opened 03:33AM - 01 Dec 20 UTC
Plane
VTOL-Plane
DevCallTopic
ReleaseAdmin
This is an issue to gather key issues for the plane 4.2 release
- [ ] display …message on pilot override active in VTOL pos controller (can prevent descent stage)
- [ ] make stabilize mode use proper rate control
- [ ] mavcan to multiple clients at once
- [ ] can gui tool panel for secure commands
- [ ] add rate limited filter to airspeed to prevent large spike from corrupting airspeed
- [x] default TECS_LAND_ARSPD to mid-point of cruise and min airspeed
- [ ] propogate Dmod up to angle loop
- [ ] look at using -g -O2 for stable builds for better crash dump analysis
- [ ] ATT.DesPitch and ATT.Pitch need to use the same pitch reference (ie. TRIM_PITCH_CD)
- [ ] motor_lost_index never reset and not exposed in lua
- [ ] work out why 2048 byte reads in #23455 failed
- [x] allow clear mission when disarmed in AUTO ?
- [ ] add waf docs target?
- [x] possible bug in RTSCTS?
- [ ] Q_M_PWM_TYPE set in defaults.parm in ROMFS doesn't work for DS150
- [ ] GSF yaw errors: https://github.com/ArduPilot/ardupilot/issues/23224
- [x] mission on sdcard
- [ ] more flexible M10 config: https://www.rcgroups.com/forums/showpost.php?p=50442153&postcount=8212
- [x] fix pitch limit in FBWA for transition: https://github.com/ArduPilot/ardupilot/pull/22730
- [ ] after a bounce off the ground, PIQA.I can peg high (seen in Alia model)
- [ ] switching to RTL when in landing sequence to cope with VTOL motor start fail doesn't change to fw mode
- [ ] ARSPD_TUBE_ORDER=3 to auto-detect order
- [ ] MS4525 probe all buses not working in 4.3 after update from 4.2
- [ ] rudder arming causes yaw in AUTO takeoff #22665
- [ ] VTOL approach can turn overshoot if WP_LOITER_RAD is small
- [ ] COMPASS_DIA_X of zero not treated as 1.0 #22666
- [x] level cal not clearing 3d accel cal needed msg?
- [ ] CubeOrangePlus param diff BAT*PIN doesn't show changes
- [ ] not using full throttle in non-airspeed takeoff: https://github.com/ArduPilot/ardupilot/issues/22572
- [ ] random voltages with voltage pin -1
- [ ] large over-tune can cause VTOL controller to climb-away, possibly lower default SMAX?
- [x] with RTL autoland: Mode change to AUTO denied, in fence recovery
- [x] MS5607 sub for MS5611 for Pixhawk1 Marco
- [ ] annoying msg Cannot calibrate with Q_TRIM_PITCH set
- [ ] not fully resetting tdrag takeoff state on new takeoff
- [ ] ICE idle governor in Q modes while disarmed
- [ ] Camera gimbal settings seem to be gone from QGC with Plane 4.3. ? (from fredrikfalkman)
- [x] receive DO_AUX_FUNCTION in lua scripts
- [ ] need better BVLOS advice and testing: https://github.com/ArduPilot/ardupilot/issues/21876
- [ ] throttle slew limit when re-starting engine on RPM outage
- [ ] reduce XY gains when rate gains activate Dmod?
- [ ] incorrect CRSFv2 detection: 2022-10-02 14:07:47.120 CRSFv2: requesting RX device info
- [ ] remove loop rate dependency on power limit for fixed wing
- [ ] limit integetrator buildup longer for catapult launch
- [ ] allow idle governor to control ICE idle in Q modes when disarmed
- [x] scale down rate PIDs during back-transiton based on airspeed?
- [ ] auto-lower pos controller gains when have attitude error?
- [ ] should use EKF height and vertical velocity estimate not DCM on loss of GPS when in quadplane mode
- [ ] add package drop support
- [ ] always allow at least 10 deg roll limit for fixed wing
- [ ] add arming check for VTOL I gain <= P gain on roll/pitch
- [ ] motors spin sometimes on soft reboot of HWing
- [ ] test ublox fw update with passthru
- [ ] before triggering Q_ASSIST_SPEED, check EKF fusion of airspeed, if not fusing, delay assist speed
- [ ] add mission and fence extraction to MAVExplorer
- [ ] add tailsitter tune param for P, I, D sequence
- [ ] option for median filter between synthetic airspeed and dual-airspeed
- [ ] re-load mission on arming in AUTO? See https://discuss.ardupilot.org/t/striver-mini-vtol-4-1-quadplane/71805/185?u=tridge
- [ ] rapid switching between EKF and DCM on baro error: https://discuss.ardupilot.org/t/excessive-ekf3-dcm-switching-in-plane-4-1-6/82966/5
- [ ] look at methods of handling flash parity errors on H7, possibly using HW CRC
- [ ] obey primary sensors with EK3_AFFINITY
- [ ] motors spinning when they shouldn't? https://github.com/ArduPilot/ardupilot/issues/16630
- [ ] force arm bypass of logging start and fence auto-enable
- [ ] need force_descend change for quadplane: #17824
- [ ] surface control while booting not working: #17966
Features for later 4.2.x releases:
- [ ] sort out CAN baro ordering for plane, maybe option bit in BARO_OPTIONS, on plane default to can baro last
- [ ] support rangefinder correction of AP_Terrain data, with configurable time constant
