Dev Call May 1, 2023
Issues & Pull Requests
Plane
Copter
Attendee count (max): 16
UTC1101 - common.xml: Add MAV_RESULT_COMMAND_LONG_ONLY and MAV_RESULT_COMMAND_INT_ONLY to MAV_RESULT by sypaq-nexton · Pull Request #1982 · mavlink/mavlink · GitHub
  • Add a pair of return values to determine if the vehicle understands command long/command int
  • Perhaps we should do a default mapping from command int to command long
    • Shouldn’t the command long be the base?
    • No, we should convert command long to command int
    • Use a default case in the command long to command int case
    • Use a specific list in the other case
UTC1109 - Plane: don't trigger RC failsafe until RC has been received for the first time by IamPete1 · Pull Request #23189 · ArduPilot/ardupilot · GitHub
  • Don’t trigger RC failsafe until RC received for first time on Plane
  • Merged!
UTC1111 - ESP32 classic fixes and a new board by davidbuzz · Pull Request #23569 · ArduPilot/ardupilot · GitHub
  • Fix ESP32 and add a new board
  • Needs to stop adding more ifdefs for the HAL we’re building for
  • Commit messages need fixing
  • Nested interrupts or not on this platform?
    • Stack is on current thread under ChibiOS
    • Not sure if it’s a separate stack on freertos
UTC1118 - Tools: sim_vehicle to only launch one 1455x UDP port by magicrub · Pull Request #23579 · ArduPilot/ardupilot · GitHub
  • Launch only one 1455x port rather than two in sim_vehicle.py
  • Merged!
UTC1120 - Move NTF_LED_TYPES to hwdef, rename to new pattern, fix line endings in Sierra autopilots hwdefs by Hwurzburg · Pull Request #23589 · ArduPilot/ardupilot · GitHub
  • Move NTF_LED_TYPES to hwdef, rename and fix some line endings
  • Can’t do a lot of things in the hwdef
    • E.g. servo channel defaults
  • Need to fix the CUAV nora
  • Can be merged once the cuav nora thing has been fixed
UTC1125 - Plane: move to more mode run functions by IamPete1 · Pull Request #23595 · ArduPilot/ardupilot · GitHub
  • Move to more mode run functions
  • Fixing stabilize mode?
    • Surface deflection based ons ticks
    • But actual rate you get is very dependent on tune as you’re fighting the PID
    • Incorporate logic from acro?
    • Make it somewhat like our new acro controller?
    • Try to do a loop in stab?
      • Really weird and gets squirrelly
      • Would be nice to be able to do a loop in stab
      • Stab in a tailsitter doesn’t work at all!
      • Acro trainer in stab?
        • People reach for stab because that’s what Copter has….
        • Betaflight?
          • Angle is fbwa
          • Horizon switches between angle and rate
          • Maybe rope in rcgroups people and see what they’d like?
UTC1130 - Filter: SlewLimiter: always caculate slew limit by IamPete1 · Pull Request #23597 · ArduPilot/ardupilot · GitHub
  • Slewlimiter - always calculate slew limit
  • So we can log it!
  • Pretty graphs….
  • Still need to log PIDs in Copter….
    • Maybe at 10Hz?
    • Bill wants them faster
      • Or at least an option for it
      • 10Hz at least gives you integrator windup (and slew rates past PH’s PR)
        • And FF on heli
UTC1138 - Make default for land airspeed halfway between min and cruise and make it apply to both FW and QPlane approaches by Hwurzburg · Pull Request #23601 · ArduPilot/ardupilot · GitHub
  • Move default for land airspeed half-way between min and cruise
    • Problems with slowing down on large quadplanes with this patch?
  • tridge will work with Henry on this one
UTC1147 - Normalize SerialManagers ports defaults to allow inclusion in hwdefs by Hwurzburg · Pull Request #23602 · ArduPilot/ardupilot · GitHub
  • Make serialmanager defines regular
  • Peter thinks doing parameter conversion would be good
    • Tridge doesn’t think it is worth it
  • Maybe we can just remove SERIALMANAGER_CONSOLE_BAUD?
  • Can be merged if Peter’s happy with it!
UTC1157 - AP_Mount: Siyi supports absolute zoom control by rmackay9 · Pull Request #23609 · ArduPilot/ardupilot · GitHub
  • Support absolute zoom control on Siyi
    • As a percentage
  • Works on A8 and ZR-10
    • Distinguished by message length!
  • Merged!
UTC0001 - AP_HAL_ChibiOS:correct KakauteH7 IMU label by Hwurzburg · Pull Request #23628 · ArduPilot/ardupilot · GitHub
  • Correct IMU label on kakuteh7v1
    • They’re bringing this back….
  • Merged!
UTC0002 - AP_HAL_ChibiOS:correct KakauteH7 IMU label by Hwurzburg · Pull Request #23628 · ArduPilot/ardupilot · GitHub
  • Mode takeoff to climb to tkoff_alt_minimum if already flying on entry
  • Flipped into mode takeoff
    • Started to loiter at 20m
    • They were expecting mode auto behaviour
  • If you enter the mode and you’re below the altitude you’re after you will climb to your takeoff alt
    • Like a loiter with a minimum takeoff if you’re already flying
    • We don’t do the wings-level thing
  • Valid-position checks
  • Offsets were wrong too
  • Flat-world assumptions using home?
    • Should be terrain-relative
  • We shouldn’t descend… but that’s already in here
UTC0016 - Add AP_RCPROTOCOL_SBUS_ENABLED option by peterbarker · Pull Request #23631 · ArduPilot/ardupilot · GitHub
  • Add and use AP_RCPROTOCOL_SBUS_ENABLED
  • Merged!
UTC0020 - Copter takeoff max rpm check by WickedShell · Pull Request #23637 · ArduPilot/ardupilot · GitHub
  • Copter takeoff max rpm check
  • Sanity check that the rpm is sensible
    • Might catch ESCs desyncing
  • What spin regime are we in?
  • Merged
UTC0024 - AP_Camera: support image tracking by rmackay9 · Pull Request #23640 · ArduPilot/ardupilot · GitHub
  • Track a point on a video stream
  • Also track a rectangle
  • Seemed to work OK on the camera Randy was using
  • Aux switch locks in current thing to track
UTC0034 - EKF: fixed watchdog on failure to allocate EKF cores by tridge · Pull Request #23648 · ArduPilot/ardupilot · GitHub
  • Fix watchdog-at-boot in low-memory situations
  • Why are people running out of memory all of a sudden?
    • Spot checks to be done
  • Will be merged after minor change made
UTC0037 - waf: added -g option to configure by tridge · Pull Request #23649 · ArduPilot/ardupilot · GitHub
  • Add -g option to configure
    • Gives you debug symbols
  • Merged!
UTC0038 - Add failsafe protections to Mode Takeoff by Hwurzburg · Pull Request #23650 · ArduPilot/ardupilot · GitHub
  • Add failsafe protections for mode takeoff
  • Descriptions on failsafe actions are…accurate but incomplete and confusing
  • Henry was making detail tables
  • Mode takeoff does nothing on failsafes ATM
  • Henry thinks we should at least what we do in auto
  • So long as you’re above takeoff alt
    • Will re-trigger once you’re above takeoff alt
  • If you have your long failsafe as glide would the extra 5 metres of alt you can if you lost RC immediately be an issue?
  • If we put the protection in takeoff - why isn’t the same thing in auto?
  • Tridge thinks we should climb to normal altitude and then trigger
  • If you get a GCS failsafe should we do this new behaviour?
  • Mode takeoff and nav takeoff is different
    • Different throttle levels!
  • RTL with climb assumes vehicle is climbing
  • Rolling takeoffs would make going to RTL problematic!
    • Not necessarily on your wings!
  • Vast majority
  • You would get two events logged
  • Stale state with the long failsafe state?
    • Don’t call check_long_failsafe during takeoff?
  • Maybe have a “long failsafe action suppressed” timestamp which can be updated?
UTC0102 - Plane update
  • 4.4 Testing has been positive
  • Some sort of filter on airspeed input data might be a good idea
  • There’s the EKF-out-of-memory problem
  • A few other things marked as 4.4
  • Ina228 battery monitor is pending testing
    • Tridge wants to backport to 4.4
  • Compass-less Plane permanent disarm
    • Re-arm in flying is not guaranteed!
    • Isn’t this why we added the estop variant?
      • yes
  • Prior to 4.4rc1 or 2 you could rearm in the air
  • State reset on disarm was added for gsf
    • Problem was there
    • When only on GSF it’s OK
    • But if you add a compass you can’t re-arm
    • Refusing to arm
  • On disarms the gsf is reset
    • Don’t do this if is_flying?
    • “EKF is no longer aiding” is what you get
  • Tridge to get some logs to look at
UTC0110 - Copter update
  • 4.4 testing has gone OK
  • Watchdog fix
  • Custombuild builds flying strangely?!
    • Seems unlikely!
    • Need logs…
  • Michelle found an EKF error on a small quad
  • Yapu reporting for second battery
  • Ekf origin alt being set badly by MissionPlanner
    • Can be very bad
    • Only really affects non-GPS-navigation user
  • Beta2 probably won’t go out this week
    • Golden Week
UTC0114 - ESP32 redux
  • Merged
UTC0117 - partner’s call tomorrow
  • Need to cover use of apj tool to add parameters
UTC0117 - vote for funding committee
  • Now open
UTC0117 - GSoC
  • Waiting for number of slots to come back
UTC0118 - close
