hunt0r
(Hunt0r)
March 31, 2026, 12:09am
2
Time-permitting, I plan to bring this “off the floor” at the end of the meeting.
Discussion-focus questions for the PR template changes :
1a. Is adding a PR classification section sufficiently valuable?
1b. Should classification instead be non-checkbox bullet points that an author is responsible to delete if they are not applicable?
Do we have consensus on the proposed checkbox changes?
Do we have consensus on adding a “Testing Details” section (distinct from the “Description” section)?
Attendee count (max): 18
UTC2301 - CI
Colcon thing still in testing
Common origin issues
Make the set origin call return false?
We have a PR which doesn’t work
UTC2307 - 4.7beta
ArduPilot Dev Call 2026-03-30 - Google Docs
Randy was unable to reproduce the secure bootloader problem
Closed the issue due to a lack of response to the user
IST8310 issue will be resolved in beta3
Board safety options and defaults acting weirdly?
Loiter performance
Set the input to 0.1 from 0.15 and be happy, people!
Input shaping
previously made the approach slow (jerk-limited approach to zero)
Now it does the same thing on departure (jerk-limited departure from zero)
Smooth transitions in both directions
Same time constant
For small adjustments you can see this
We are planning on changing the default
This was the biggest blocker
EKF alt offset increases when switching
Questions around some parameter conversion
Flight code / units to make GCS happy?
Allow MissionPlanner the ability to force-load the same firmware
Helps clear the crash dump off the vehicle
There’s some odd stuff with climbing 2m in land
Ignores height in waypoint
One ignores, one doesn’t
Beta releases every 2 weeks is the plan
Change description in xtrack fields in XML
Need to see if anybody is using these meanings, because they’re pretty out there
Correct mavlink/mavlink/master version of enum only used by AP
Approved
Fix blimp manual test
Long-standing PR which fixes a problem
Not fair leaving a CI job failing all the time
Need to go one way or the other
Randy will ping Michelle directly
It was always close to the edge
Add EK3_MAG_CAL=7
Want testing evidence but good to merge past that
Fix bound check in mode_switch_changed
Merged
Can’t actually cross this path
AP_NavEKF3: use onGroundNotMoving for zero velocity fusion#32396
Are we really not moving when that state is true?
We want to know what’s behind this PR
What’s the real-world thing that this fixes?
And a log?
Fix some method and attribute names
Will merge when confirmed as no compiler output change
The rover breakout Randy will look at it
Clean up DPS280 vs DP310 state
Merged
Fix RC input in face of combination of RC input and failsafe values
Merged!
Rework rotor speed control library
Streamline it
Removes extra code which is now in the motor frames up
Decisions are being moved up into the RSC
Questions around desired vs actual spool states.
Whether outputs should be based on one vs the other….
It’s ongoing
UTC0022 - waf: Drop support for end-of-life Python 3.8 by cclauss · Pull Request #32526 · ArduPilot/ardupilot · GitHub
Drop support for focal in Vagrantfile and environment install script
Marked for merge
Along with a companion PR
Check backend return values when setting common origin
Doesn’t work at the moment because of the set-once thing
Suggestion is that the backends return true if you are trying to set the same location to same spot to avoid the “already set” problem
Will come back to DevCallEU
Unit tests for SITL battery
Merged!
Simulations for topotek, viewpro AVT and Siyi gimbals
Merged!
Loop over states in FuseBodyVel Kalman gain
Saves ~4kB on 2MB board (boards with velocity feature)
MergeOnCIPass
UTC0054 - off the floor
PR template changes
Classes of PR?
No compiler output change
Random code changes
Behaviour change
Keep the checkboxes
Peter will merge reasonable changes
UTC0009 - partner call tomorrow
UTC0009 - close
Is this referring to ATC_INPUT_TC?
Yes it is referring to ATC_INPUT_TC
