hunt0r
(Hunt0r)
2
Attendee count (max): 18
- Colcon
- Peter has a candidate branch he’s fixing
- Speed stuff
- Seems to be CI going slowly
- Maybe some other of our repositories is being pushed and chewing up vast numbers of our runners?
UTC2308 - release update
- New beta2 going out today
- Please test
- George helped, will be able to help out even more next time
- We’re going to tag AP_Periph now so it goes out as beta1
- Table coding coming for 4.8
- Release notes are always the problem
- Report of secure boot problem in 4.7
- POI lock not in normal firmware - should it be?
- Arc waypoints wip in mavlink?
- Alt est offset between baro and rangefinder
- EKF inputs
- The magic switch stuff
- Causes a persistent offset
- Doesn’t revert to purely using the barometer
- Copter flip mode via RC switch
- Can’t abort/disengage with the switch
- Not new in 4.7
- Genuine soaring bug when autolanding?!
- Sam wants to withdraw as soaring maintainer
- Slower behaviour in loiter in Copter?
- Lower time constant seems to make things feel like it used to
- Probably the biggest blocker/issue
- The change in loiter/co-ordinated yaw is strong
- It’s called out strongly in the release notes too
- VTOL missions with terrain following really don’t work
- Probably not something we will fix for 4.7
- Also in 4.6
- PH will probably look more closely
- Fence alt min type
- Peter’s unwilling to approve the renames
- Merged!
- Peter Barker — 5:44 PM
Also, I do reserve the right to say, “I told you so” when reviewing CFIT logs related to that last PR
- Loop over statyes to zero memory
- Saves a bunch of flash
- Can be merged once Replay has been addressed
- Blimp PID tuning fixes
- MergeOnCIPass
- Existing optical flow fusion code uses a terrain estimator to scale the flow values
- Height estimate from the main filter is used as a filter for this estimate
- Whenever the main estimator’s estimate is bad it feeds into the scaling of the flow
- This PR breaks that connection
- What happens when the new thing breaks?
- Dead-reckoning is very bad
- E.g. rangefinder going away will cause serious, serious problems
- There’s a time limit on that
- This will do better with vigorous vehicle motion
- Should we remove the old one?
- Plane’s use of the optical flow thing as a height source should be unaffected
- Will bring this one back
- Rename save_comms_ip to restore_comms_ip
- Merged!
- Add support for UTM_GLOBAL_POSITION
- Screwed up the relative alt
- Use zeroes if we can’t get the variances
- Move to using a structure send?
- Questions around undulation
- We’re currently sending amsl
- We’re not going to send the alt field unless we can get the undulation
- If a burst read is exact multiple of the packet data length we sent the wrong ack offset
- Will be back
- Add option to show object file differences
- Can be merged once review comments have been approved
- Sanity check email address before allowing merge
- Merged!
- Fix Get_flow_control fin SITL
- Merged!
UTC0040 - off the floor - SITL battery design proposal
- Tridge wants to see a PR
- Advice given, this will be back
UTC0052 - close
What is the safe way? Disable dead reckoning so that it will execute a fail safe?
