Dev Call March 2, 2026
CI Workflows
Release Update
Issues & Pull Requests
Attendee count (max): 15
UTC1101 - CI ci · Workflow runs · ArduPilot/ardupilot · GitHub
UTC1102 - release update
  • Randy’s working on release notes
    • Several days so far
    • 2400 PRs total
    • 900 were done by AI
    • There are more PRs being merged all the time….
    • Maybe end of day today
    • AI is including more information (e.g. link to each PR)
    • PR by end of day
    • Please don’t be disappointed or angry if your work is not in the release notes
      • Ping Randy if you particularly want your work mentioned
      • There’s already 1000 lines in the release notes and some pruning required
      • But also things might just be missed
  • Maybe beta end of this week
  • Peter had two PRs he wants in before 4.7beta
    • Andy’s fence alt frame type
    • Trimble’s EAHRS PR
  • Randy’s got some parameter conversion PRs
  • RTL Alt final relative to terrain might be an issue that needs fixing
UTC1110 - Add New Target: KT-FMU-F1 by redstonee · Pull Request #32180 · ArduPilot/ardupilot · GitHub
  • Add support for KT-FMU-F1
  • Merged!
UTC1112 - autotest: tidy RTLSpeed test by peterbarker · Pull Request #32221 · ArduPilot/ardupilot · GitHub
  • Tidy RTLSpeed test
  • Just a cleanup
  • Merged!
UTC1114 - Add FAST_BOOT bitmask parameter by rishabsingh3003 · Pull Request #32238 · ArduPilot/ardupilot · GitHub
  • Add fast_boot bitmask parameter
  • People are uncomfortable with this
  • Don’t want two ways to two things
  • We are very skeptical of the DroneCAN thing
  • We want boot faster for everyone, not just people using this feature
  • Peter will do some analysis on what slows the boot process down the most
    • Measure then cut
UTC1120 - Add FAST_BOOT bitmask parameter by rishabsingh3003 · Pull Request #32238 · ArduPilot/ardupilot · GitHub
  • Support for ResoluteH7
  • Needs Andy
UTC1125 - Rover: use enumeration entries when sending PID_TUNING message by peterbarker · Pull Request #32301 · ArduPilot/ardupilot · GitHub
  • Use enumeration values for PID tuning message
  • Merged the mavlink, this one can go in next
UTC1128 - common.xml: add invalid to fields of RC_CHANNELS_SCALED by peterbarker · Pull Request #484 · ArduPilot/mavlink · GitHub
  • Adopt mavlink/mavlink/master flag values
  • We have a problem with flag values and plotting
    • Don’t want to kill canned graphs!
  • We will kill the sending of this message instead of adopting the change into the ardupilot repo
UTC1139 - common: document force-save values to PREFLIGHT_CALIBRATION by peterbarker · Pull Request #485 · ArduPilot/mavlink · GitHub
  • Document force-save values for preflight calibration
  • Good to merge once same changes upstream
UTC1140 - common: document NAV_TAKEOFF param3 autopilot-nav requirement by peterbarker · Pull Request #486 · ArduPilot/mavlink · GitHub
  • Document param3 in NAV_TAKEOFF which ArduPilot supports
  • Allows the vehicle to take off in modes which don’t hold horizontal position
    • E.g. ALT_HOLD
  • Some discussion over wording
  • Peter will merge
UTC1148 - terrain data issue
  • Should we send out a user alert?
  • Git commit reference for the fix doesn’t make a lot of sense in this case
  • Requires further investigation
  • Randy doesn’t think it’s going to work
    • Issue is not related to an ArduPilot flight code issue
    • Doesn’t make sense to tie to a particular version of ArduPilot
    • Maybe the fix is the one that’s referenced
  • Do we need a 4.6.4 with the prearm failure in it?
  • We’ll need some sort of dry run
  • Let’s talk about it again next week
  • Would we have to provide patches for 4.0, 4.1, 4.2, 4.3, 4.4, 4.5 too?
  • Maybe ask the partners what they think
UTC1159 - delaying partner meeting for a week
  • Randy will log in and catch people that showed up anyway
UTC0001 - GSoC update?
  • Hunt0r will help out as unofficial mentor
  • Nate’s comfortable to do a couple of students
  • Any other DevTeam members interested in taking on a student?
UTC0005 - drone tow stuff
  • Ryan was accepted onto the committee, working on test plan
  • Testing glider/hang glider
  • Evaluating whether it can be done safely / waivers
  • If you have concerns then talk to Ryan
  • Someone has a system which may or may not be running ArduPilot
  • Need to know if this is something to encourage or discourage
UTC0008 - close
