Issues & Pull Requests
Plane
Copter
Rover
Attendee count (max): 18
UTC2300 - https://github.com/ArduPilot/ardupilot/pull/17530
- particle sensor driver in i2c
UTC2305 - https://github.com/ArduPilot/ardupilot/pull/17621
- Run Prearm checks with a button in the GCS
- Can be merged with the relevant mavlink stuff going on
UTC2307 - https://github.com/ArduPilot/ardupilot/pull/17649
- We should auto-detect the message type rather than
- Battery identifier required
- Too much static information in the one message
- What does this give rather than the existing battery messages?
- How does this interact with the SMART_BATTERY_INFO message?
- Float16 for cell voltages
- An auxiliary message which gives more information for the information not covered elsewhere?
- Single backend, multiple message listeners
- Battery serial number
UTC2320 - https://github.com/ArduPilot/ardupilot/pull/17669
- Reverting Q pitch limit patch
- Now skips q position 1 state for tailsitters
- 100kph and then asking vtol controller to handle positioning…
- Not really designed for that
- Severe actions
- Will pitch up at your max pitch rate
- Will go up a really long way?
- Not the perfect solution but gives smooth transitions back
- Approach -> position2 on landing
- Via tailsitter transition stuff
- Airbraking and tailsitters is interesting
- TVBS could do more during the aerobraking portion of the
UTC2327 - https://github.com/ArduPilot/ardupilot/pull/17629
- Setting message intervals using a configuration file
- Uses up ~1kB of messages
- Try to make it smaller
UTC2343 - https://github.com/ArduPilot/ardupilot/pull/17716
- Increase number of cells to 14 from 12
- merged
UTC2346 - https://github.com/ArduPilot/ardupilot/pull/17721
- Remove HIL
- Merged
- Wasn’t useful in its current form
UTC2347 - https://github.com/ArduPilot/ardupilot/pull/17730
- Make sure MatekF405 bi-dir output get a DMA channel
- Merged
UTC2348 - https://github.com/ArduPilot/ardupilot/pull/17754
UTC2352 - https://github.com/ArduPilot/ardupilot/pull/17762
- Move filesystem operation to backend
- More filesystem corruption?
- Will get this merged this week
UTC2358 - https://github.com/ArduPilot/ardupilot/pull/17766
- Merged
- Bindings for set_home and set_origin and get_origin
UTC0001 - https://github.com/ArduPilot/ardupilot/issues/15941
- First Plane beta release out
- First beta release done from a hospital room
- Thanks to Henry for all the testing done
- Tim French did an interesting test
- Package delivery
- Similar to Google Wing vehicle
- Lots of small parameters
- Using Plane VTOL transition to do hovering stuff
- Usually you would loiter-time
- Beta2 maybe next week
UTC0004 - no Copter or Rover update as no Randy
UTC0004 - GSoC update
UTC0012 - AuxFunc library
- Tridge will follow Randy’s lead on this one
UTC0012 - PositionControll stuff
- Leonard can get back on top of this stuff over hte next little while
- Several little things
- The SCurve vector-equal thing went in
UTC0013 - close
