**Issues & Pull Requests"
GSOC
Funding
Contribution of the Month
Shenzhen EXPO 22-24th June
Plane
- Fix for Quadplane QLOITER
- Airspeed fix
Copter
Rover
Attendee count (max): 25
UTC2301 - https://github.com/ArduPilot/ardupilot/pull/8601
- Detect conflict between compasses on one batch of Here+
- Two compasses same i2c address
- Corrupted magnetic fields
- All sorted out now with these patches
- Should probably be backported
- Workaround is to set compass-typemask to disable the icm20498
UTC2307 - https://github.com/ArduPilot/ardupilot/pull/8531
- Tom is in another timezone still
- This discussion needs Tom
UTC2308 - https://github.com/ArduPilot/ardupilot/pull/8492
- Log plane navigation functions
- Column name issues have been resolved
- Gb-init-ignore was also snuck in
- Should be have a sample gdbinit file?
- Template for people if they wanted it
UTC2309 - https://github.com/ArduPilot/ardupilot/pull/8354
- Did this get tested in SITL?
- Lexton wanted his vehicle to fly slow
- Michael wants his vehicle to fly fast
- Did that option go in?
- Not yet, but it is required
- We havenāt progressed this oneā¦
UTC2312 - https://github.com/ArduPilot/ardupilot/pull/8327
- Storm32 native serial mount
- Little bit of work since last week
- We should jump in and do whatever little cleanups are needed given this is a first-PR
- Nullptr-checking, that sort of thing
- FF is hoping to look at this this week
UTC2314 - simplify radio trimming
- https://github.com/ArduPilot/ardupilot/pull/8499
- Report back to GCS if it failed
- Pulling same result from radio is pointless
- Why do this rather than setting parameters?
- MP might have a button to just trim parameters
- MAVProxy can synthesise packets at the command-line to test this sort of thing
- On-board radio trim?
- This just needs testing
UTC2319 - https://github.com/ArduPilot/ardupilot/pull/8603
- Remove F4Light HAL entirely was proposed this-morning
- Tridge has been working on F4Light with night-ghost for some time
- Appropriate licensing wasnāt checked on merge
- Tridge found the libertyv2 license recently in the code
- Tridge has been working hard to get this mess cleaned up
- Night-ghost has made many patches to try to fix the problem
- None of them have been sufficient
- 50,000+ lines of code to rewrite?!
- Still likely to be derived work
- People MUST take these licensing issues seriously
- ChibiOS ST libraries?!
- Proposal: remove F4Light HAL
- With very great regret as this was an extremely valuable addition to ArduPilot
- With very talented user-base
- ChibiOS port will support most of the hardware
- Will lose some features of some boards
- Tridge will work on Native-OSD support
- Will also work on Linux, then
- Need to make a public announcement expressing regret and explaining what needs to happen to get it back in
- Exemption?
- It would basically be a relicensing of the ST libraries as an exemption just for ArduPilot wouldnāt work (GPL requirements)
- License is not a piece of text. Itās a URL!
- They can dynamically change the license?!
- Hard to tell what license software was licensed under otherwise
- Many, many, many other Open Source (inc. GPL) projects include these libraries
- OpemCM3 was created (and NuttX HAL-layer was created) in response to the Liberty license!
- ST does have a lot of stuff out there with compatible licenses
- PR is poking his contacts
- Contribution agreement?
- Adds friction
- Small contributions from new developers will be harder
- Will slow things down a bit
- There are tools out there to ease the process
UTC2338 - GSoC
- Most students have published a blog on discuss
- Putting together a meeting for all of the mentors for evaluations
- Skype group chat is a reasonable place to put stuff
- Ebin has balance-bot balancing in SITL
- He has hardware
- Should be balancing on real hardware shortly
- Desired-velocity controller still to be done
UTC2340 - funding committee
- Very nice response
- James Pattison has been voted in
- Still time to vote ātil end of call
- [9:42 AM] (Channel) MdB: please leave vote result viewing openā¦
- [9:42 AM] (Channel) MdB: not to keep harping on that, but really?
UTC2342 - nominations for contribution-of-the-month
- Sh83, chobitsfan
- More nominations welcome
- Weāve been a bit slack on doing these
- Give both?
- Vote to give to both as weāve not been doing this in too long
UTC2343 - new funding request
UTC2344 - Shenzhen expo
- 1.5 weeks off
- Conference schedule under control
- 1 or 2 slides missing
- Will be finalised in next few days
- Then translated to Chinese
- People have been working on exhibition booth
- Banners are an issue
- Jani will make and hand-carry to Shenzhen
- Ideas for design are welcome for these banners
- 24 hours before work to be started
- Text for the banners would be greatly appreciated
- The VTO banner wording
- Business commentary? Technical commentary
- Jeff has layouts in front of him but writerās blockā¦.
- Contact Jeff if you can help!
- History-wall will be there
- LCD TV
- Jeff will supply list-of-videos
- https://docs.google.com/document/d/1h1_2G_8xBSOs1fTpaQasGqz3U77YKPNbxTAHC-Pt3Pg/edit?usp=sharing
UTC2355 - qloiter and airspeed error
- Quadplane and new loiter code
- Initialisation fix
- And some new default parameters
- Will go into second beta
- Airspeed sensor
- Vertical lift motors popped on on the Porter
- Interesting class of error
- Brief airspeed failure
- 3 seconds
- We correctly shifted to internal airspeed estimate
- We updated a filter based on this value, however
- Including for the raw pressure
- Completely rubbish airspeed when the sensor came back because the filter was polluted
- Be wary of āInfinite impulse responseā
- Big erroneous input will affect filter forever
- Not the case with this particular bug, but something to look out for
- New beta time!
UTC0000 - Randy and Copter
- Rover Rc2 is out and being tested
- Polygon fence fixed
- Easy calibration fixed
- RC8-minimum-below-trim
- MP sets RC trim on unused RC channel to zero all around
- Hopefully MO can fix this
- Does happen on higher-numbered-channels too
- New beta to come out
UTC0004 - Randy and Rover
- Still in beta for 3.4
- Really great feedback
- Including on vision-position-estimate
- accel/decel fixes
- Better pivot turning
- One issue outstanding
- Wide turns
- We moved the speed-scaling into the motors library out of AttitudeControl
- Restricts the output range
- Leads to not having good steering control at high speeds
- PR is in place
- Accepts numbers outside -1ā¦1
- Rc2 should be out later this week
- Moving scaling to output?
- Clamping to +1/-1 only after scaling is applied?
- Not just Rover which suffers
- Meaning of i-term an change over time
- E.g. tight corner at high speed == i-term buildup
- When you slow down the meaning changes?
- Plane has multiple actuators for same axis
- E.g. differential thrust and rudder
- Need different speed-scaling factors for these actuators
- Tridge is thinking about adding something in servo library to add speed scaling
- Set-speed-scaling of k_left_throttle
- Set-speed-scaling of k_left_rudder as 1/speed
- Would scale rudder according to speed
- E.g. a swamp boat with two motors and a rudder?
- Motors library or parameters as tridge described?
- Multicopter with rudder?
- Something into motors library
- Every multicopter frame would need to know about rudders?
- Will continue discussion in general chat during the week
UTC0014 - AntennaTracker maintainer position still open
UTC0015 - expo redux
UTC0016 - make videos!
- Need videos for things like calibrating airspeed sensors on Planes and the like
- Nate might be able to put some together
- E.g. COās tradheli videos
ppoirier
(ppoirier)
3
Really interesting getting updates from these projects.
I just see 2 Blogs atm : @dima and @AyushGaud and @shortstheory
Are there any others ?
