Issues & Pull Requests
Plane
Copter
Rover
Attendee count (max): 26
UTC1102 - https://github.com/ArduPilot/ardupilot/pull/14730
- Some receives send both percentage and dbi
- Ignore one of them
- Just use percentage
- merged!
UTC1103 - https://github.com/ArduPilot/ardupilot/pull/14657
- Running telem at higher frequencies floods logs at 100Hz
- 400 messages per second
- One timing subtraction issue
- Can be merged after thatâs fixed
UTC1106 - https://github.com/ArduPilot/ardupilot/pull/14618
- Options for acro
- Pushing size out?
- Leonard devised these when redoing attitude controller
- Sysid without the controllers getting in the way could be goodfor heli
- Bitmask vs one-or-the-other
- Airmode mixed in with this as an option in acro
- Yaw2 / yaw3?
- Developers can look at variations
- âAcro lockingâ
- Air-mode works well for loops and whatnot
- Want the option to disappear for heli
- Arming-on-a-switch and heli?
- What happens when airmode is activated?
- Pre-existing
- Airmode should be independent of modes
- Just always stabilizing
- Helis are always stabilizing anyway
- Leonard to look at this
- Remove extra options that wonât be popular
- Bill wants to check this out for Heli implications
- Randy is worried about user support on adding extra options
- This allows people to test their rate loops but not their stabilisation loops
- One acro here doesnât rely on the EKF giving an absolute attitude
- Normal one does
- Robust to EKF performance issues
- Advantages to each different acro mode
- Easy way for people to play with own attitude stabilisation techniques
- Leonardâs not sure if the third one is overhead we donât need âthough
- One and three may be useful, two may not be
- Billâs really not sure about that air mode on tradheli
UTC1120 - https://github.com/ArduPilot/ardupilot/pull/12200
- Ifdefs to control bidirectional stuff
- Couple of CI issues
- Extracted frsky and protocol decoder about a bit
- On correct path here?
- Does it build with bidirectional off?
- Which thread are we processing these on?
- Need to work on CI failures
- Needs feedback from the community!
- Might get alignment errors
- Want to make sure weâre using appropiate be16toh etc
- Navio target is useful for getting the warnings
UTC1148 - https://github.com/ArduPilot/ardupilot/pull/14453
- Video - 8 minutes long
- PH worked out why he added the function
- Going from q mode to forward flight is instant transition
UTC1153 - https://github.com/ArduPilot/ardupilot/pull/14441
- Select backend rates
- Needs it on his 3â quad as motor RPM goes above 500Hz so canât drive notch filter higher than that (Nyquist)
- Adds another parameter to set the gyro sample rate
- Need a racing-quads setup page that mentions this sort of parameter
- Fast sampling determines raw sample rate
- This changes the rest-of-sample rate
- Change in behaviour for F7/H7 due to faster sample rate
- Fast sampling vs not fast sampling?
- Donât have a separate parameter by sensor
- Another parameter for each INS to specify a rate for each sensor?
- Need more feedback to users on what the final configuration is
- Rates that are finally coming out like we do for PWM output types
- In the dataflash log?
- Text to user e.g. âIMU1:8.0kHz/2.0kHz IMU2:4.0kHz/1.0kHzâ
- Param name?
- Backend rate / frontend rate
UTC0009 - https://github.com/ArduPilot/ardupilot/issues/14763
- Generating duplicate documents for ATC
- Either agree on ranges etc
- Or add heli file as entire parameter set
- The two frame types have significantly different parameters
- Parameter versioning is done on the Wiki side
- Check with MO to see if heâs OK with adding heli as a separate parameter set
- Ask Don too
UTC0016 - https://github.com/ArduPilot/ardupilot/pull/14174
- Decode DSM frame markers to avoid timing related jitter
- No Andy
- Tridge likes the scheme
- Lots of different variants of Spektrum receivers
- Canât be certain this wonât break some Spektrum receivers
- MdB will test on some receivers
- NeedsTesting marker added
- Needs IO firmware to be generated and committed
UTC0017 - https://github.com/ArduPilot/ardupilot/pull/14756
- Merged
- Fixes compiler warnings about unaligned accesses
UTC0023 - https://github.com/ArduPilot/ardupilot/pull/14755
- Throttle hysteresis?
- For ICE engines may need it to keep running?
- 5% is not a small error
- Uses deadzone
- MdB is happy with on-by-default
- MdB thinks we do need the 0% guarantee
- Sprung throttle will need to hold it down
- Throttle suppression stop it firing up ATM
- Merged!
- Should close https://github.com/ArduPilot/ardupilot/issues/14285
UTC0028 - https://github.com/ArduPilot/ardupilot/pull/14720
UTC0034- https://github.com/ArduPilot/ardupilot/pull/14671
- Makes it easier to do loops and rolls in qacro mode
- Manual-mix bug was found
- This isnât switching correctly
- Use enumeration for arming ArmingMethod and change behaviour based on that method
- Update_throttle_suppression is something to be very careful around
- Review added
UTC0040 - https://github.com/ArduPilot/ardupilot/pull/14698
- Board -> firmware mapping for users is problematic
- Fmuv2 complicates matters
- If you have a 1MB board but its not a Pixhawk1
- This would be useful then
- Fmuv2 probes for lots of different sensors
- Eliminating fmuv2 might stop some people being able to update
- Would have to be one of the clones that as 1M
- Tridge canât think of any board which needs us to build this
- People should generally be using Pixhawk1-1M when theyâre running 1MB Pixhawks
- Fmuv4 can be removed now; just use PixRacer
UTC0047 - https://github.com/ArduPilot/ardupilot/pull/14743
UTC0049 - https://github.com/ArduPilot/ardupilot/pull/14700
UTC0050 - https://github.com/ArduPilot/ardupilot/pull/14691
- Allow specification of task prioritisations
- Enumeration?
- Pseudo-enumeration
- Implicit incrementing means auditing all vehicles all the time
- Last column should not be delta
- Tridge would like an auto-increment of line before
UTC0120 - Plane update
- RTL autoland still needs to be fixed
- GCS FTP stack overflow patch
- Should already be working correctly
UTC0126 - Copter update
UTC0127 - close
