CraigElder
(Craig Elder)
#1
Issues & Pull Requests
Plane
Copter
Rover
Attendee count (max): 26
UTC1100 - https://github.com/ArduPilot/ardupilot/pull/14807
- Initial implementation of msp protocol
- Port from betaflight
- Mspv1 and mspv2
- Rangefinder and optical flow inav messages
- Matek3901 combined sensor
- DJI FPV goggles
- Telem implementation that works from both a master and one-wire mode
- Tested by a lot of people
- Lots of parameters
- Particularly for layout
- Would be nice to integrate this with OSD somehow
- Already have multiple backends
- AP_OSD_MSP
- Backend that pushed the data into a structure
- x/y coordinates for each element
- MSP code could live separately and access structure via singleton
- Access elements for sending out protocol messages
- Intermediate data structure in AP_OSD
- There is a struct already which holds the MSP telemetry
- Currently we have a printf function into the OSD backend
- Instead we should make the backend function take a format
- But some sort of other interface which provides a raw value
- Would not work well for messages
- But well for e.g. floating point numbers
- Existing backends would only look at the formatted string
- MSP backend would look at the floating point number
- MSP OSD could push into existing structure?
- Or could go the other way, too
- Key change would be to change the API on AP_OSD_Backend to provide not just strings but token/value pairs
- backend->write(x, y, false, ā%3d%cā, (int)u_scale(TEMPERATURE, esc_temp), u_icon(TEMPERATURE));
- Becomes
- backend->write(x, y, false, OSD_TEMPERATURE, esc_temp, ā%3d%cā, (int)u_scale(TEMPERATURE, esc_temp), u_icon(TEMPERATURE));
- Or a second call:
- backend->set_value(OSD_TEMPERATURE, esc_temp); with a matching backend->set_value_string(OSD_MSG, mymsg);
- Scrolling would be messy
- Might work for flightmode
- Would we need a thread for msp in this case?
- Potentially the MSP could run on the OSD thread
- Could also look at having a register-token-at-position-with-format method
- Alternatively:
- backend->set_value(OSD_TEMPERATURE, x, y, esc_temp);
- Using the same parameters would be great as MissionPlannerās interface could be used for both
- OSD via CAN?
- Would need to include AP_OSD on all boards
- Just exclude the SPI backends?
- Composite values?
- Home-distance-and-direction?
- Two set- calls
- backend->set_value(OSD_HOME_DIST, x, y, home_dist);
- backend->set_value(OSD_HOME_DIR, x, y, home_dir);
- What about Separate coordinates?
- Would need separate elements for them
- Call set_defaut on the parameter on the MSP backend init function to turn them on
- We should look at getting a set of goggles for Alex
- Flow code needs looking through
- Flow and quality, no gyro data
- Use the timing-jitter-removal-code
- receive_time_constraint_micros
UTC1100 - https://github.com/ArduPilot/ardupilot/pull/14777
- Allow RC channel option be read by scripting
- Get switch position rather than PWM
- Also designates a switch for scripting
- Directory in AP_Scripting for lua applets
- E.g. smartaudio
- Complete and seems to be working for power changes
- Needs to know which channel is used for power changes
- Multiple scripts with one script?
- Parameters would be required to resolve this collision
- Parameters are trickyā¦
- Some method to associate parameters with a script
- Associate an ID with a script
- This PR does a static castā¦
- Should we just always static-cast things that are returned?
- Could potentially shoot yourself in the footā¦
- Changing binding could lead to subtle bugs
- Simpleā¦.
- All generator edits will be revertedā¦.
UTC1140 - https://github.com/ArduPilot/ardupilot/pull/14798
- Simple fix on last weekās PR
- Merged!
- Trusting Andy on this oneā¦
UTC1150 - https://github.com/ArduPilot/ardupilot/pull/14804
- Nice cleanup
- One small change from Randy to make then it can be merged
UTC1153 - https://github.com/ArduPilot/ardupilot/pull/14803
- A FYI ATM
- Chane between different sources based on a switch
- GPS -> ExternalNav -> GPS
- Randy flew underneath a metal roof, switch to external nav, then flew back out again and moved to GPS again
- Two banks of sources
- Proxy and posxy2
- Switch allows you to move from one to the other
- Only for EKF3 at this point
- Randy would like more testers for this PR!
- This already adds value
- What more should we add to this before merge?
- May help us move towards more EKF code cleanups
- Particularly yaw handling
- This is changing the defaults for some things?
- Velocity-z now defaulting to baro?
- EKF magic values need to die
- How will this work with the affinity PR?
- GPS affinity can still be happening
- This is just use-gps-for-fusion
- isfusionmodegps==3 now calls new class and asks for get-pos-source
- Array of two AP_Int8 parameters rather than two separately-named
- Resets are handled
- E.g. T265 has own yaw source
- Resets position and heading when switching
- Controllers are aware of this and jump their targets
- No twitches except for in altitude
- We need to notify the z controllers
- Only tested in loiter for the time being
- Bugs are probably in the yaw area
- Some strange slewing happening when resetting to GPS
- Parameter conversion still needs to be done
- Using gps for alt is quite common
- We now differentiate the different position sources a lot more
- E.g. beacon vs external nav
- Notionally allows velocity to come from one source and position from another?
- Data tends to come in lumps, so this might not work ATM
- There are options to indicate whatās fused
- Probably nobody is testing fusing gps position but not velocity
- Maybe dump velocity for fusing one or the other
- Just have one parameter
- Could possibly get position from GPS and velocity from flow?
- Magcal parameter has been abused to also specify yaw source
- This will allow us to say, āwe want to get yaw from gpsā or gsf or external navā¦
- Start to run all autotests on EKF3
- Currently only 1MB boards default to 3
UTC0018 - https://github.com/ArduPilot/ardupilot/pull/14787
- User-accessible script parameters?
- Interim method until we can do parameters properly?
- Could use SD card instead?
- Donāt include scripting if you donāt have an SD card ATMā¦.
- Tridge might not get to doing things properly for quite some time
- Fix it up before a stable release
- āThings can change in masterā
- This would remove the pressure to do it properly, āthough?
- 2 parameters rather than 4?
- Scripts get reference to a parameter?
- Tridge thinks this should go in as-is
- Reimplement as array, rename then can be merged
UTC0031 - https://github.com/ArduPilot/ardupilot/pull/14742
- Will solve a problem with T265
- Putting the option in uartdriver is not nice
- Separate bits for send/receive?
- Needs to wait for Solo testing
- Separate PR to allow setting of private or not in parameters so you can modify gimbal params
URC0040 - https://github.com/ArduPilot/ardupilot/pull/14681
- On approach choose between speed and descent methods
- No way to move between progressive and full crow
- Set it up so on a switch you can move between no, progressive and crow
- Progressive by setting the bit or setting the switch up
- Need to fix the dspoiler thing
- Can be merged after dspoiler fix
- More testing
UTC0047 - https://github.com/ArduPilot/ardupilot/pull/14671
- We previously asked, āWhat flight modes does this apply to?ā
- Auto / Landing?
- Should be correct now
- Do we want this on in fbwa?
- Manual mode?
- Qstab -> manual should stop the vertical motors immediately
- Qhover does support throttle suppression
- Donāt want to go to spin-min or stabilize, which would be bad?
- How does this work in Copter?
- Arm in althold with zero throttle, does it stabilize instantly?
- Airmode only affects manual-throttle modes
- is_vtol_manual_throttle() on the flightmode
- Fbwa is effectively althold vertically but manual throttle
- No behaviour change if we donāt have a strong reason to do so
UTC0101 - https://github.com/ArduPilot/ardupilot/issues/14460
- Mission restart fix is in
- Vtol auto missions were broken
- Not setting a horizontal speed
- Auto transition to landing would have a left-over setting and things would work there
- Still waiting on compass fix from Sid
- https://github.com/ArduPilot/ardupilot/pull/14776
- MO thinks this is OK
- Doing it at end of compass cal?
- Is that a good place to do it?
- End of compass cal means that if your 3rd compass was excluded because you swapped out a compass then it wonāt do that third compass
- Wonāt fix things for the third compass
- Thereās a āremove missingā button now in MP
UC0103 - not much to mention for Copter-4.0.4
UTC0106 - not much to mention for Rover
UTC0109 - close
