CraigElder
(Craig Elder)
January 25, 2021, 10:52pm
1
Issues & Pull Requests
ArduPilot:master
← khancyr:rover_niti
opened 01:33PM - 25 Jan 21 UTC
ArduPilot:master
← WillyZehnder:ReserveAUX_FUNC
opened 11:09AM - 24 Jan 21 UTC
ArduPilot:master
← tridge:pr-regcheck-double
opened 09:08PM - 22 Jan 21 UTC
ArduPilot:master
← peterbarker:pr/ground-course
opened 10:23PM - 21 Jan 21 UTC
ArduPilot:master
← tridge:pr-imu-tcal2
opened 08:17PM - 21 Jan 21 UTC
ArduPilot:master
← tridge:pr-param-delay
opened 10:46AM - 21 Jan 21 UTC
ArduPilot:master
← rmackay9:ekf-arming-no-gps
opened 06:53AM - 21 Jan 21 UTC
ArduPilot:master
← peterbarker:pr/plane-disallow-modechange
opened 01:58AM - 21 Jan 21 UTC
ArduPilot:master
← IamPete1:scrinpting_matrix
opened 07:39PM - 02 Nov 20 UTC
ArduPilot:master
← tridge:pr-plane-gcs-failsafe-land
opened 05:38AM - 17 Feb 20 UTC
ArduPilot:master
← amilcarlucas:pr-upstream-20210120-1
opened 11:41AM - 20 Jan 21 UTC
Plane
opened 10:30PM - 27 May 20 UTC
This is to track issues found in the plane 4.0 release.
Release discussion: https://discuss.ardupilot.org/t/plane-4-0-release/47188
Issues for 4.0.6beta2:
fly for at least 10s on...
DevCallTopic
Plane
Copter
opened 10:33PM - 12 Oct 19 UTC
This is a list of issues discovered during Copter-4.0 testing:
Common support problems:
users can't figure out which barometer is being used...
Copter
DevCallTopic
Rover
opened 05:28AM - 07 Oct 19 UTC
This is a list of bugs and features that have been reported as part of Rover's 4.0 beta testing (category on...
DevCallTopic
Rover
CraigElder
(Craig Elder)
January 26, 2021, 12:50am
2
Attendee count (max): 16
UTC2300 https://github.com/ArduPilot/ardupilot/pull/16432
Rover: disable switching and arming in INITIALIZING mode #16432
Need to prevent changing into Initialize from any other mode
Have an Initialize mode for all vehicle
UTC 2313
:https://github.com/ArduPilot/ardupilot/pull/16427
Reserve aux function to help WillyZehnder keep his relative mission branch re-based. Merged.
UTC 2315
ArduPilot:master
hoping to get a review from peter or sid, who aren’t here today.
UTC 2319
ArduPilot:master
ground_course_cd() * 0.01f == ground_course(), might as well simplify
Merged
UTC 2322
ArduPilot:master
UTC 2337 https://github.com/ArduPilot/ardupilot/pull/16406
Correcting an error where downloading params could cause the loop rate to slow because of disabled params
merged
UTC 2344 https://github.com/ArduPilot/ardupilot/pull/16399
This resolves issue: #16017
Merged
UTC 2347 https://github.com/ArduPilot/ardupilot/pull/16391
UTC 2348 https://github.com/ArduPilot/ardupilot/pull/15708
Custom frames are possible using this
Pending review
Wiki needed
UTC 0005 https://github.com/ArduPilot/ardupilot/pull/13590
definitely an improvement, but there are corner cases
its old, so at this point merging it is better than not merging it.
UTC 0018 https://github.com/ArduPilot/ardupilot/pull/16360
More testing and a wiki update required
UTC 0022 https://github.com/ArduPilot/mavlink/pull/191
trivial upstream sync
merged
UTC 0024 https://github.com/ArduPilot/ardupilot/pull/16433
do u want yaw control to be earth-frame or body-frame,? choosing between these should be easy for a user to do, such as rc switch. both are perfectly valid choices, even in the same flight. typically fpv want body-frame, and everyone else wants the other one.
discussion, no resolution yet.
needs more info from the original requester for their specific scenario.
UTC 0031 https://github.com/ArduPilot/ardupilot/issues/14460
minor plane release due later today.
UTC 0032 https://github.com/ArduPilot/ardupilot/issues/12547
bill geyer - new minor release of 4.0.6 copter just done today.
UTC 0038 - https://github.com/ArduPilot/ardupilot/issues/12509
rover close to a 4.1 beta test
UTC 0043 - other stuff from randy
spline curve update from leonard - nearly there.
rishab’s 3d avoidance with a 3d camera is also progressing, includes ‘backing up’ and ground detection via point cloud.
UTC 0045 …off the floor?:
henry - pwm / pinno / hwdef / param issue 0 vs 1 indexing of relay controls.
