Dev Call Jan 2, 2023
Issues & Pull Requests
Attendee count (max): 14
UTC2300 - add Pixhawk firmware loading info by Hwurzburg · Pull Request #4847 · ArduPilot/ardupilot_wiki · GitHub
  • Add firmware loading info
  • First attempt at fixing generic instructions on flashing boards
  • Some clones may only be seeing one IMU when there are actually two?
  • There’s the MS5607 vs MS5611 issue which we could explicitly mention
  • [10:04 AM]Peter Hall: I think the warning should be a little scary.
  • [10:04 AM]Peter Hall: Its basically lucky dip…
  • [10:04 AM]Peter Barker: I most object to “vague”
  • [10:04 AM]Peter Barker: FUD etc
  • These boards might be the very cause of large number of fmuv2 downloads we see
  • Tridge has 2 of these boards on the way and will be able to see what current dodgy clones look like
  • As far as we know there’s no genuine Pixhawk1 being produced (i.e. licensed to use the trademark)
UTC2308 - Development: update airspeed message by IamPete1 · Pull Request #296 · ArduPilot/mavlink · GitHub
  • Update airspeed message
  • Already upstream
  • Merged!
UTC2310 - common.xml: add fuel_pressure ext. to EFI_STATUS by robertlong13 · Pull Request #297 · ArduPilot/mavlink · GitHub
  • Fuel pressure extension
  • Merged
  • We’ll get robertlong12 to PR upstream
UTC2312 - AP_Airspeed: move to per-instance params by IamPete1 · Pull Request #22297 · ArduPilot/ardupilot · GitHub
  • Per-instance params for airspeed
  • Doesn’t change existing parameters
  • Param conversion works
  • synthetic/media/three-real sensors coming
  • Continuous probing?
    • Strange doing that on Periph…
  • Merged!
UTC2318 - AP_Scripting: system for switching to alternative versions of lua scripts by tridge · Pull Request #22438 · ArduPilot/ardupilot · GitHub
  • System for switching to alternative versions of lua scripts using an RC switch
  • OS bindings are smaller than using the generated bindings
  • Need to warn the switch will reload all scripts….
UTC2321 - AP_HAL_SITL: add option to create uart connection to file by peterbarker · Pull Request #22479 · ArduPilot/ardupilot · GitHub
  • Add option to create uart connection to file
  • Need to update the in-code documentation a little first
UTC2325 - Plane: Events: combine failsafe event prints by IamPete1 · Pull Request #22480 · ArduPilot/ardupilot · GitHub
  • Combine failsafe event prints
  • Merged
  • Fewer lines of output when a failsafe happens
UTC2325 - Rename HAL_INS_ENABLED to AP_INERTIALSENSOR_ENABLED by peterbarker · Pull Request #22481 · ArduPilot/ardupilot · GitHub
  • Rename HAL_INS_ENABLED to AP_INERTIALSENSOR_ENABLED
  • Merged!
UTC2328 - Plane: Update Q_OPTIONS metadata to new format by Hwurzburg · Pull Request #22483 · ArduPilot/ardupilot · GitHub
  • Update the Q_OPTIONS metadata to move stuff into the checkbox dialogue
  • Metadata can take a long time to come into MissionPlanner
  • Merged!
  • Henry and Peter will work together to use more of these
UTC2330 - AP_ExternalAHRS: add support for VectorNAV 100 by IamPete1 · Pull Request #22488 · ArduPilot/ardupilot · GitHub
  • Add support for VectorNAV100
  • Tridge tested it on our existing supported device
  • Merged!
UTC2332 - Plane: glide slope switch to per mode method by IamPete1 · Pull Request #22491 · ArduPilot/ardupilot · GitHub
  • Glide-mode-switch to per-mode-method
  • Const uint32_t mode_options for some of this stuff?
    • Could save a chunk of flash
  • Maybe try a set of option bits later
  • Peter will have a play with another similar change to see how well the bitmask works
UTC2343 - AP_Scripting: bindings: logger: support more formats by IamPete1 · Pull Request #22504 · ArduPilot/ardupilot · GitHub
  • Add support for more logger formats
  • So you don’t have to encode in one of existing almost-suitable format
UTC2344 - AP_Terrain: only include GCS_MAVLink if terrain is enabled by peterbarker · Pull Request #22518 · ArduPilot/ardupilot · GitHub
  • Don’t include headers in terrain unnecessarily
  • Merged!
UTC2347 - AP_Declination: update magnetic field tables by tridge · Pull Request #22520 · ArduPilot/ardupilot · GitHub
  • Update world magnetic model table data
  • Generating these isn’t trivial
    • The underlying generation is fortran….
    • There’s a pure-python implementation which tridge isn’t using for this yet
  • Knowing which tables are in use might be useful in analysis?
    • We do use the tables in-flight….
    • Can work it out from git hashes if really required
  • 10:50 AM]Peter Hall: Could we save much flash by including smaller areas?
  • Test data changed?
    • Bilinear interpolation bug-finding needs the data
  • Problem with ublox
    • Rtk fixes different between rtk and unicore?!
    • Different datum
    • uBlox uses world model above sea level on a 10-degree grid
    • Both use wgs-84 model
    • ArduPilot uses amsl
    • Eg96 vs eg2000-and-something model
    • Models are within cm
    • uBlox saves flash space by not having all parameters of the model but having 10-degree granularity
      • Those are degrees of lat/lng - so massive!
      • Using two GPSs, one uBlox, one unicore? 7 metre change in height, even if you have an RTK fix on both!
      • 4 partners looking at introducing Unicore
        • One-of-each would be bad if using RTK
  • Need to find a better way of using wsg geoid
  • This moves to model 13 from 12
  • Merged!
UTC0002 - AP_Scripting: rename TRIK to TRIKR for sport_aerobatics by Hwurzburg · Pull Request #22521 · ArduPilot/ardupilot · GitHub
  • Rename TRIK to TRIKR in aerobatics scripting
  • Merged!
UTC0003 - AP_Arming: only require AP_RALLY_ENABLED if MIS_ITEM_CHECK_RALLY by peterbarker · Pull Request #22523 · ArduPilot/ardupilot · GitHub
  • Arming check fix when rally enabled/not enabled
  • Merged!
UTC0005 - param_parse.py: understand @CopyFieldsFrom by peterbarker · Pull Request #22530 · ArduPilot/ardupilot · GitHub
  • param_parse.py: understand @CopyFieldsFrom
  • Merged
UTC0008 - AP_Param: allow class specific defaults using pointer diff. by IamPete1 · Pull Request #22531 · ArduPilot/ardupilot · GitHub
  • Class-specific defaults using pointer-diff
  • Stops using defaults linked list, uses poiter arithmetic to save flash
  • No more set-and-default calls
  • New AP_GROUPINFO_FLAGS_DEFAULT_POINTER macro
  • Actually costing us bytes?
    • Should save a bunch of memory
  • This is scary code with pointer-diff
    • But it’s AP_Param, so fits right in
  • Will allow for OSD param defaults to work a lot better as they’d be too expensive right now
  • Probably the right approach
  • A comment would be worthwhile
  • Manual code review for codepaths setting the default when flag isn’t set
UTC0016 - AIRLink hwdef: added heater parameters by aviaks · Pull Request #22534 · ArduPilot/ardupilot · GitHub
  • Add heater parameters to airlink hwdef
  • Tridge wants to know these are correct for the board
  • Copy-and-pasted from another board
  • Don’t want oscillation
UTC0019 - Remove erratic logging of first home position into CMD log by peterbarker · Pull Request #22546 · ArduPilot/ardupilot · GitHub
  • Removes weird logging of home location
  • Merged!
UTC0022 - AP_Scripting: Update readmes for aerobatics by Hwurzburg · Pull Request #22536 · ArduPilot/ardupilot · GitHub
  • Update scripted aerobatics comments based on extensive discussions
  • Merged
UTC0023 - AP_Logger: create and use AP_Logger_config.h by peterbarker · Pull Request #22548 · ArduPilot/ardupilot · GitHub
  • Make an AP_Logger_config.h
  • Merged!
UTC0024 - MAVLink: send FTP replies from within the FTP thread by tridge · Pull Request #22552 · ArduPilot/ardupilot · GitHub
UTC0038 - AP_HAL_ChibiOS: minimize Mamba405-2022 by peterbarker · Pull Request #22553 · ArduPilot/ardupilot · GitHub
  • Minimize the F405-2022 build
  • Merged!
UTC0039 - Plane update
  • 4.3.3 update with CubeOrange IMU FIFO reset change, perhaps
  • Need to consider the bandwidth parameter download fix
  • Nothing exciting happening
  • Need to consider when 4.4 starts
UTC0040 - Copter and Rover update
  • 4.3.2 is out
  • 4.3.3 needs to gout with stuff from Leonard
    • The dt change will be included
      • Flight performance fix
    • No decision on when this beta will start
      • A longer beta because of the dt change
      • Andy’s asked for several things to come back
    • A bunch of issues did get resolved
      • Much shorter issue list now
  • Surface tracking oscillations with one of the lidars?
    • Nothing new
    • Second-order complementary filter?
    • Use sensor directly?
    • interpolate/add on velocity stuff?
    • Use AHRS HAGL rather than rangefinder for surface tracking?
    • Hedge-hopping?
      • Noise vs signal
    • Change in behaviour?
      • The rangefinder-gain stuff went away which might have caused issues
UTC0051 - welcome to Ryan
  • New DevTeam member
UTC0051 - conference update
  • Get room bookings done!
  • Make surrey ou ask about parking if you are going to hire a car
    • Use scooters or Uber instead?
UTC0051 - off the floor
  • Note APD issues in here:
  • Hopefully APD will blog about it soon
  • More likely to happen on big quadplanes
    • Longer wiring / bigger caps etc
    • Anti-spark connectors more common on big-S battery setups
  • Is this visible enough?
    • Do they have a page?
      • Not yet for their existing dshot/pwm stuff
      • but will when they get their CAN stuff out
    • There’s a couple-of-line-notes on their documentation….
  • Should we emit a safety bulletin?
    • This isn’t a bug in the ArduPilot firmware, so probably not appropriate
  • If you are using APD ESCS - read and understand that wiki page!
UTC0056 - close
