CraigElder
(Craig Elder)
1
Issues & Pull Requests
Remote ID
Plane
Copter
Rover
CraigElder
(Craig Elder)
2
Attendee count (max): 18
UTC1100 - https://github.com/ArduPilot/ardupilot/pull/16360
- Allows arming checks to pass with no baro
- Allows DCM to work without baro (uses GPS)
- No separate DCM parameters
- Want some extra parameters to specify fallback AHRS
- What does the EKF
- Randy has concerns about supporting no-baro boards
- Define in hwdef to say fly with no baro
- Speedybf4 and mambof405v2 have this set
UTC1120 - https://github.com/ArduPilot/ardupilot/pull/16347
- Treat negative current as zero in flightaxis
- If we want to support generators we could revisit this
- Merged
UTC1122 - https://github.com/ArduPilot/ardupilot/pull/16342
- Persists logging for a while after a transition
- Corrects q logging for tailsitters
- Merged
UTC1124 - https://github.com/ArduPilot/ardupilot/pull/16341
- Constrain value line numbers on all boards
- Worth the extra cost
- Merged
UTC1124 - https://github.com/ArduPilot/ardupilot/pull/16335
- Kakutef7 not building because EK3 is bigger than EK2
- … it is built as part of CI, so it does build there ATM
- Need to get EKF3 smaller rather than regressing to EKF2
- Ifdefs around wheel odometry for example
UTC1130 - https://github.com/ArduPilot/ardupilot/pull/16332
- Pruning defaults out
- Merged
UTC1134 - https://github.com/ArduPilot/ardupilot/pull/16329
- Support SIM_STATE AND SIMSTATE
- Intermediate step, perhaps to using better common message with int32_t lat/lng
- Merged
UTC1141 - https://github.com/ArduPilot/ardupilot/pull/16318
- New linux target to support sensorless boards
- Try to get get Lucas to look at it
UTC1145 - https://github.com/ArduPilot/ardupilot/pull/16294
- Forward transition from initial pitch rather than zero
- Will smoothly transition from backwards-leaning in q to forward flight rather than snapping
- Merged
UTC1147 - https://github.com/ArduPilot/ardupilot/pull/16292
- Quadplane windvaning options
- Allow hovering wing-into-wind
- Want to see real-world flights
- Goes to closest side
UTC1150 - https://github.com/ArduPilot/ardupilot/pull/16262
- Some review has been done but no full review
- Temperature calibration of accels/gyros and persistently store them
- Stored in same sectors as bootloader
- Uses 10kB of flash on those boards that implement it
- Fancy bootloader-based parameter storage only available on F7 and H7
- Saves a kB on F4 boards due to fixes in optimisations
- Factory-calibrated accels and gyros…
- Hex have temperature-chamber logs they may be able to spew parameters out for
- Built-in-learning too
- Set a parameter on a cold vehicle, but until it is hot
- EKF to query IMU about whether it is temperature-calibrated
- Can change its weighting on allowable gyro drift and current IMU temperatures
- Improvement?
- 5x or 10x reduction in drift
- This time next year hopefully the premium boards will come pre-calibrated from the factory
- Might look at doing a linear extrapolation rather than flatline out side of calibrated range
- AP_Periph-based IMUs would report clean data into the autopilot
- Doesn’t currently do that for baro
- Need a 5th-order-polygon for baros
- Need a constant-pressure environment to calibrate a baro…
- Filtering fixes
- We’ll probably eliminate the existing tcal library and replace it with something like this
- Don’t need to recalibrate after this
- Record temperature calibrated at
- Plane dead-reckoning will get a lot better
- Clockwork getting complaints from users about drift as winter hits
- Put vehicle outside. Wait. Bring vehicle in. Turn on.
UTC0013 - https://github.com/ArduPilot/ardupilot/pull/15717
- Initial impression from MdB is good
- Merged!
UTC0018 - https://github.com/ArduPilot/ardupilot/pull/14636
- Merged
- Maxbotix understand addr field
UTC0020 - https://github.com/ArduPilot/ardupilot/pull/14265
- Can be merged after flight testing and valgrinding
UTC0023 - https://github.com/ArduPilot/pymavlink/issues/243
UTC0031 - Remote ID
- Software definable read-only option for telemetry port
- Can only send, not receive
- Some sort of “passive” bit
- Don’t obey commands from this port
- Still forward/log etc etc
UTC0045 Plane Update
- Coordinating a release with copter
UTC0047 Copter Update
- Working towards a point release later this week
UTC0050 Rover Update
