Issues & Pull Requests
Plane
- Plane 3.9.5 Beta
Copter
- Copter 3.6.5 Beta
Rover
- Rover Beta Testing
Funding Committee Update
Plane
Copter
Rover
Attendee count (max): 24
Pre-Agenda:
UTC1102 - https://github.com/ArduPilot/ardupilot/pull/10233
Merged!
Some discussion of sensor failure loop
UTC1111 - spool-up work
Brings heli and multi closer together
Zero feedback on reviews so far
Mostly Bill Geyer’s work
Another 24 hours then it can go in
Should be run under Valgrind
UTC1113 - https://github.com/ArduPilot/ardupilot/pull/10212
Collapse location
Will be merged within 24 hours
UTC1115 - https://github.com/ArduPilot/ardupilot/pull/10133
Add differential thrust like you get on normal planes to tilt rotors
Changes motors matrix to add new API
Tridge has tried to avoid changing the API
But this one doesn’t require Copter changes
Get-roll-factor?
Borrowed from matrix to calculate scaling of differential thrust
UTC1117 - https://github.com/ArduPilot/ardupilot/pull/10070
Normal flight should carry on, just quadmotors stop
String prefix needs fixing
Could possibly disable motors in an easier way
If you’re in a q-state this could be weird if it doesn’t stop the forward motor
Should allow mode change too
Should this be moved into the global RC_Channel library?
We have a spinny-thing function in srv_channel
https://github.com/ardupilot/ardupilot/blob/master/libraries/SRV_Channel/SRV_Channel.cpp#L185 is really insufficient for this purpose
Booster motors
Need a proper “spinny things” function
Making this general into the future would be good, but making or cover all vehicle types in the future would be great
UTC1130 - https://github.com/ArduPilot/ardupilot/pull/9858
It still needs Randy or Leonard to look at it
Comment added
UTC1131 - https://github.com/ArduPilot/ardupilot/issues/9498
rc1 is the current rc
https://discuss.ardupilot.org/t/copter-3-6-5-rc1-available-for-beta-testing
Thanks to tridge for the sd-card fix!
Bebop2 fix
Rc protocol decoding fix
Aux switch / frsky fix
Dsm receiver fix
Corruption in stream from dsmx receiver would drop things down to 7 channels and 8 would become 0 in log
Need to rebuild the IO firmware
https://github.com/ArduPilot/ardupilot/pull/10222
Few more things came up
Flowhold mode vehicle wobbles when vehicle gets really high
Probably expected based on bad height estimate
Wobbling gives it more information on height
[10:37 AM] (Channel) JP: 20m alt on that sensor isn’t something one should complain about…
Bad scaling would also explain it
Let’s not give up on >20m just yet
oneshot 125 not working on NavIO2
Naming issues on one board…
UTC1140 - Rover and Randy
MP updates required for aux switches
Parameter load time
3.5rc2 later this week?
UTC1142 - https://github.com/ArduPilot/ardupilot/pull/8816
Rangefinder parameters
User is continuing to rebase - thanks!
Parameter copying-across needs testing
UTC1143 - https://github.com/ArduPilot/ardupilot/pull/10119
Removing some redundant resets and constraining
Style difference?
Merged!
UTC1145 - https://github.com/ArduPilot/ardupilot/pull/10108#event-2042712945
Peter’s concern is GCSs that don’t look for the nak
Qgc doesn’t do partial uploads
Should allow it to extend
MP does use partial list
[10:50 AM] (Channel) JP: There’s a bunch of gcs potentially affected - ie ugcs, etc
Statustext is going back in
MdB will send something to the GCS mailing list notifying them statustext is going away
[10:55 AM] (Channel) JW: I asked Kelly if he is using partial mission upload in Solex… he replied, “What are partial mission uploads” … so that’s cool.
UTC1151 - Plane 3.9.5 out shortly
Leonard found some important things
VTOL takeoff in quadplanes was honouring lat/lon in mission item
Subtle bug in ekf yaw resets
Mag anomalies
Handled it slightly too late in loop so it didn’t have any effect
Added better battery simulation for quadplanes
Trying to track Copter releases
UTC1154 - no onion work
Really just needed a little bit of cleanup
Tridge is happy with the general structure
UTC1158 - Rover
Jaime’s doing interesting work on non-GPS
… and ICE engine support
Avoidance stuff coming to Rover
E.g. the canberrauav stuff
Need to make sure it will scale down to Rover distances
Some constants will need changing
Existing dodge stuff is not sufficient and can’t be sufficient
Some equivalent to Rover CRUISE mode would allow it to work in a manual-ish mode
Randy’s worked on set-message-interval in ROS
UTC0008 - Self nominations for funding committee
Francisco, Tom, James, Jaime, Philip
Thanks to those who nominated!
Vote will go up after meeting
UTC0009 - Jani and Shenzhen
List of names who would participate in Shenzhen event
Let Jani know if you’re interested in attending/talking
End of month
Promotions after end of next month
Want to grow the event!
UTC0012 - CANBUS peripheral code
Can attach any i2c code to a CAN node and it becomes available in ArduPilot
Can discover buses
https://github.com/tridge/ardupilot/tree/AP-Periph/libraries/AP_UAVCAN/dsdl/ardupilot/bus
No plans for SPI ATM
High-rate is problematic over CAN
1ms round-trip
OSD, potentially?
[11:15 AM] (Channel) JP: Are you aware that Pavel is releasing a breaking update for uavcan shortly: will probably need a separate implementation
Tao vs bzero?
Uavcan1.0
[11:17 AM] (Channel) iampete: would be nice to use a cheap ‘beta flight’ board as a can extender for a cube
These nodes are smaller and possibly cheaper
F103 128k versions possibly cheaper than the 64k ATM
They should be drop-in replacements
Pretty tight ATM
Bootloader takes a chunk of space
8kB for tridge’s
Probably 16kB by the time CAN is in there
UTC0016 - Funding committee update
expenses in last month or so
Unconference
Three applications for sponsorship for members
GSoC student also approved
Nominations?
want to wrap up Proposals before new funding committee comes out
Want to give a snapshot before dumping on new committee
Randy would like to see more regular updates from the committee
Great Summer in terms of sign-ups
Tailed off a bit as it got colder
Another couple coming in, ‘though
