Dev Call Dec 3 2018 2300 UTC
Issues & Pull Requests
Non GPS Navigation
Plane
  • Update
Copter
  • Update
Rover
  • Update
Attendee count (max): 21
UTC2304 - https://github.com/ArduPilot/ardupilot/issues/9935
  • Adding Solo targets to the build
  • Why two builds?
    • Can’t we differentiate them?
    • We can but the default parameters are different
      • Why can’t we differentiate based on IMU sensors at runtime?
    • Possibly use the .apj stuff instead?
      • Just take the Cube target and add extra parameters
      • This would be ideal - just use apjtool to tack things on
    • We do stuff in tailsitter code based on stuff at runtime, can’t we do the same thing here?
    • No way to detect the difference between the Cubes?
      • Have to ask the user
      • No, you can make an educated guess
        • But then you’d have to be able to force compatible behaviour in the case the user has replaced their Cube
  • Use frame params directory?
  • Solo and Solo-black rather than Solo-Green and Solo-Black?
  • MdB: Solo Solo-Green is a lot clearer IMO
UTC2325 - https://github.com/ArduPilot/ardupilot/pull/9913
  • More rangefinders?
  • Would be a lot of parameters…
    • Parameter download time!
      • Used to be wonderfully fast….
    • Enable parameters!
      • Sounds like a good idea…
      • Do we hold the PR?
        • No
        • Ask for a rebase?
          • Maybe just rebase it ourselves…
          • Randy will have a peek at this
UTC2329 - https://github.com/ArduPilot/ardupilot/pull/9844
  • Requested changes from last week have been done
  • Works better with ccw than master and previous version
  • Needs tridge or Tom to look at it
  • Flown on NuttX or ChibiOS?
    • NuttX
  • Negatives?
    • Amusing things happen if you give the L1 a negative radius…
UTC2332 - https://github.com/ArduPilot/ardupilot/pull/9633
  • Randy’s not against having an initialising mode
  • Mavlink message definitions
  • MdB uses initialising mode to reset timers and the like on Plane
    • Seems to be quite reliable
  • Randy will review
UTC2335 - https://github.com/ArduPilot/ardupilot/pull/7234
  • Works great in SITL
  • Issue with testing on FMUv3, another day or so hopefully will lead to fix
  • Later we will move to separate thread, sleep/wake up. Better, more efficient solution compared to current implementation that checks at 400hz all the time.
  • MdB: Would be nice for most GCS usage :slight_smile:
  • [10:41 AM] (Channel) MdB: Only get data you care about…
UTC2341 - non-GPS nav
  • Changes to ROS required for it to send the set-message-interval command
  • Mario and friends have been having a good amount of luck with Cartographer
UTC2344 - new flow sensor
  • 40m was holding position
    • Probably limit
  • Setting Ek2_flow-delay low seemed to screw up the EKF2 badly
    • As in crashing vehicle due to wild velocity estimates
    • [10:46 AM] To Weekly devcall: We have GPS position vs ahrs position prearm checks.
    • [10:46 AM] To Weekly devcall: We could add velocity check as well
UTC2346 - Plane update (without tridge!)
  • Nate’s been testing the new IO firmware
  • MdB thinks Planes are awesome and Copters are not
UTC2347 - https://github.com/ArduPilot/ardupilot/issues/9498
  • New rc
  • Will definitely be a 3.6.4
    • Bad logging message
      • Tridge’s hardware made the problem go away for him so unable to replicate with a logic analyser still
      • Tridge added some retries into ChibiOS
    • Terrain database and LIDAR fixes too
UTC2351 - Rover 3.5 beta testing
  • Rc1 has been out for a few weeks
  • One bug found yesterday to do with entering auto if you have no mission
  • Copter 3.6 release takes a lot of time away
UTC2353 - no more responses to the funding for conference thing during the meeting
  • Can’t chat with James about this due to bad connection
  • [10:56 AM] (Channel) JamesPattison: Vote for funding a community member to attend unconference looks pretty split (50/50)
  • [10:57 AM] (Channel) JamesPattison: Minimise (case by case) is leading for dev attendance subsidising
  • [10:58 AM] (Channel) JamesPattison: Only 17 votes
UTC2355 - new SITL merged!
  • Morse
  • 3D simulator
  • Based on Blender
UTC2358 - nominations for contribution of the month encouraged!
UTC2359 - Partner’s call tomorrow
