Attendee count (max): 19
UTC1100 - Welcome to Ari
UTC1101 - https://github.com/ArduPilot/ardupilot/pull/16121
- Streamrate parameters
- Based on number of gcs mavlink backends we have
- Default was 5
- Circling around the gcs top-level parameter object
- Single enable parameter for stream rate control?
- SR_ENABLE parameter?
- If false then we hide all the streamrates
- If true then we map 1-1 onto the serial port numbers
- optimum range on things like dragonlink requires certain stream rates so you have to stop the fiddling of rates by the GCS
- Mapping between port and rangefinder number
- We used to have separate protocol numbers for 1st gps / second gps
- For 4.1 we could change our stream rate parameters
- Persist individual message intervals via SD card?
- GCS_SR set of parameters
- GCS_SR_ENABLE
- Current PR is nice and simple and could probably go in as-is?
- Docstring stuffed
- we‘ll probably merge this as-is…
UTC1124 - https://github.com/ArduPilot/ardupilot/pull/16139
- Use PixRacer as an AP_Periph
- Needs to allocate an ID as all new board types require
UTC1128 - https://github.com/ArduPilot/ardupilot/pull/16144
- MSP_PORT parameter to disable MSP
- Avoids CAN packet loss
- Enables DMA
- Still corrupting a packet every minute or two
- Still need to chase that down
- Timeout handling on F3 is probably a bit off
- 1kHz on F3 rather than 1MHz
- Protocols in periph are different
- GPS_PORT==2 rather than using serial protocol
- Resource constraints (parameters, flash)
- Protocol to port or port to protocol?
- Number is the serial port number, not silkscreen…
- Really need Serialn_protocol_in serialn_protocol_out
- So you can use xmit and receive separately (e.g. rangefinder into AP and MSP out)
- No parameter documentation for CAN at the moment
- SITL parameters and CAN parameters…
- AP_Periph parameter set will be a separate set of XML
UTC1139 - https://github.com/ArduPilot/pymavlink/pull/322
- Mavlink2 support in CSharp
- This will break support
- Doubts others are using it
- Can merge once CI passing
UTC1142 - https://github.com/ArduPilot/ardupilot/pull/16145
- Parameter access in scripting
- Naming
- AP_Param ardupilot parameter and Parameter in scripting
- But they’re basically the same thing…
- Looking up by name is too slow
- This allows real-time fiddling
UTC1150 - https://github.com/ArduPilot/ardupilot/pull/16143
- Moving loiter and thermal our of auto fs group
- No pilot in put in loiter mode…
- Will circle forever in RC failsafe
- Continue-in-auto will not land elegantly
- This changes things on will-it-complete…
- Significant behavioural change
- Copter FS options parameter required in Plane
UTC1155 - https://github.com/ArduPilot/ardupilot/pull/16138
- Removes OwnPtr
- Tries to avoid having two subsystems having access to the same device pointer
- Instantiate, handle to device thread, no longer use it yourself
- Sometimes we do want two pointers to same device
- Mavlink devop
- Lsm303d mag + accel needs a pointer in INS and compass libraries
- We shouldn’t just merge this without more discussion
- Has this ever saved us from a problem?
- Patterns protect us rather than ownptr/uniqueptr?
UTC0005 - https://github.com/ArduPilot/ardupilot/pull/16130
- Needs flight testing
- Can be merged after it’s been put through some real flight testing
UTC0010 - https://github.com/ArduPilot/ardupilot/pull/16068
- AP_Button expand info in metadata
- Flapping CAN test
UTC0011 - https://github.com/ArduPilot/ardupilot/pull/15990
- Can be merged after we change to treat 0-0 as
UTC0019 - https://github.com/ArduPilot/ardupilot/pull/15065
- Rc channel override release fixes
- Can be merged after type fixed
UTC0022 - weird telemetry rates on 433 radio
- Reproducible so should be fixed soon…
UTC0023 - plane
- Generally happy
- Airspeed fix for a new Plane stable, perhaps…
UTC0023 - Copter
- Not too much to report on Copter
- EK3-still-initialising bug still being chased….
- Randy might try to chase it
- S-curves stuff hasn’t been chased yet
UTC0026 - Plane changes
- Min-pitch in hand-launch PR fixed
UTC0027 - EK3-source-yaw parameter split
- Waiting on Paul
- Want before 4.1 beta
UTC0028 - Copter 4.0.6rc1
- Bill and Amilcar
- Just before xmas
- Two week time period for testing…
- Facebook post was made
- Need to merge release notes to master
UTC0032 - Rover
- Same blockers as for Copter
UTC0033 - close
