Dev Call Dec 22, 2025
CI Workflow
Release Update
Issues & Pull Requests
Attendee count (max): 18
UTC 2302 ArduPilot 4.6 issues list · Issue #28612 · ArduPilot/ardupilot · GitHub
UTC 2308 Rover-4.6.2: watchdog when downloading logs · Issue #31386 · ArduPilot/ardupilot · GitHub
  • Crash Dump diagnostics
UTC 2315 Copter parameter conversion from cm, cd to m and degrees · Issue #31562 · ArduPilot/ardupilot · GitHub
  • Discussion on how to rename parameters in the wiki
  • Discussion on how to automate updates to the wiki and the code
UTC 2340 signing: Improvements to the Bootloader and Firmware Signing Process by joshanne · Pull Request #31623 · ArduPilot/ardupilot · GitHub
  • Merge on CI Pass
UTC 2347 https://github.com/ArduPilot/ardupilot/pull/31713
  • Changes requested
UTC 2352 Tools: remove -ftrapping-math as it cause SITL to crash by timtuxworth · Pull Request #31736 · ArduPilot/ardupilot · GitHub
  • Tridge to try and reproduce
UTC 2358 AP_Common: add Cortex-M-specific working setjmp implementation by tpwrules · Pull Request #31740 · ArduPilot/ardupilot · GitHub
  • Sid to review
UTC 0003 Remove concept of "fresh" from mount backends by peterbarker · Pull Request #31758 · ArduPilot/ardupilot · GitHub
  • Randy to review
UTC 0010 AP_NavEKF3: reduce FuseMagnetometer computation time 25-35% by tpwrules · Pull Request #31759 · ArduPilot/ardupilot · GitHub
  • Reduce CPU computation time
UTC 0015 Standard Modes Support problems · Issue #31761 · ArduPilot/ardupilot · GitHub
  • Change the mode names to full strings
UTC 0023 common.xml: specify that TUNE_FORMAT.tune is specifically MML by peterbarker · Pull Request #453 · ArduPilot/mavlink · GitHub
  • Need input from Hamish
