CraigElder
(Craig Elder)
1
Issues & Pull Requests
Morse Simulator
https://www.openrobots.org/morse/doc/stable/what_is_morse.html
MAVProxy
- new release,
- multicast udp support
nuttx removal
Plane
Copter
Rover
AUVSI
Canberra Conference
CraigElder
(Craig Elder)
2
Attendee count (max): 23
UTC2304 - https://github.com/ArduPilot/ardupilot/pull/9966
Should have a separate airspeed sensor
Knowing ground pressure would actually be nice
We used to send it
Moving to using the airspeed sensor recently
Airspeed2 is a named pair
Should fix this with another message?
Sensor values in tlogs
No Scaled_pressure_send in px4 firmware
We should create an airspeed message
resolution : send separate airspeed sensor data
Do we send a scaled_pressure2 if no second baro?
UTC2322 - https://github.com/ArduPilot/ardupilot/pull/9958
Add edn backend for docs
Extra pip tool required
Scope creeps:
- Fixed bitmask on Plane where it had commas in it
merged
UTC2324 - https://github.com/ArduPilot/ardupilot/pull/9956
Do-go-around
Store do-go-around in mission
Like do-land-start
E.g. continue approach along runway and follow waypoints to get clear of airspace then retry landing approach
Need to remove the warning
- After correcting the grammar
Drive-by fix related to zero vs one indexing
SITL testing works OK
Throttle abort has been moved
Currently this PR is mavlink-only
We need to do this on throttle abort
Use singleton in AP_Landing?
Quadplane stuff not present in library
Deferred so MdB and tridge can talk
UTC2333 - relative vs labelled jumps with MdB
Add jump tag to as mission item
GCS can draw appropriate lines
This is the preference from the mavlink side
Relative has the advantage of not needing to scan
- But we scan anyway for random other things
Where do we store missions?
Except in SITL - it does a pread
UTC2338 - request to get a specific Solo build
Didn’t get through this last week
Want to get builds on the autotest server
https://github.com/ArduPilot/ardupilot/pull/9932
Looks fine to tridge
merged!
Build_binaries.py will get a patch
Throttle slew rate patch is being tested by volunteers at the moment
3 or 4 testers at the moment
UTC2348 - https://github.com/ArduPilot/ardupilot/pull/9633
UTC2349 - https://github.com/ArduPilot/ardupilot/pull/9844
UTC2348 - Morse simulation stuff
UTC2352 - MAVProxy changes
Multivehicle stuff and a few other features
Set parameters on esp8266 radios separately from vehicle
Will be able to manipulate parameters on CAN devices
- So use MAVProxy to change CAN parameters rather than hw device
Should be able to manipulate Solo gimbal parameters now
UTC2358 - PR for NuttX
UTC2359 - Plane 3.9.4 went out
UTC0000 - AUVSI update
Will be getting a booth again
Hex, SpektreWorks, maybe BlurRobotics
Need to choose booth soon and finalise participant list
May be able to have an “ArduPilot-specific” section due to negotiations
UTC0000 - Copter release update
UTC0024 - Rover
UTC0016 - funding committee
- Accepting funding requests for Canberra conference
UTC0025 - Helicopter motor shutdown fixes?
Aux switch debouncing
Exitting s.bus failsafe leaves some channels at zero?
Bill separately talked with tridge
- Spektrum channel-splitting
Need an autotest
Deglitching is done specially for channel 8
Bill’s the man!
UTC0033 - longitudinal thrusters?
So not having to tilt the frame
Could this get into master?
Another library interposing?
Coming up a lot now
Vestiges in the AP_Motors top-level class
Several more p-controllers?
Open-source heli layout coming
UTC0035 - CAN for hobbyists
UTC0045 - perfect tie for contribution of the month
- Will leave open for a little while
