Dev Call Aug 31, 2026
CI Workflows
https://github.com/ArduPilot/ardupilot/actions/workflows/ci.yml
Release Update
Issues & Pull Requests
Attendee count (max): 13
UTC2300 - CI https://github.com/ArduPilot/ardupilot/actions/workflows/ci.yml
  • The race conditions in the peripheral tests appear to be solved
  • Everything was clean on a dozen PRs Peter rebased yesterday!
UTC2303 - release update
UTC2328 - tridge AI review
  • Using it more and more
  • Every 6 hours it updates the DevCallTopic and DevCallEU and AIReview
  • Many repos looked at
UTC2329 - Copter: add ground effect altitude and timeout parameters by andyp1per · Pull Request #32472 · ArduPilot/ardupilot · GitHub
  • Add ground effect and timeout parameters
  • Randy’s happy
  • AI just has nitpicks left
    • Randy wants Andy to acknowledge the AI comments before merge
      • Can be merged if Andy is happy
UTC2336 - AP_Compass: IIS2MDC calibration and correctness fixes by andyp1per · Pull Request #33780 · ArduPilot/ardupilot · GitHub
  • Enable by default
    • NDAA argument is reasonable
  • Can be merged once Jacob is happy with it
UTC2337 - RTL cleanup by lthall · Pull Request #33868 · ArduPilot/ardupilot · GitHub
  • RTL cleanup from Leonard
  • Auto position hold cleanup sequence
  • Removing discontinuities when changing modes and submodes
  • Simplifies a bunch of state machine stuff
  • Leonard would like some people to have a peek at this
UTC2342 - AP_InertialSensor: don't clear sensor health mid-cycle by andyp1per · Pull Request #33989 · ArduPilot/ardupilot · GitHub
  • ADIS fixes and stop clearing sensor health mid-cycle
  • Merged!
UTC2348 - Sitl shared memory - eg swarms, following, master-slave, virtual peripheral/s, etc by davidbuzz · Pull Request #34019 · ArduPilot/ardupilot · GitHub
  • Shared memory transfer of information between binaries
  • Breaking the lockstep schedule stuff
  • Lots of infrastructure stuff mixed into the PR
UTC0017 - AP_NavEKF3: anchor yaw while ground-learning in MAG_CAL=7 by andyp1per · Pull Request #34057 · ArduPilot/ardupilot · GitHub
  • Anchor yaw while ground learning
  • Merged
UTC0020 - RC_Channel: defer aux initialization until backends exist by Hwurzburg · Pull Request #34166 · ArduPilot/ardupilot · GitHub
  • Change the way we initialise the mount library vs the RC input
  • We’re not keen on the way this is done
  • Let’s try get_aux_cached instead
UTC0033 - Move AHRS_ORIENTATION -> BRD_ORIENTATION by peterbarker · Pull Request #34173 · ArduPilot/ardupilot · GitHub
  • Move AHRS_ORIENTATION → BRD_ORIENTATION
  • Concern this adds danger for no strong reason
    • E.g. defaults.parm has AHRS_ORIENTATION
UTC0047 - AP_Scripting: allow heap expansion while disarmed on AP_Periph by tridge · Pull Request #34183 · ArduPilot/ardupilot · GitHub
  • allow heap expansion while disarmed on AP_Periph
  • I.e. ignore SCR_HEAP_SIZE and make it arbitrarily large
  • Good to go in when the name is changed
UTC0057 - Plane: reset ALT_OFFSET on navigation changes by tridge · Pull Request #34184 · ArduPilot/ardupilot · GitHub
  • Reset altitude offset on navigation changes
  • So you change ALT_OFFSET but only has effect for a very short period
  • Now resets the alt offset on boot and on waypoint change
UTC0113 - AP_Logger: fixes for corrupt logs and poor error tracking by peterbarker · Pull Request #34187 · ArduPilot/ardupilot · GitHub
  • Fixes for corrupt logs and poor error tracking
  • Merged!
UTC0114 - AP_Terrain: do not extrapolate height above terrain from an unset value by peterbarker · Pull Request #34191 · ArduPilot/ardupilot · GitHub
  • Do not extrapolate terrain from unset value
  • Merged
UTC0134 - Plane: QuadPlane backward airspeed limit to avoid reversed tail flow by Hwurzburg · Pull Request #34202 · ArduPilot/ardupilot · GitHub
  • Quadplane backspeed limit
  • Can Henry give us a compelling case?
  • It is opt-in
  • PH to think about it
UTC0140 - Rover: remove unused parameter member and non-functional RST_SWITCH_CH by Hwurzburg · Pull Request #34214 · ArduPilot/ardupilot · GitHub
  • Remove unused parameter member and non-functional RST_SWITCH_CH
  • Merged!
UTC0141 - github.com/ArduPilot/ardupilot/pull/34215
  • Remove unused MAV_SYSTEM_ID
  • Need Sid to say OK
UTC0144 - AP_Arming: say what to do about the safety switch by Hwurzburg · Pull Request #34233 · ArduPilot/ardupilot · GitHub
  • Change text from “Safety Switch” to “Push safety switch or BRD_SAFETY_DEFLT=0”
  • Few boards actually have a safety switch now
  • Not happy with the wording / parameter name
  • Suggestions left
UTC0154 - Copter: report the full navigation setpoint on both POSITION_TARGET messages by lthall · Pull Request #34234 · ArduPilot/ardupilot · GitHub
  • Report the full navigation setpoint on both POSITION_TARGET
  • Just a heads up on this one
UTC0159 - SITL shared memory redux
  • Split out a few PRs to contain sub-work
  • Some contention around retaining proper lockstep scheduling
UTC0206 - close
