opened 05:16AM - 28 Feb 22 UTC
Copter
Rover
DevCallTopic
ReleaseAdmin
This is a list of issues discovered during Copter and Rover 4.2.0 beta testing. … For reference [Copter-4.1 issues ](https://github.com/ArduPilot/ardupilot/issues/16478), [Rover-4.1 issues](https://github.com/ArduPilot/ardupilot/issues/17116).
**Reports requiring Investigation**
- [ ] Rover 4.2.2 using NMEA RTK GPSs cannot attain position estimate (no logs sadly, no public discussion)
- [ ] Rover running slowly with full SD card but no logs ([discussion](https://discuss.ardupilot.org/t/rover-4-2-cant-go-forward-after-u-turn/89839/2))
- [ ] request for wiki docs on signing firmware ([discussion](https://discuss.ardupilot.org/t/copter-4-2-3-rc3-available-for-beta-testing/89841/14))
- [ ] Pixhawk6x issues ([discussion](https://discuss.ardupilot.org/t/copter-4-2-3-rc1-available-for-beta-testing/89506/9))
- [ ] SoloGimbal broken (also broken in 4.1.x) ([issue](https://github.com/ArduPilot/ardupilot/issues/20923))
- [ ] Missions may complete while the vehicle is disarmed ([issue](https://github.com/ArduPilot/ardupilot/issues/20655))
- [ ] UAvionix Ping disrupts param download ([discussion](https://discuss.ardupilot.org/t/copter-4-2-0-rc2-released-for-beta-testing/84818/3))
- [ ] modalAI Voxl setup problems ([issue](https://github.com/ArduPilot/ardupilot/issues/20481), [discussion](https://discuss.ardupilot.org/t/voxl-position-reference/87230))
**Copter**
- [ ] circle mode can't keep vehicle pointed at center if CIRCLE_RATE > ATC_SLEW_YAW ([issue](https://github.com/ArduPilot/ardupilot/issues/21098))
- [ ] do-change-speed doesn't work if immediately after a TAKEOFF command ([discussion](https://discuss.ardupilot.org/t/copter-4-2-x-cant-accept-do-change-speed-in-auto-mission/87509), [issue](https://github.com/ArduPilot/ardupilot/issues/21080))
- [ ] DShot BlueJay not working ([discussion](https://discuss.ardupilot.org/t/copter-4-2-0-rc4-available-for-beta-testing/85556/3)) -- fixed in 4.2.1-rc1?
- [ ] DShot LEDs not working ([issue](https://github.com/ArduPilot/ardupilot/issues/20816)) -- fixed in 4.2.1-rc1?
- [ ] AndyP's ongoing alt-hold issues ([PR](https://github.com/ArduPilot/ardupilot/pull/20781)) -- agreed not blocker for 4.2.0 release
- [ ] neopixel shows incorrect colours on some boards ([discussion](https://github.com/ArduPilot/ardupilot/issues/20768), [PR](https://github.com/ArduPilot/ardupilot/pull/20432))
- [ ] Copter set-attitude-target doesn't accept roll,pitch angles and yaw rate ([issue](https://github.com/ArduPilot/ardupilot/issues/20444))
**Rover Specific**
- none
**Enhancement Requests (may or may not be done)**
- [ ] request to update mavlink repo ([issue](https://github.com/ArduPilot/ardupilot/issues/20849), [PR](https://github.com/ArduPilot/ardupilot/pull/20927))
- [ ] CubeBlack not-enough-memory with CAN enabled ([discussion](https://discuss.ardupilot.org/t/copter-4-2-0-beta1-available-for-beta-testing/82460/19)) -- many small changes increased memory usage. Not easy to fix.
- [ ] OSD Group2 Params LINK_Q Items appear even for disabled OSD screens ([issue](https://github.com/ArduPilot/ardupilot/issues/18418), [PR](https://github.com/ArduPilot/ardupilot/pull/18533)) -- a display issue and quite difficult to fix
- [ ] [Custom Build server](https://custom.ardupilot.org/) should support building beta and stable ([discussion](https://discuss.ardupilot.org/t/rover-4-2-0-beta1-available-for-beta-testing/82462/7))
- [ ] Log fence locations ([discussion](https://discuss.ardupilot.org/t/no-polygone-fences-in-the-dataflash-logs/82566), [issue](https://github.com/ArduPilot/ardupilot/issues/20213))
- [ ] SBP (aka Swift) GPS driver should accept yaw ([discussion](https://discuss.ardupilot.org/t/how-to-force-gps-yaw-to-rovers-yaw/82553/2))
**Wiki improvement Requests**
- [ ] Improve optical flow wiki ([discussion](https://discuss.ardupilot.org/t/how-to-test-benefits-of-optical-flow-improvements/82488))
- [ ] document DO_LAND_START / AutoRTL ([discussion](https://discuss.ardupilot.org/t/suggestion-being-able-to-define-an-rtl-approach-path-i-e-approach-rtl/85470), [MP PR](https://github.com/ArduPilot/MissionPlanner/issues/2858))
**Resolved Items**
- [x] add Pixhawk1M-bdshot ([discussion](https://discuss.ardupilot.org/t/copter-4-2-3-rc3-available-for-beta-testing/89841/10), [issue](https://github.com/ArduPilot/ardupilot/issues/21504), [PR](https://github.com/ArduPilot/ardupilot/pull/21524#pullrequestreview-1083294319)) -- resolved for 4.3
- [x] BlueRobotics ping sensor not working above 4.0.0 ([discussion](https://discuss.ardupilot.org/t/blue-robotics-ping-sensor-not-working-on-anything-above-ardurover-4-0-0/88007)) -- sensor firmware needs to be upgraded, wiki has been updated to add instructions on how to do this.
- [x] climb during precision landing ([discussion](https://discuss.ardupilot.org/t/quad-rises-to-40m-before-landing/86311), [PR](https://github.com/ArduPilot/ardupilot/pull/20982)) -- not included in 4.2 because it is an existing issue. I think we will wait for 4.3 for the fix to go out.
- [x] LidarLight broken on CubeOrange, Nora (all H7?) ([issues](https://github.com/ArduPilot/ardupilot/issues/20778)) -- hardware issue
- [x] Circle mode should stop at fence ([issue](https://github.com/ArduPilot/ardupilot/issues/20939), [PR](https://github.com/ArduPilot/ardupilot/pull/20964)) -- resolved for 4.2.2-rc1
- [x] OSD not showing latest modes ([PR](https://github.com/ArduPilot/ardupilot/pull/20811)) -- resolved for 4.2.1-rc2
- [x] precision landing yawing during descent when tag lost ([discussion](https://discuss.ardupilot.org/t/fixed-yaw-precision-landing/85618/2), [PR](https://github.com/ArduPilot/ardupilot/pull/20801)) -- resolved for 4.2.1
- [x] Matek H743 has 4 IMUs so INS_ENABLE_MASK needs an extra bit? ([discussion](https://discuss.ardupilot.org/t/rover-4-2-0-rc3-released-for-beta-testing/85121), [PR](https://github.com/ArduPilot/ardupilot/pull/20793)) -- resolved for 4.2.1
- [x] CHUTE_ENABLE somehow set to zero (RC switch?) ([discussion](https://discuss.ardupilot.org/t/copter-4-2-0-rc4-available-for-beta-testing/85556/8), [issue](https://github.com/ArduPilot/ardupilot/issues/20788)) -- present in 4.1.x as well
- [x] TradHeli internal error from Guided mode ([discussion](https://discuss.ardupilot.org/t/heli-frame-prearm-internal-error-0x100000-l-602-flow-of-ctr/85172), [PR](https://github.com/ArduPilot/ardupilot/pull/20742)) -- resolved for -rc4
- [x] ATC_SLEW_YAW affects yaw speed in Loiter ([issue](https://github.com/ArduPilot/ardupilot/issues/20608), [PR](https://github.com/ArduPilot/ardupilot/pull/20758)) -- resolved for -rc4
- [x] AP_Button's internal error when using PWM input ([issue](https://github.com/ArduPilot/ardupilot/issues/20609)) -- maybe caused by servo tester used during testing -- not a real problem
- [x] Chimera EKF issues after acro flight (worse in -rc1 than -beta3). AndyPiper has logs ([PR](https://github.com/ArduPilot/ardupilot/pull/20684), [related PR](https://github.com/ArduPilot/ardupilot/pull/20431)) -- resolved in -rc3
- [x] MatekF765-Wing-bdshot requested ([discussion](https://discuss.ardupilot.org/t/rover-4-2-0-beta3-released-for-beta-testing/83623/12)) -- included in -rc2
- [x] BLHeli_S not working and "all zeros" watchdog ([discussion](https://discuss.ardupilot.org/t/spontaneous-crash-possible-problem-in-4-2bdshot-daily-build-from-feb-22/83297/16), [zeroWD issue](https://github.com/ArduPilot/ardupilot/issues/20092)) -- resolved for -rc2 (we think)
- [x] User struggles setting up wheel encoders, camera triggers, brushed-motors-with-relays due to BRD_PWM_COUNT removal ([Rover discussion](https://discuss.ardupilot.org/t/rover-4-2-0-beta3-released-for-beta-testing/83623/17), [Copter discussion](https://discuss.ardupilot.org/t/brd-pwm-count-mentioned-in-wiki-but-not-in-parameters-or-in-parameter-list-doc/84155), [Plane issue](https://github.com/ArduPilot/ardupilot/issues/20567), [PR](https://github.com/ArduPilot/ardupilot/pull/20576)) -- resolved for -rc2
- [x] MP param download 30+ seconds on Randy's CubeOrange after CAN_P1_DRIVER = 1 or BTN_ENABLE = 1 ([issue](https://github.com/ArduPilot/ardupilot/issues/20582)) -- resolved in Beta MP (build 1.3.8150.28411 or higher)
- [x] Vision Position Estimates treated as offsets from internal origin ([issue](https://github.com/ArduPilot/ardupilot/issues/20585)) -- working correctly
- [x] compass learn testing ([discussion](https://discuss.ardupilot.org/t/lane-switch-on-compass-learn-3-flight/84223), [discussion2](https://discuss.ardupilot.org/t/test-results-of-compass-learn-3/84177)) -- FYI only
- [x] DO_SET_SERVO does not work on Servo9 ~ 14 on CubeOrange ([discussion](https://discuss.ardupilot.org/t/no-pwm-servo-aux-out-1-movement-on-cube-orange/84325/2), [PR](https://github.com/ArduPilot/ardupilot/pull/20584), [PR](https://github.com/ArduPilot/ardupilot/pull/20577)) -- resolved for -rc2
- [x] RPM spams console until gpio PIN parameter is set ([issue](https://github.com/ArduPilot/ardupilot/issues/20575), [PR](https://github.com/ArduPilot/ardupilot/pull/20579)) -- resolved for -rc2
- [x] Linux crash due to UART or scheduler change? ([issue](https://github.com/ArduPilot/ardupilot/issues/20519), [PR](https://github.com/ArduPilot/ardupilot/pull/20540)) -- resolved for -rc2
- [x] Tradheli autotune not properly exiting rate P/rate D tuning when max allowed gains are not determined ([PR](https://github.com/ArduPilot/ardupilot/pull/20447)) -- resolved for -rc2
- [x] SYSID FF fix ([PR](https://github.com/ArduPilot/ardupilot/pull/20466)) -- resolved for -rc2
- [x] Rover watchdog reset on MatekH743-Mini-bdshot ([discussion](https://discuss.ardupilot.org/t/rover-4-2-0-beta3-released-for-beta-testing/83623)) -- probably resolved in -rc1
- [x] Balance bot not standing for user with brushed motors ([discussion](https://discuss.ardupilot.org/t/rover-4-2-0-beta3-released-for-beta-testing/83623/7)) -- needed to set SERVOx_FUNCTION = -1 (need better docs?)
- [x] Bi-directional dshot doesn't work on Rover ([PR](https://github.com/ArduPilot/ardupilot/pull/20374)) -- fixed in beta3
- [x] landing not slowing at LAND_ALT_LOW (Randy and PeterHall have logs) -- fixed in beta3
- [x] WP_SPEED from Ch6 tuning not working? ([discussion](https://discuss.ardupilot.org/t/wpnav-speed-as-a-chan-6-tune-parameter-working/83217)) -- vehicle config issue, works.
- [x] DSHOT reverse range is inverted (4.2 issue. see [issue](https://github.com/ArduPilot/ardupilot/issues/19346), [PR1](https://github.com/ArduPilot/ardupilot/pull/20349), [PR2](https://github.com/ArduPilot/ardupilot/pull/20358)) -- resolved for beta3
- [x] BLHeli passthrough not working on CubeOrange's AUX1 ([issue](https://github.com/ArduPilot/ardupilot/issues/20362)) -- but is likely a hardware issue
- [x] MinimOSD not working? ([discussion](https://discuss.ardupilot.org/t/copter-4-2-0-beta2-released/82959), [Wiki PR](https://github.com/ArduPilot/ardupilot_wiki/pull/4231)) -- user needs to set SERIALx_PROTOCOL = 1
- [x] BalanceBot does not stand-up in Acro mode ([discussion](https://discuss.ardupilot.org/t/rover-4-1-3-rc1-released-for-beta-testing/79751/3)) -- resolved in beta3
- [x] takeoff stuck if alt-above-home is lower than alt-above-terrain ([comment](https://github.com/ArduPilot/ardupilot/commit/fb6c3ebb729a4b428da5dd14832cd95d71709a1e#commitcomment-68370961), [issue](https://github.com/ArduPilot/ardupilot/issues/20277), [PR](https://github.com/ArduPilot/ardupilot/pull/20153), [PR2](https://github.com/ArduPilot/ardupilot/pull/20285)) -- fixed in beta2 (the problem was only ever present in master, never made it to a beta)
- [x] GPS-for-yaw with DroneCan GPS not working ([discussion](https://discuss.ardupilot.org/t/copter-4-2-0-beta1-available-for-beta-testing/82460/6), [PR](https://github.com/ArduPilot/ardupilot/pull/20249)) -- resolved in -beta2
- [x] DShot esc issue ([discussion](https://discuss.ardupilot.org/t/copter-4-2-0-beta1-available-for-beta-testing/82460/8), [PR](https://github.com/ArduPilot/ardupilot/pull/20247)) -- resolved in beta2
