CraigElder
(Craig Elder)
1
**Issues & Pull Requests
GSOC
Open Drone ID
Plane
Copter
**Rover
*ROS / SLAM
CraigElder
(Craig Elder)
2
Attendee count (max): 19
UTC2301 - Recursive semaphores
- Semaphores that a thread can take multiple times but must release the same number of times
- Stops you deadlocking against yourself
- Adds against all the HALs
- https://github.com/ArduPilot/ardupilot/pull/9232
- Please check comment on PR discussing the locked-interface pattern
- Caller grabs the lock on the library
- They can call whatever they want on the library at that point
- When scope closes lock on library is released
- Caller takes care of atomicity
- Updates on library are happening on main thread but only update routines need to take lock
- Tridge is currently using this for new avoidance code
- MdB: I’m not sleeping, but I’ve talked with tridge a bunch before this
- [9:10 AM] (Channel) MdB: He cost me my lunch before the call actually
- ML: I have no idea what any of this means, so I think it’s a great idea!
- Maybe wait for FF or Lucas to comment
UTC2313 - Stack overflow checking in SITL appears to have broken MacOS
- Probably memalign vs posix_memalign
UTC2314 - avoiding bad RC trims
- https://github.com/ArduPilot/ardupilot/issues/9214
- Trimming planes in manual with RC trims means your FBWA may not fly straight (commanded)
- Add arming check that RC is in deadzone for 2 seconds since boot
- Should we check all channels rather than just the primary flight channels?
- Could be painful
- But would ensure correct model is selected
- Be at switch
- MdB: IE my PX4IO switch moves with flight mode switch
- [9:19 AM] (Channel) MdB: which means it may not be trim
- Maybe sometime later
- Sounds good, just needs implementing!
UTC2319 - https://github.com/ArduPilot/ardupilot/pull/9196
- Unit test suite should set the pragma indicating direct equivalence testing is OK
- Digression into hatred of templates
- Stop using templates so much?
- Is_equal a template for floats and doubles?
- Wrap180 should not be a template
- Scaling factor
- Critical function called rapidly in loops
- Or make a specific float version
UTC2324 - https://github.com/ArduPilot/ardupilot/pull/9188
- MdB likes it
- Tridge likes it
- Can be merged
UTC2330 - https://github.com/ArduPilot/ardupilot/pull/9163
- Tridge likes it
- MdB likes it
- Can be merged
- Catches where you use the wrong ID in a block going to disk
UTC2333 - https://github.com/ArduPilot/ardupilot/pull/9121
- Magic constant question
- Upper and lower limits?
- Lower limit 1 parameter
- Some other upper limit
- Is worth pursuing
- Solo has 95% lost packets
- Packet injection issue due to consecutive sequence numbers?
- Scale all your like with flow control
- Not above 115kbaud otherwise
UTC2343 - https://github.com/ArduPilot/ardupilot/pull/9116
- Tested in autotest
- Randy thinks it looks good and can be merged
UTC2345 - https://github.com/ArduPilot/ardupilot/pull/9107
- Servorelayevents
- Only on unused channels
- Perhaps a specific “relay” or servo function in addition to None
- Mavlink control?
- Put it in as-is
- Can add another define later if we feel like it
UTC2349 - https://github.com/ArduPilot/ardupilot/pull/9105
- Small optimisation
- This function should be using .get()
- Pre-existing bug discovered live!
UTC2355 - 8690
UTC2358 - https://github.com/ArduPilot/ardupilot/pull/7215
- Yaw from GPS
- still pending, won’t be done in a little while due to the OBC
- Removing devcalltopic
UTC0000 - https://github.com/ArduPilot/ardupilot/pull/8397
- More accurate timestamp
- Could end up logging too early
- Potential race condition
- Not easy to fix this race
- Maybe change semaphore to blocking-take
- This would not be safe as it’s in interrupt concept
- Aircraft would fall from sky
- Tridge will add a check that you’re not blocking-taking
- Not in use
- Pending for far too long
- Tridge doesn’t immediately recognise the code
- GPS time-lag estimation PR?
- [10:06 AM] (Channel) MdB: the main debate on it was what to do with units that are over-configured?
- [10:06 AM] (Channel) MdB: but I maybe can’t recall…
- 10Hz but can’t do 10Hz needs to reconfigure the GPS back to 5Hz
- https://github.com/ArduPilot/ardupilot/pull/8409
- [later] tridge worked on the patch, asks Nate to test
UTC0011 - https://github.com/ArduPilot/ardupilot/issues/5988
- Leonard’s started to look at it
- Will be a parameter under MOT_SLEWRATE or similar
UTC0014 - GSoC
- Coming to an end
- Students did very well
- Jaime is working through Sephyr’s work
- New repos on the ArduPilot github list
- All evaluations are in already
- All passed except the student who had to withdraw for legal reasons
- Thanks to all mentors and students!
- Mentors meeting in September
- Right before the China conference
UTC0018 - open-drone-id
- Intel is on workgroup with FAA
- Bluetooth beacon packet with 26 or so bytes
- Similar to ssid on wifi, always being sent
- 400m with bluetooth 4.2
- Should be able to do a km with bluetooth 5
- https://github.com/opendroneid
- Two messages at two different rates
- Tom’s working on mavlink gateway
- All in the blind
- No connections
- Alt, vel, pos
- 32-bit number
- Working group is authoring it
- Intel is kind of the secretary of the working group
- [10:34 AM] (Channel) TP: yes, there’s a speed vector
- TP: and AGL and MSL and an advertised accuracy
- TP: Open Drone ID pics:
- https://photos.app.goo.gl/VMeYDmYiJKujg1K37
UTC0030 - plane update
- New beta out
- Change of default pid gains for roll/pitch
- Old values way too low
- Avoid Soggy planes
- Want first throw-off experience to be better
- Bad experience on first flight when plane won’t pull up!
- TECS_PITCH_MAX of 15
- So automatic navigation controller doesn’t have bad landings due to poor pitch landings
- “Balloons” up and loses too much airspeed
- L1 rate changed to tighten navigation up
- MdB: oO I thought it was supposed to be ~1.5x speed?
- Autotune for TECS?
- OSD updates in 3.9.1
- Force messagewriters fix for very low dataflash buffer sizes
UTC0038 - Copter/Rover update
- 3.6 testing
- Randy was away last week
- Another rc coming this week
- Fix for allowing do commands before takeoff command
- Boost working or not?
- Not initialised correctly
- Growing calls for a Rover release
- Omniboats
- ChibiOS-only boards etc
- Sailboat code is moving along nicely
- With iampete
- Testrun in next week or so
- Non-gps navigation is moving along slowly
- When using external positions sources you can’t really use your compass
- Need to turn them off
- Otherwise your frames get misaligned
- EKF will align with compass
- External system won’t align with that
UTC0041 - tiziano
- Willing to make some media videos to make on our ArduPilot page if we can get him to the interdrone conference
- TP: Made some great videos in the past
- TF: I should have joined the dev call much sooner! Thanks for making my life easier!
- A lot of work to put a nice video together
- https://www.youtube.com/user/prandtlmayer/videos
- Funding request!
- How much, benefits etc etc
- Will do!
UTC0050 - Believer planes
- Still not coming
- Olivier still poking them
