Alternatively we could assume descent unless the stick is moved outside the dead zone
Copter can only cancel a land with high throttle
Don’t want to cancel the landings on plane ship landings as you are tracking a point
Just want to pause descent while it is going down (e.g. due to wave coming through)
Shouldn’t really be using loiter stuff
[10:46 AM] Peter Hall: IMHO more matching between copter and Q plane is better
[10:47 AM] Peter Hall: most people are quite used to how copter behaves before they try Q planes.
Pilot control of descent rate shouldn’t happen until you move past 90%
Flight options bit for Copter which allows you to not abort but control descent rate like this will allow
Very high desired climb rate for a moment while cancelling?!
Should we consider precision and normal landing differently?
Polit_thr_behave
Sprung or not
Used on takeoff
And for arming?
Leonard is working on specifications for takeoff/landing
10:55 AM] rmackay9: In copter the param that controls this is PILOT_THR_BHV. 70% does the cancel. it switches to Loiter or AltHold (if no position estimate)
[10:55 AM] rmackay9: really the param should be moved to LAND_OPTIONS (which doesn’t exist)
[10:56 AM] rmackay9: I also think we need to be careful that we don’t confuse users re which mode they’re in. So for example a battery failsafe could trigger and switch them to Land and we then make it fly like loiter… and they don’t know what mode they’re in…
[10:57 AM] rmackay9: LAND_CANCEL_TRIGGER_THR
Let’s try the “panic response” 70% throttle thing
Tridge will work with Henry to try that
UTC0058 - Plane update
Beta5 went in yesterday
Ability to fly in vtol modes in DCM
Crash
Large expensive quadplane ended up in DCM and it didn’t go well
As you enable things your flash-free-countdown ticks down
apj should mention what features you had enabled
Cookie should nominate previous build?
Donate button?
11:24 AM] rmackay9: Re GSoC, Rishabh has a bunch of PRs we hope to merge this week to add the precision landing state machine and some other improvements
