CraigElder
(Craig Elder)
1
Issues & Pull Requests
Plane
Copter
Rover
GSOC
Attendee count (max): 20
UTC2301 - https://github.com/ArduPilot/ardupilot/issues/2650
- Fix for cross-track error in Plane navigation
- Backport from 4.1
- To test in SITL, rudder/aileron offsets + wind to SITL and turn off servo auto-trim and path should still converge
- Not planning on doing a 4.0 release so this has been closed but if one is done it will get pulled in
- Tridge often creates PRs to backport fixes, marks it as 4.0 backport but then closes it.
- Not merging them allows us to do a very thin release if we really need to
- Currently 15 or 20 patches could go in
- Could create a 4.0-next branch which we would merge all the patches
- Would we need to support that branch?
- Current system allows them to run 4.0 plus one patch
- Currently 38 PRs marked for 4.0 backport to Copter
- Probably wonât ever make another 4.0 stable, however
UTC2317 - https://github.com/ArduPilot/mavlink/pull/203
- Mavlink bitmask attributes
- Merged
UTC2320 - https://github.com/ArduPilot/ardupilot/pull/16908
- Slew limit fixes
- do not run throttle when disarmed in Q modes
- Integers still used, which is bad
- History isnât a floating point number so youâve got to move 1us per loop or you donât move
- 50Hz means min 50us
- Separate filter on throttle needed
- Why do we want throttle slew limiting on tailsitters in forward flight?
- Currently itâs on for everythingâŚ
- Normal throttle is correct but left/right is not
- Tailsitter testing showed this up
- Throttle left/right wasnât fast in manual mode
- Try to get Henry to test this one
- Probably correct but needs lot of testing
- Spinup when disarmed should still be fixed
- Better fix for the spinup-when-disarmed is in here
UTC2336 - https://github.com/ArduPilot/ardupilot/pull/17152
- Limit all turn rates to ATC_TURN_MAX_G
- Will still slow down for a corner but if youâre going too fast it will go wider to limit accel
- Will not affect manual mode
- Rhysâ land yacht going way too fast
- Sailboats ignore the speed limit
- Slowing down is a problem
- Different limits in different limits x vs y
- Some variable renaming for consistency coming upâŚ
- Gravity table for world coming?!
UTC2349 - https://github.com/ArduPilot/ardupilot/pull/17139
- Fixes frames for wind direction
- Fixes some filtering
- Moves the logging into windvane
- True wind is still in earth frame
- Apparent wind is now in body frame
- Unrelated hydrofoil has static stability
UTC2353 - https://github.com/ArduPilot/ardupilot/pull/17209
- Tested upside down?
- Flip Copter over and make sure it recovers
- E.g. yaw control would rotate through 180 degrees
- Euler angle inputs did thatâŚ
- Are heliquads currently broken?
- No smooth transition from one to the other is the problem with current inverted flight setup on helis
- Simply inverts the targets
- Controls not reversed too
UTC0014 - https://github.com/ArduPilot/ardupilot/pull/17242
- Param editor on all boards?
- Dropped fonts so we currently have room
- KakuteF7-bdshot has it ATM
- 8kB cost
- Weâd probably be removing them again in very short order
- Wonât be merging this
UTC0018 - https://github.com/ArduPilot/ardupilot/pull/15507
- Aux functions from scripting
- Originally no way to tell where aux functions came from
- Still no way
- But we ignored that
- Merged
- Raise issue for adding proper logging
UTC0022 - https://github.com/ArduPilot/ardupilot/pull/16198
- User-defined parameters in scripting
- Still work to do
- Probably a 4.2
UTC0025 - https://github.com/ArduPilot/ardupilot/pull/17263
- Look elsewhere for your data in fixed wing modes
- Rate output doesnât include the feedforward component
- Bug in validator means weâre not picking up duplicate fields ATM
UTC0031 - https://github.com/ArduPilot/ardupilot/pull/17272
- Mergd
- Rover metadata fixes
UTC0031 - Plane updates
- https://github.com/ArduPilot/ardupilot/issues/15941
- AC_PID is looking good
- Landing system not in yet
- Quadplane approach might be 4.2
- EK3 GPS lag changing in flight
- Lag increased and GPS was stuffed
- When pushing into time horizon queue the sampleâs timestamp could be modified
- Do we lie on the input side or cope on the output side?
- Vast amounts of documentation going in - thanks Henry
- Geofence situational awareness in MP is poor
UTC0043 - Copter update
UTC0053 - GSoC
- May 3rd to fill slots
- Need to review applications
UTC0053 - https://github.com/ArduPilot/ardupilot/pull/17083
- 32-bit Cygwin install script fixes
- Before it was a 64-bit cygwin with 32-bit tools
- Cygwin builds for MP now done on github actions
- Tools/scripts/cygwin_build.sh
UTC0055 - Rover updates
- Another beta coming this week off master
UTC0058 - small PR for Rover
- Rotating mast sailboat
- PH to continue to help
UTC0058 - https://github.com/ArduPilot/ardupilot/pull/16239
- Battery charge state
- Minor bug to fix
UTC0102 - close
