opened 11:50PM - 12 Sep 22 UTC
Copter
Rover
DevCallTopic
ReleaseAdmin
This is a list of issues discovered during Copter and Rover 4.3 testing. For re…ference [Copter-4.3 project](https://github.com/ArduPilot/ardupilot/projects/25), [Copter/Rover-4.2 issues](https://github.com/ArduPilot/ardupilot/issues/20192)
Reports requiring investigation
- [ ] LAND not slowing down? ([discussion](https://discuss.ardupilot.org/t/copter-4-3-6-released/99269))
- [ ] RTL_SPEED not being obeyed? (reported by lthall)
- [ ] CSRF on Matek h743 slim ([discussion](https://discuss.ardupilot.org/t/copter-4-3-5-released/98158/10))
- [ ] Yaapu telemetry failing somehow related to 2nd battery ([discussion](https://discuss.ardupilot.org/t/copter-4-3-5-rc1-released-for-beta-testing/97674))
- [ ] KDECAN not working? ([issue](https://github.com/ArduPilot/ardupilot/issues/22952), [discussion](https://discuss.ardupilot.org/t/kdecan-telemetry-not-working-in-4-3-series-firmware/96730))
- [ ] internal error on takeoff ([discussion](https://discuss.ardupilot.org/t/consistently-getting-internal-error-0x100000-i-57-flow-of-ctrl/95839))
- [ ] waiting for terrain data in stabilize mode with ter_pend = 0 ([discussion](https://discuss.ardupilot.org/t/prearm-waiting-for-terrain-data-i-couldnt-get-rid-of-the-error/95415/19))
- [ ] trajectory discrepancy in Non-GPS ([discussion](https://discuss.ardupilot.org/t/huge-trajectory-tracking-error-when-using-position-velocity-typemask/95483))
- [ ] baro drift before takeoff leads to flip ([discussion](https://discuss.ardupilot.org/t/barometer-drift-before-takeoff/95436))
- [ ] balancebot not protecting backwards? ([discussion](https://discuss.ardupilot.org/t/rover-4-3-0-beta5-available-for-beta-testing/93379/7))
Copter specific issues (confirmed to be real)
- [ ] RTL_SPEED does not work if WPNAV_SPEED adjusted ([also in 4.4 issues list](https://github.com/ArduPilot/ardupilot/issues/23192), [PR](https://github.com/ArduPilot/ardupilot/pull/23220))
- [ ] NMEA Output GGA message bug ([issue](https://github.com/ArduPilot/ardupilot/issues/23157))
- [ ] Copter do-change-speed mission command not working after takeoff command ([discussion](https://discuss.ardupilot.org/t/mission-ignoring-do-change-speed-flying-wpnav-speed-instead/90815), [issue](https://github.com/ArduPilot/ardupilot/issues/21080)) -- existing issue in 4.2 as well
Rover specific (confirmed to be real)
- [ ] RoverS-Curves don't track a straight line as well as L1 ([issue](https://github.com/ArduPilot/ardupilot/issues/22183))
- [ ] internal error when using GPS-for-yaw ([discussion](https://discuss.ardupilot.org/t/rover-4-3-0-beta2-has-been-released/91551/3))
- [ ] MP basic tuning screen needs updating for S-Curves ([discussion](https://discuss.ardupilot.org/t/rover-4-3-0-beta1-released/90783/4))
GCS specific issues (confirmed to be real)
- [ ] Mission Planner needs updates for MNT1_ param name changes ([Plane user issue](https://github.com/ArduPilot/ardupilot/issues/21989), [Copter](https://discuss.ardupilot.org/t/gimbal-configuration-is-not-possible/93396/11))
Wiki related requests:
- none
Enhancement Requests (may or may not be done)
- [ ] Servo pitch+yaw gimbal should use pitch servo to correct yaw when vehicle is rolled 90deg ([discussion](https://discuss.ardupilot.org/t/gimbal-poi-feature/92234/7), [enhancement request](https://github.com/ArduPilot/ardupilot/issues/22440)) -- future enhancement
Resolved Issues
- [x] Rover-4.4.0 with RTK UM980 doesn't find GPS ([discussion](https://discuss.ardupilot.org/t/about-rtk-module-supporting/95348)) -- pin out diagram was incorrect
- [x] USD1 rangefinder on CAN interferes with DroneCAN GPS ([discussion](https://discuss.ardupilot.org/t/unable-to-use-gps-and-rangefinder-on-can-ports-1-and-2/97535/3)) -- user config error
- [x] AHRS_TRIM_XY over 7.5 deg interferes with landing detector -- resolved in Copter-4.3.5-rc1
- [x] duplicate log FMT messages ([issue](https://github.com/ArduPilot/ardupilot/issues/22662), [PR](https://github.com/ArduPilot/ardupilot/pull/22670)) -- resolved in master
- [x] Gremsy driver sending gimbal feed-forward values when vehicle is disarmed and pilot provides yaw input ([PR](https://github.com/ArduPilot/ardupilot/pull/22604)) -- resolved for 4.3.4
- [x] Surface Tracking oscillation with US-D1 lidar ([discussion](https://discuss.ardupilot.org/t/massive-amounts-of-noise-on-us-d1-radar-rangefinder-leads-to-erratic-altitude-hold/93132))
- [x] Surface Tracking using raw lidar instead of filt or interpolated leads to momentary fast climb ([PR](https://github.com/ArduPilot/ardupilot/pull/22611)) -- resolved for 4.3.4
- [x] Internal Error I:917 ([discussion1](https://discuss.ardupilot.org/t/internal-errors-0x100000-l-917-flow-of-ctr/87033/3), [discussion2](https://discuss.ardupilot.org/t/internal-errors-0x100000-i-921-flow-of-ctr-twitching-motion-in-loiter-during-forward-flight/93126), [discussion3](https://discuss.ardupilot.org/t/prearm-internal-errors-0x100000-l-921-flow-of-ctrl/93986), [PR](https://github.com/ArduPilot/ardupilot/pull/22298)) -- resolved for Copter-4.3.3-rc1
- [x] gimbal yaw jumps to far left when RC input > 1700 ([issue](https://github.com/ArduPilot/ardupilot/issues/22225), [PR](https://github.com/ArduPilot/ardupilot/pull/22442)) -- resolved for 4.3.3-rc1
- [x] baro alt error 5808m ([discussion1](https://discuss.ardupilot.org/t/copter-4-3-1-rc1-available-for-beta-testing/93378/7), [discussion2](https://discuss.ardupilot.org/t/prearm-error-gps-alt-error-5850m-see-baro-alterr/94099/3)) -- needed to set BARO_OPTIONS = 1
- [x] Kakute H7 V2 config error ([discussion](https://discuss.ardupilot.org/t/holybro-kakute-h7-v2-config-error-ins-unable-to-initialise-driver/92003)) -- resolved for 4.3.0-beta3
- [x] Arming check for slow loop rate triggering during motor test and compassmot ([issue](https://github.com/ArduPilot/ardupilot/issues/22388), [PR to revert for 4.3](https://github.com/ArduPilot/ardupilot/pull/22413))
- [x] message rates from a file not working? ([issue](https://github.com/ArduPilot/ardupilot/issues/22361), [PR](https://github.com/ArduPilot/ardupilot_wiki/pull/4820)) -- wiki dev docs were wrong, fixed with PR
- [x] slow param download with Pixracer on 4.3 vs 4.2 ([discussion](https://discuss.ardupilot.org/t/slow-parameter-loading-in-4-3/94075/3)) -- cannot reproduce, no response to request for logs
- [x] AHRS and GPS differ pre-arm when doing non-GPS nav ([issue](https://github.com/ArduPilot/ardupilot/issues/22383), [PR](https://github.com/ArduPilot/ardupilot/pull/22393)) -- resolved for 4.3.3-rc1
- [x] SBus output not working? ([discussion](https://discuss.ardupilot.org/t/copter-4-3-0-released/92530/14)) -- could not reproduce, receiver outputting SERIAL_CONFIG_8E1I instead of SERIAL_CONFIG_8E2I
- [x] Gremsy gimbal not reaching Pitch limits in RC_Targetting (angle mode) ([discussion](https://discuss.ardupilot.org/t/ardupilot-4-3-gremsy-gimbal-improvements-testers-wanted/86479/38)) -- no logs, cannot progress
- [x] Sporty takeoff ([discussion](https://discuss.ardupilot.org/t/feedback-and-assistance-with-new-takeoff-behaviour/94121)) -- change in behaviour, Leonard says param changes fix it
- [x] prearm RNGFND1_PIN=103, set SERVO3_FUNCTION=-1. ([discussion](https://discuss.ardupilot.org/t/copter-4-3-0-released/92530/14), [PR](https://github.com/ArduPilot/ardupilot/pull/22375)) -- resolved for Copter-4.3.3
- [x] boot fails if too many dshot LEDs ([issue](https://github.com/ArduPilot/ardupilot/issues/22263), [discussion](https://discuss.ardupilot.org/t/problem-in-copter-4-3-with-the-subsytem-led-preventing-the-drone-from-startup/93992)) -- classified by Andy as an enhancement request.
- [x] Siyi A8 mount always unhealthy ([discussion](https://discuss.ardupilot.org/t/siyi-a8-mini-4k-ai-mini-zoom-gimbal-camera-ai-identify-tracking-4k-1-1-7-inch-8mp-sony-sensor-6x-zoom/92133/30), [PR](https://github.com/ArduPilot/ardupilot/pull/22313)) -- resolved for 4.3.1
- [x] AutoTune gains not loaded during pilot testing ([PR](https://github.com/ArduPilot/ardupilot/pull/22193)) -- resolved for 4.3.2
- [x] Solo gimbal not pointing down past 45 deg ([issue](https://github.com/ArduPilot/ardupilot/issues/22190)) -- RC6_TRIM issue
- [x] Gimbal yaw-reset after pitch changed ([issue](https://github.com/ArduPilot/ardupilot/issues/22095)) -- QGC gimbal control issue
- [x] wheel encoder noise ([discussion](https://discuss.ardupilot.org/t/rover-4-3-0-beta1-released/90783)) -- user frame issue.
- [x] Gremsy gimbal overloaded with high update rate of vehicle attitude messages ([PR](https://github.com/ArduPilot/ardupilot/pull/22151)) -- resolved for 4.3.1-beta1
- [x] User can't find Benewake H30 lidar ([discussion](https://discuss.ardupilot.org/t/copter-4-3-0-released/92530/5)) -- not on sale yet
- [x] SkyViper Journey broken (4.0.8 works, >4.1 does not) ([issue](https://github.com/ArduPilot/ardupilot/issues/21932), [PR](https://github.com/ArduPilot/ardupilot/pull/22134)) -- resolved for 4.3.1-beta1
- [x] request for help setting up secure boot ([discussion](https://discuss.ardupilot.org/t/secure-boot-support/90991))
- [x] Rover S-Curve tuning instructions ([wiki](https://ardupilot.org/rover/docs/rover-tuning-navigation.html))
- [x] AP_GPS: Auto baud detection broken for SBF, Novatel, GSOF, SITL ([issue](https://github.com/ArduPilot/ardupilot/issues/21771), [PR](https://github.com/ArduPilot/ardupilot/pull/21830)) -- resolved for beta2
- [x] DO_JUMP commands not initialised if wp set before arming ([PR](https://github.com/ArduPilot/ardupilot/pull/21769)) -- resolved for 4.3.0-beta2
- [x] RPM harmonic notch not working? ([issue](https://github.com/ArduPilot/ardupilot/issues/20898), [PR](https://github.com/ArduPilot/ardupilot/pull/21717)) -- resolved for beta2
- [x] MambaF405mk4 includes mini version? ([discussion](https://discuss.ardupilot.org/t/rover-4-3-0-beta1-released/90783/6))
- [x] Mount's default mode not working for SToRM32 MAVLink (also not working in 4.2) ([PR](https://github.com/ArduPilot/ardupilot/pull/21737)) -- fixed for beta2
- [x] NeoPixel LEDs on ESC1,2 on SkystarsH7HD not working ([discussion](https://discuss.ardupilot.org/t/copter-4-3-0-beta1-released/90782/10)) -- known hardware limitation related to PWM grouping
