Dev Call April 20, 2026
CI Workflows
Dev Call April 13, 2026
Release Update
Issues & Pull Requests
Attendee count (max): 17
UTC2301 - CI
  • Blimp test
  • Slowdown seems to be their infrastructure
  • Release took a long time
  • 30-odd PRs to fix bogged things down
    • AI-created
    • Require approval for first-time contributors
    • Currently “to github”
    • Maybe change to “to ardupilot”
      • Yes, done
UTC2310 - release update
  • Custom message crc error thing
  • Need to revisiting the MAVn_DEVID thing
    • It’s still a source of major confusion
  • Mavlink logging docs need improving
  • Terrain download stuff that Tim reported
    • Visible as terrain pending bouncing up and down
      • Fix the TERR message to log the number of requests made to the GCS
    • Thomas looked at it
    • Logs show there was no attempt to grab terrain from GCS
    • Cache being thrashed
    • Default cache size was 12
      • 12 costs 12*1800 bytes
        • 21kB
      • Reasonable for 15m/s with 100m spacing
      • Tim’s using 30m spacing and moving faster
      • With lookahead in fixed wing it is constantly trying to pull in more terrain tiles
      • Reproducible in SITL
      • Lower the terrain cache size TERR_CACHE_SZ
      • Use maybe 50
        • Yay H7
    • When circling there’s a tangent vector scanning the landscape!
      • Curved lookahead?!
    • Constant re-evaluation of terrain is a good thing
    • 30m or less spacing on Copter / with terrain-based navigation could be a real problem
      • Terrain failsafe may trigger
      • RTL can also use terrain….
        • Would return at home alt interpreted as above home if that fails
  • Elrs
    • Joystick and regular RC
    • RC off all the time
    • Flying just with joystick
    • When telemetry is broken
    • Switches back to the regular RC which has never been used
  • Buffer overflow in CAN logging is critical
UTC2347 - common.xml: update MAV_CMD_DO_SET_MISSION_CURRENT desc by peterbarker · Pull Request #498 · ArduPilot/mavlink · GitHub
  • Update XML
  • Merged
  • Some confusion on the wording
UTC2357 - https://github.com/ArduPilot/ardupilot/pull/32416
  • Add PilotGaea board
  • Merged
UTC2359 - https://github.com/ArduPilot/ardupilot/pull/32605
  • Fix build problems with test_build_options.py
  • Merged!
UTC0001 - https://github.com/ArduPilot/ardupilot/pull/32634
  • Fix payload place and land altitude bug
  • Issues found
UTC0001 - Convert QURT HAL to using hwdef system by peterbarker · Pull Request #32728 · ArduPilot/ardupilot · GitHub
  • Move QURT over to using hwdef system
  • Actually uses two toolchains
    • Two architectures….
  • Merged!
UTC0006 - Plane: add input shaping to roll and pitch controllers by IamPete1 · Pull Request #32743 · ArduPilot/ardupilot · GitHub
  • Add input shaping to roll and pitch controllers
  • Real-time scurves used to limit control output
  • Need to understand step changes in estimator output
  • Need to see what happens with upset recovery
    • We don’t limit ourselves to roll rates when doing upset recovery
  • Ardupilot is a submodule of web tools now
    • Compiles to webasm
  • Should be able to use the parameter revert script
UTC0020 - AP_Compass: report specific failure reason when fit rejected by christianpetri · Pull Request #32757 · ArduPilot/ardupilot · GitHub
UTC0040 - Issue with throttle mix and quadplane hard landings · Issue #32759 · ArduPilot/ardupilot · GitHub
  • Throttle adjustment for VTOL land
  • Abort and land use the same numbers
  • Don’t force mix-max during VTOL landing descent
  • Learning hover throttle doesn’t really happen on a quadplane
    • Doesn’t spend long enough at hover throttle in quadplane
    • And then you find you were in a wind when this happened
    • Learnt very low hover throttles are very bad
  • Lua script to adjust the hover throttle for massive payload drops
  • We also have learn-but-don’t-save option
  • Descending fast in a quadplane leads to instability
    • So allocating output to stability and increasing your descent rate can be counterproductive!
  • #32759
    • Difference between MOTB.ThrAvMax and QTUN.TMix
    • Former was really high
    • The latter was 0.5
    • In some part of the code the tmix better reflects what is being used
    • Output-arm-stabilizing uses one but might want the other?!
  • Leonard will have a look
  • There is a web tool to help you understand these numbers
  • Probably a 4.7 candidate for the mix/max change
UTC0057 - hwdef: Add JFB200 of JAE flight controllers by n-ito2222 · Pull Request #32786 · ArduPilot/ardupilot · GitHub
JFB2000 board
  • Reviewed it
  • We agreed that we would have provisional allocations on board IDs
UTC0111 - AR_Motors: Make power limiting eaiser for end-users by stephendade · Pull Request #32788 · ArduPilot/ardupilot · GitHub
  • Power limiting for Rovers
  • Stop motors overheating due to over-watt
  • When testing on a real Rover the low-passed power added lots of lag
    • Could take 15 or 30 seconds to hit the power limit
    • Made it difficult to understand when the limiter was in effect
  • This PR lowers the filter time constant
  • Maybe not on the statustext?
    • Is hitting your limits an error?
    • This acts in manual mode!
    • Disconcerting on the throttle
    • Want to ensure the user knows what is happening
  • Stephen thinks that the watt limiter being active is always a sign of a bad thing happening
    • Thomas thinks he wouldn’t want to be nagged!
    • MOT_THR_MAX to 80% each?
      • Doesn’t work with DC motors?
  • Statustext will be removed…
  • Stephen will come back with this one
UTC0122 - Surface tracking: preserve full pilot climb/descent authority by lthall · Pull Request #32789 · ArduPilot/ardupilot · GitHub
  • Preserve full pilot climb/descent authority
  • Surface tracking can saturate
  • Allows for max climb even in the face of terrain
  • Not without problems at the bottom of a hill you might end up with a climb rate above your maximum but it is better than the double you could get at the moment
UTC0127 - Add support for Shanghai Fudan Microelectronics (FMSH) FM25Q series NOR Flash by gengchi-fuan · Pull Request #32796 · ArduPilot/ardupilot · GitHub
  • Add support for FM25Q autopilot
  • Already lots using this?!
UTC0131 - Augment sim_vehicle.py with a GUI · Issue #32802 · ArduPilot/ardupilot · GitHub
  • Request for a GUI for SITL
    • Scenario-based seems OK
  • Aside:
    • MissionPlanner + quadplane tilt
    • Very difficult to get this working in MissionPlanner SITL
    • Issue was opened
  • If you have ideas on what should be in this “starter gui” please add to issue
  • mavagent?!
UTC0141 - autotest: add test for plane-wind-failsafe.lua by peterbarker · Pull Request #32807 · ArduPilot/ardupilot · GitHub
  • New autotest for Plane
  • Discussion around Lua debugging
  • [11:43 AM]NateMailhot: Recursive self repairing script?
  • Peter has coverage working
UTC0144 - Tools: break callisto SITL config to a common method by Ryanf55 · Pull Request #32828 · ArduPilot/ardupilot · GitHub
  • Break Callisto starting method out into a method
  • Do we want to use more Python features
UTC0149 - beta
  • Will be trying to keep to the 2 week cycle
  • Tag your PRs!
UTC0155 - discussion on votes
  • Should ask user before raising vote
  • Follow the instructions (dev-team user guide!)
UTC0156 - looking at log
  • Throttle stuck at 50%
  • Everything is just oscillating
  • roll/pitch commands pulling the average up throttle
  • During descent it builds the vertical speed
    • Natural instability bites
  • If the mix was at 0.1 would the vehicle have done better?
  • Descent rate was commanded at 1.5 but got 6
    • Instability let the speed build up
  • Leonard thinks there might be more to this
    • Throttle was pegged
    • He thinks this would do this regardless of what you did
    • Previous experience shows that loiter stabilised the aircraft
      • Why does this work?
      • Maybe there’s an impulse here somewhere?
        • A momentary reduction in throttle?
    • Maybe if we hit a stability limit then stop trying to descend
      • Or if you exceed a descent rate then command zero
    • Leonard thinks tune the aircraft to handle the maximum descent rate
    • Might need to limit the descent rate more on the aircraft
    • Turbulence etc etc….
  • So too-rapid and the vehicle may not recover
  • But sometimes too much stabilisation required and the quadplane can’t descend
UTC0213 - close
Could we keep track of highest terrain alt and use it as fallback for terrain failures?
Having a way of mapping ports and channels would be handy.
It depends on ths use case, sometimes crashing into the ground is better than flying too high and breaching an airspace restriction.
But I do agree that we could handle this better.
Fair point though at that point terminating (with parachute) is IMHO the only sane option (unless you are flying over flat ground). CFIT sounds like big ground risk.
