Attendee count (max): 18
UTC1110 - Conference recap
- Went well
- Videos are up
- No fancy editing, just blatted up
- If anyone feels like doing all the splash screens and things they’re most welcome
- Need to work out what to do next year
- Stream and zoom?
- Neither?
- Redundancy this year
- Would be nice to get mavlink forwarding for support without a static IP address
UTC1111 - templates: sort included headers in msg.h.em by peterbarker · Pull Request #5 · dronecan/dronecan_dsdlc · GitHub
- Consistent output from the dsdl compiler
- Merged!
UTC1114 - User request: add new target: revo-mini-sd by shellixyz · Pull Request #20077 · ArduPilot/ardupilot · GitHub
- Revo-mini-sd
- Same as revo-mini
- Merged!
UTC1117 - External flash cleanups by andyp1per · Pull Request #20411 · ArduPilot/ardupilot · GitHub
- Doesn’t seem to affect other-than-extf
- Merged
UTC1119 - Adding ability to use multiple notches for multiple rpm sensors by lucascheuer · Pull Request #20400 · ArduPilot/ardupilot · GitHub
- Multiple notches for multiple RPM sensors
- Closed PR but might be a good one?
- Need to configure existing harmonic notches to use second RPM sensor
- We really need to rename one of the notches to show they’re the same sort of thing
- [9:31 AM] AndrewTridgell: INS_HNTC2_ENABLE
- [9:31 AM] AndrewTridgell: INS_HNTCH_ENABLE
- Parameter conversion should be OK
UTC1136 - Copter update
- Rc 1 released
- Probably should’ve been beta4
- Looking forward to feedback
- A few things to resolve
- Probably one more before stable gets released
- Sysid for 4.2?
- Should go into the next one
- Zero watchdog fix is in this one
- Would be nice to have reproduced on the Kakute, but couldn’t
- Maybe tryto repro on omnibusf4pro?
- If we get a crash log, please ftp a copy of the crash log before reflashing the board!
- Writing to SD card automatically would seem to be a good idea?
- Seems to be someone who can reproduce on omnibusf4pro-bdshot
- Set_attitude_target change
- Covered by Leonard in presentation
- Need to clarify in documentation?
- Blheli-s not working?
- OSD group2 parameter link
- Cubeblack memory?
- New version is using more memory
- Rover could go out anytime, really
- How much more memory is black using?
- 6kB?
- Dual-CAN and FTP….
- Are we regressing from 4.1?
- Need numbers on this
- Parameters have been supplied
- Need to test this
- If there are bug fixes that should go into 4.2 please ping Randy
- Query on visual stuff not working on 4.2?
UTC1152 - Tools: add airspeed defaults to vehicle defaults files by Hwurzburg · Pull Request #20423 · ArduPilot/ardupilot · GitHub
- Add airspeed defaults to defaults files
- Merged!
UTC1153 - Clarify get_pilot_desired_lean_angles and fix limit by lthall · Pull Request #20428 · ArduPilot/ardupilot · GitHub
- Pilot lean angle fixes
- Should be mergeable after CI passes
- Change in Plane hasn’t gone into the PR?
- Multiple copies in Plane?!
- Flight testing would be good….
- Shouldn’t be going past 85 degrees with this algorithm….
- Set_control_in needs to die
UTC0001 - Matek F765 Wing bdshot by andyp1per · Pull Request #20468 · ArduPilot/ardupilot · GitHub
UTC0003 - hwdef: minimal GPS support for Flywoo boards by Hwurzburg · Pull Request #20474 · ArduPilot/ardupilot · GitHub
- Minimal support for GPS boards
- Missed one that needs minimal GPS thrown in
- merged!
UTC0004 - AP_AHRS_DCM: fix normalization reset by hendjoshsr71 · Pull Request #20475 · ArduPilot/ardupilot · GitHub
- Fix normalisation reset
- What does 1,0 actually mean here?
- It’s a normalised thing, so this is a sanity check that the normalisation succeeded
UTC0011 - Move logging of RPM, Beacon and Proximity into relevant libraries by peterbarker · Pull Request #20476 · ArduPilot/ardupilot · GitHub
- Move logging of RPM, Beacon and Proximity over
- Needs testing
UTC0021 - Remove instance id from EK2 external interface by peterbarker · Pull Request #20483 · ArduPilot/ardupilot · GitHub
- Remove -1 from ekf2 interfaces
- Saves a few bytes
- merged
UTC0024 - AP_NavEKF3: store and use lastKnownPositionD by peterbarker · Pull Request #20484 · ArduPilot/ardupilot · GitHub
- Fixed-position mode
- Need Paul’s input on this
- Need to fix m vs cm
UTC0029 - Add specific compile options for Volz/RobotisServo by peterbarker · Pull Request #20485 · ArduPilot/ardupilot · GitHub
- Compile-options for Volz and RobotisServo
- Rather than relying on AP_Periph
- Merged
UTC0035 - Fix setting GIT versions from environment by peterbarker · Pull Request #20492 · ArduPilot/ardupilot · GitHub
- Gate GPS backends
- Build hitec mosaic
- SBF based GPS
- Make sure build size not changing
- And f303-universal
- And f303-gps
UTC0054 - Plane update
- Adsb issue needs to be looked at
- Nate’s issue really needs looking like
- Mid-flight motor reversal
- 1000 degrees/second rotation
- No explanation as yet
- Interrupt flood from camera feedback pin?
- New ubox firmware problems
- 1.13 to 1.30
- Configuration protocols have changed
- Need to fix this as new GPSs might start to come with 1.3.0 firmware
- Drastically bad
- Might be able to stop statting each file on fatfs
UTC0108 - Pitch-based weathervaning
UTC0110 - Tidy sending of start-sending-init-blob by peterbarker · Pull Request #20494 · ArduPilot/ardupilot · GitHub
UTC0110 - CRSF check against failsafe defaults
- Lowers warning threshold on displays
- merged
- Should use the EKF parameter
UTC0115 - cleanups for sending GPS blob initialisation
UTC0122 - AP_Periph: updated peripheral bootloaders by tridge · Pull Request #20505 · ArduPilot/ardupilot · GitHub
- Simplify building of boards
