Dev Call Apr 21, 2025
Release update
Issues & Pull Requests
Attendee count (max): 16
UTC1100 - vehicle updates
  • Several Plane PRs have gone in
    • Pitch level-off at take-off PR is under review
      • Needs to target master
  • Report that secure bootloader doesn’t work?
    • Leonard followed instructions on the Wiki and it worked well
    • 4.5.x ‘though
    • First set of instructions didn’t work
      • Perhaps monocypher version?
    • Randy will continue
      • Probably an individual user issue
  • M10 issue
    • Maybe make a LUA script to do the cold reset
  • No blockers for another beta release?
  • Reports of extreme servo movements on soft reboot
    • Cut pulses?
    • Peter also sees it on vehicle startup, before ArduPilot is running
      • Possibly need to pin pins in the bootloader too?
  • Several important fixes have gone in the last week which would be good to get out in a new beta
  • New beta tomorrow maybe?
UTC1120 - Remove Python2 support; inline typing markup into templates by peterbarker · Pull Request #1025 · ArduPilot/pymavlink · GitHub
  • Inline typing markup into templates
  • Drop support for Python2
  • A little more testing but can then be merged
UTC1130 - pymavlink: update to master by peterbarker · Pull Request #394 · ArduPilot/mavlink · GitHub
  • Update to master pymavlink / 22.04 in github workflows
  • merged
UTC1132 - AP_Follow: change to using position-from-origin internally by peterbarker · Pull Request #27250 · ArduPilot/ardupilot · GitHub
  • Move to using position-from-origin in follow
  • Needs another little test in quadplane
  • Use tofloat and todouble
  • Can be merged after this little stuff has been done
UTC1146 - DroneCAN: support sending/receiving DroneCAN messages in lua by tridge · Pull Request #29310 · ArduPilot/ardupilot · GitHub
  • Support sending/receiving DroneCAN messages
  • Needs a libcanard PR to go in
    • Want Thomas to have a look at the libcanard
  • PH is happy with this
  • A few little things PH found
  • Actually saves some flash in libcanard
    • Need Thomas or SId to review…
  • Some discussion around proper cleanup of userdata objects
    • Tridge will ping PH for another review
UTC1148 - AP_NavEKF3: Use the correct extnav variances for posvel fusion by rishabsingh3003 · Pull Request #29420 · ArduPilot/ardupilot · GitHub
  • Use correct extnav variances for posvel fusion
  • PR approved and tested by user in Japan
  • Split out a contentious part
  • This should be fairly well-tested
  • Merged!
UTC1159 - AP_Baro: Add support for AUAV airspeed sensor absolute channel by IamPete1 · Pull Request #29535 · ArduPilot/ardupilot · GitHub
  • Support for AUAV airspeed’s absolute pressure
    • Shared backend class
    • Talk-to-sensor class
    • baro inheriting from airspeed is a bit strange
    • Tridge actually stripped the absolute stuff out before merging AUAV
  • Why not a completely separate baro driver?
    • Code is almost identical
  • We could have an AP_AirPressureSensor library
  • We decided the slightly weird structure was fine
UTC0011 - AP_NavEKF3: Manual Lane switching by rishabsingh3003 · Pull Request #29623 · ArduPilot/ardupilot · GitHub
  • Manual lane switching in EKF3
  • A switch gives you the different lanes
    • Able to check your tune on each of your three lanes!
    • Eg. different vibration
  • We need better feedback on what the cores are doing
  • Autoswitch still works…
  • Some naming comments from Randy
  • Lane or core?
  • lane
UTC0013 - AP_LandingGear: stop dup retract messages, clean up code by Hwurzburg · Pull Request #29676 · ArduPilot/ardupilot · GitHub
  • Stop dup retract messages
  • Merged!
UTC0019 - ArduPlane: fix quadplane stopping speed equation by eppravitra · Pull Request #29712 · ArduPilot/ardupilot · GitHub
  • Fix quadplane stopping speed equation
  • Mismatch between the comment and the code
  • This will result in a higher stopping speed
  • This may cause things to over-shoot?
    • Position1 controller only exists because the normal controller doesn’t work well at 100km/h
  • Used to slow down until the normal velocity controller can take over
  • This will try to stop faster than it can in this phase
  • This should cause the vehicle to slow down sooner
  • Slower all the way in
  • Should no longer have a glitch at cross-over either
  • Q_TRANS_DECEL is flawed
    • It’s saying decel is constant
    • momentum-drag/fuse-drag / whatever
    • Your decel really varies over time
      • Check the x-axis accel!
    • Should have checked with Leonard or Paul or Pete before doing Q_TRANS_DECEL
    • Building on top of a rubbish assumption
  • Don’t want to stop too short or you can end up with throttle surging
  • Test in RealFLight then on real vehicle
  • Double-the-waypoint code?
  • There’s also some awful couple between waypoint speed and this code
    • 2 times waypoint speed used as an envelope
    • Tridge would like some help on “target_speed = MIN(MAX(poscontrol.pos1_speed_limit, 2*wp_speed), target_speed);”
      • …. It’s silly, makes things speed up sometimes
  • Would be nice to just use normal position controller
    • So get rid of position1
    • Normal velocity controller doesn’t like using very fast things
    • Asymmetric speed control
      • More forward than backwards required in Plane
    • Maybe things have moved forward?
    • PH might have a PR
    • Q_PSC_BIAS?
      • 1 for symmetric
      • 2 for twice front/back as left/right
      • Elliptical control
        • But an offset ellipsis as you do not want to go backwards very much at all
      • Needs frame rotation for this
  • Characterisation of drag would be nice
UTC0036 - Add rc 2 sub by Hwurzburg · Pull Request #29742 · ArduPilot/ardupilot · GitHub
  • RC for sub
  • Some issues with hard-coded stuff in Sub
  • Maybe default the RC channel 0 for sub
  • Groupinfo_frame used?
    • copy/paste stuff has been vexing on FRAME
UTC0049 - AP_NavEKF: Allow EK3 cores to run different sources by rishabsingh3003 · Pull Request #29750 · ArduPilot/ardupilot · GitHub
  • Allow EK3 cores to run different sources
  • An option bit to treat the source sets as the sources for the different lanes
  • Some more testing requested
UTC0057 - AP_HAL_ChibiOS: Fix using the incorrect pin after checking the correct pin is defined by joshanne · Pull Request #29789 · ArduPilot/ardupilot · GitHub
  • Fix brick2 servo rail check
  • Merged!
UTC0106 - Plane: correct checking of mask for changing altitude by peterbarker · Pull Request #29799 · ArduPilot/ardupilot · GitHub
  • Correct checking of mask for changing altitude
  • Merged!
UTC0107 - AP_Proximity: Add more proximity backends by rishabsingh3003 · Pull Request #29802 · ArduPilot/ardupilot · GitHub
  • Add support for more proximity sensors
  • Merged
UTC0110 - SITL: Support JSON aero coefficients by Ryanf55 · Pull Request #29809 · ArduPilot/ardupilot · GitHub
  • JSON aero coefficients via JSON
    • Similar to Copter’s frame types
    • Mission feasibility testing
  • Few people have used the existing stuff
    • Now we can have parameter trees in models maybe we should just make things normal parameters?
      • SIM_MC_
      • SIM_PLN_
      • We can do thrust-per-motor / vector stuff
  • MergeOnCIPass
UTC0118 - hwdef: add flash-from-SD support for MatekH743 by ntamas · Pull Request #29810 · ArduPilot/ardupilot · GitHub
  • flash-from-SD support for MatekH743
  • Merged!
  • We should allow flashing bootloader without embedding it
UTC0131 - Fix and move get_fwd_pitch_is_limited() by lthall · Pull Request #29826 · ArduPilot/ardupilot · GitHub
  • Fix and move get_fwd_pitch_limited
  • The fwd-pithc-limited-not-unset thing may explain something tridge was chasing…
  • MergeOnCIPass
UTC0138 - AP_NavEKF3: check if using GPS before scaling observation noise based… by rishabsingh3003 · Pull Request #29847 · ArduPilot/ardupilot · GitHub
  • Check if using GPS before scaling observation noise
  • Stop applying the scaler when not using GPS for nav
UTC0142 - Add axis and units to AC_PosControl by lthall · Pull Request #29848 · ArduPilot/ardupilot · GitHub
  • Add axis and units to AC_PosControl
  • Facilitate moving to metres and other SI units
  • “u” vs “up”
  • We resolved on NEU and U
    • Upper-case
  • People are happy with the renames!
  • With no compiler output change this is good to go in
UTC0153 - AP_Mount: XFRobot enabled on 2mb boards by rmackay9 · Pull Request #29811 · ArduPilot/ardupilot · GitHub
  • Enable XFRobot on 2MB boards
  • Merged!
UTC0058 - Tools: XFRobot image and video download script by rmackay9 · Pull Request #29813 · ArduPilot/ardupilot · GitHub
  • XFRobot image and video download script
    • Thanks to ChatGPT
  • Merged!
UTC0059 - AP_Logger: Enable LOG_FILE_DSMROT by default by Ryanf55 · Pull Request #29814 · ArduPilot/ardupilot · GitHub
  • Enable LOG_FILE_DSRMROT by default
  • Would break people currently running Replay
  • Tridge currently likes getting everything in the one log, too
  • Using rate-max can also really help leaving log-disarmed set
    • You still end up with small logs
  • A web tool to split things?
  • Should we set LOG_DISARMED when LOG_REPLAY is set
    • It’s not completely useless without LOG_DISARMED
    • Replay isn’t as useful but you do get all of the raw IMU data etc
UTC0105 - Add airspeed control to AP_DDS for plane in GUIDED by Ryanf55 · Pull Request #29829 · ArduPilot/ardupilot · GitHub
  • Airspeed control in AP_DDS
  • Peter raised objections to copy/paste of code, would prefer to see function factored
  • Will be back!
UTC0115 - Tools: ros2: Add airspeed test with new fixtures for testing plane in ROS 2 CI by Ryanf55 · Pull Request #29832 · ArduPilot/ardupilot · GitHub
  • Add test with new fixtures for testing Plane
  • Merged!
UTC0118 - Make ArmingChecks enum class AP_Arming::Check by peterbarker · Pull Request #29830 · ArduPilot/ardupilot · GitHub
  • Make arming checks enum-class
  • Merged!
UTC0119 - Prevent rotation pitch calculations from running post-rotation by Georacer · Pull Request #29834 · ArduPilot/ardupilot · GitHub
  • Prevent rotation pitch calculations
  • Need to discuss with George
UTC0120 - All vehicles: Fix non fatal rc failsafe bug by Hwurzburg · Pull Request #29846 · ArduPilot/ardupilot · GitHub
  • Fix non-fatal RC failsafe bugs
  • Second Plane patch is strange
UTC0124 - close!
