Attendee count (max): 27
UTC1102 - https://github.com/ArduPilot/ardupilot/pull/14013
- Profiled support
- Stuff finished up from last week
- Tridge isn’t keen on having this backported to Plane
- Merged into Copter stable
UTC1102 - https://github.com/ArduPilot/ardupilot/pull/13997
- Autorotate bailout stuff
- Tell motors library we want rapid spoolup of throttle
- Runup timer and rampup speed
- Weren’t correctly handling timer
- Preserve delta between rampup time and runup time
- Should never be less than one?
- Quadhelis have very fast runups?
- SITL-only, being autorotate
- End-to-end review
- Bill needs to read and test end-to-end
UTC1109 - https://github.com/ArduPilot/ardupilot/pull/13989
- Allow use of ramp-up when using external governors
- Set governor up so it sees a pwm in a certain band
- Governor knows when you return power (reengage interlock) will ramp up throttle much quicker
- Parameter to set this window for external governor
- New tail rotor type allowing tail rotor to be governed by external governor
- Tested on hardware, no flying so far
- Interesting test setup - see video in PR
- Bill will merge this when he is happy
- Jumps in graph?
- minimum setting on RPM affects this?
- This is measured from real-world-test
- Could be the ESC feedback being wonky
- Rob uses idle for that quick-startup point
- That quick-spool up works OK for Rob
- Need to be careful here as it does lead to problematic situations
- Landed means window isn’t used; it goes to idle
UTC1121 - https://github.com/ArduPilot/ardupilot/pull/13934
- Copter velocity control method
- Should be non-functional-change
- Dt handling is slightly different
- Tridge is happy to merge anyway
- merged
UTC1122 - https://github.com/ArduPilot/ardupilot/pull/13878
- GPIO reorganisations for in Linux API
- Lucas?
- Has done a quick review
- Hasn’t been responded to yet
- Constexpr on some boards x= sin(3) will work if the compiler can evaluate sin, but some can’t
- Good otherwise as it will throw error if it can’t be calculated at compile time
- Auto keywords?
- We do use it elsewhere
- Main advantage is you don’t need to work out exact type
- Used for DIR structure in autofs to allow type to be private
- Judicious use is not a bad thing
UTC1124 - https://github.com/ArduPilot/ardupilot/pull/13712
UTC1134 - https://github.com/mavlink/mavlink/pull/1342
UTC1147 - https://github.com/ArduPilot/ardupilot/pull/14115
- Merged!
- More documentation!
UTC1148 - https://github.com/ArduPilot/ardupilot/pull/14102
- Henry Plane tailsitter
- Tailsitter transition to fixedwing jerks then ramps
- Starts transition from current pitch angle
- Doesn’t pitch to zero at start
UTC1151 - https://github.com/ArduPilot/ardupilot/pull/14102
UTC1151 - https://github.com/ArduPilot/ardupilot/pull/14129
- Look at vehicle initialised?
- Need to make sure we don’t lose messages
UTC1154 - https://github.com/ArduPilot/ardupilot/pull/14140
- Race condition on storage write
- Sentinel can be corrupted in race condition
- Could cause current parameter loss
- More review would be good
- Tricky thing at low level
UTC1157 - https://github.com/ArduPilot/ardupilot/pull/14122
- Handle external nav resets
- Reset messages now making it into EKF
- And now they’re being handled
- Before picture you see a reset
- EKF chews for a while and then swallows it
- After picture shows EKF doing hard reset straight away to new position
- Sign seems correct
- Resets can occur on a regular basis
- Delayed reading
- Would currently need to disable GPS to use vision as primary
- Randy and Paul will chat
- This PR is a fairly small use-case
- This isn’t going to be used by thousands as soon as it is merged….
UTC0005 - https://github.com/ArduPilot/ardupilot/pull/13921
- Fix if an axis is producing unrealistic values then we fail in its entirety
- Paul is happy to close this out as “that’s the way it works”
- Tridge is thinking minimum-changes to EK2 as well
- Peter still to review
UTC0012 - https://github.com/ArduPilot/ardupilot/pull/13776
Operation with no or bad compass data
Couple of time-wrap issues
Randy’s found a bunch of existing overruns too
https://github.com/ArduPilot/ardupilot/issues/14058
Want this in before next devcall
Subtracting of timestamps must be on same type to get wrap correct
Paul can patch this today
No ekf check stuff in quadplane
Tridge will merge this-arvo, hopefully
UTC0018 - scripting, add bindings for servo output
UTC0019 - https://github.com/ArduPilot/ardupilot/pull/14108
- Correction for GPS antenna offset
- Const-ifying two functions
- Removing scope of calls
- Not called when not using GPS?
- Merged!
UTC0021 - https://github.com/ArduPilot/ardupilot/pull/14085
- Compass calibration in separate thread
- Will need to be rebased to check stack usage
- Could notionally force-arm and fly with the thread still running
- Needs to be valgrinded
- Can’t be instant-reviewed
- Tridge and MdB will both want to review
UTC0023 - https://github.com/ArduPilot/ardupilot/pull/13974
- Moving-baseline yaw
- MdB was concerned about averaging time
- 245ms if you’re a Rover gps, 215 when not
- Rtcm corrections down both ports is bad
- But sometimes the correct thing
- Need to look at load on ublox
- Tridge to prove it is a problem before we attempt to fix it
- MdB will see if he can find an easier solution
UTC0030 - https://github.com/ArduPilot/ardupilot/pull/13911
- Add @PARAM and @SYS virtual filesystem
- Partial parameter downloads
- Fixed FTP server packet timeout
- Losing reply to open you’d have to reboot
UTC0035 - https://github.com/ArduPilot/ardupilot/pull/13746
- Needs all unrelated changes split out into separate PRs
UTC0043 - https://github.com/ArduPilot/ardupilot/pull/13387
- If anyone steps close to copter then don’t allow it to arm
- 0.6m ATM
- Prearm distance to allow it to be changed
- Randy was considering removing it completely
- We don’t back up so it doesn’t too much
- Alt-hold is a little more interesting
- PH thinks it is good
- Default the value to existing default?
- Make it a script instead?
- Randy will just rename message
UTC0045 - https://github.com/ArduPilot/ardupilot/pull/13166
UTC0048 - Plane update
UTC0048 - Copter
UTC0050 - Rover
UTC0052 - GSoC
- A bunch of good proposals
- Some very good students
- Can’t discuss details of applications because of Google’s rules
- Evaluation closes later this-evening
- Limited by number of mentors
UTC0053 - https://github.com/mavlink/mavlink/issues/1346
- Discovery of vehicle metadata?
- This related to our new @SYS and @PARAM filesystenms
- Default parameter files?
- Has to come from within vehicle
- Parameter caching is bad
- Fast download of parameters via FTP
- Unset would be nice
- Spare bit in header
- Garbage collection
- Will be concentrating on @PARAM / @SYS stuff for the time being
- Once it is merged will approach Don to see about QGC support
UTC0107 - close
