Dev Call Apr 01 2019 2300 UTC
Issues Pull Requests
Plane
  • Plane release
  • TECS bug fix
Copter
Rover
Dronekit Vote
Attendee count (max): 17
UTC2305 - retiring trusty
  • The compiler question - trusty64
  • Having travis
  • Will merge it!
UTC2313 - https://github.com/ArduPilot/ardupilot/pull/10950
  • Smaller!
  • Merged
UTC2319 - https://github.com/ArduPilot/ardupilot/pull/10914
  • Merged
UTC2319 - https://github.com/ArduPilot/ardupilot/pull/10890
  • Nice cleanup
  • Slight change to HIL which is already dead
  • Any HIL code can be removed as we’ll have another approach later
  • 10900 - next week!
UTC2323 - https://github.com/ArduPilot/ardupilot/pull/10906
  • Metadata out of date compared to image
  • Extrapolation of position
  • Surprising amount of maths in get_position
    • Will be more accurate
  • Technical change
  • Tests will be added
  • Plane GPS update oddity
  • People will be happy to put this in once we have regression test and early returns
  • Nate can do some testing
UTC2336 - make sure all cores are healthy
  • https://github.com/ArduPilot/ardupilot/pull/10873
  • Checks active EKFs only
  • Plane was OK
  • Other vehicles are messy
  • Rover has behaviour change
    • Should be investigated in case its a more widespread problem
    • Wrong set of EKFs being checked?
      • Type you want to use or the ones you are using?
      • Probably correct as is, just needs checking
    • Check it under Valgrind?
    • Randy is happy to help looking at this
  • No AHRS healthy check
    • Reproduces in SITL
  • AHRS health checks in Copter are a bit strange
  • Not a valgrind issue
    • But note the problem in Storage with Valgrind
UTC2343 - https://github.com/ArduPilot/ardupilot/pull/10817
  • Tridge needs to check this
  • INS: AP_InertialSensor comments for new cubes
UTC2345 - https://github.com/ArduPilot/ardupilot/pull/10614
  • Weekly nudge
  • Needs a mid-week nudge
  • Peter’s been flying it
UTC2348 - https://github.com/ArduPilot/ardupilot/pull/10539
  • Rebased recently
  • Francisco picked some things up…
    • Addresses
  • Fixes EKF2 terrain estimator use of optical flow data
  • Merged without squashing
  • Travis failed?
UTC2351 - https://github.com/ArduPilot/ardupilot/pull/10477
  • Make sure it works with mavlink1 and mavlink2
  • Can go in once it is tested
UTC2357 - https://github.com/ArduPilot/ardupilot/pull/9716
  • Needs spool stuff
UTC2358 - https://github.com/ArduPilot/ardupilot/pull/9017
  • Needs Spool stuff
UTC2359 - https://github.com/ArduPilot/ardupilot/pull/7291
  • MdB is averse to statustexts
  • Tridge likes “messages” in MAVProxy to see what’s generally going on
  • [11:00 AM] (Channel) rmackay9: I don’t think we should send out status text if things are working as they should for the most part…
  • [11:00 AM] (Channel) rmackay9: we can enhance the log viewr
  • Peter really likes getting the waypoint messages
  • Randy thinks we should just enhance the GCSs instead
  • Mission on vehicle isn’t necessarily the same one as on the GCS
  • OK for 99% of people
  • Forced statustexts doing anybody any favours?
  • MAV_SEVERITY isn’t necessarily a good solution
  • MISSION_CURRENT should have a type field
  • We don’t log some stuff (frame)
  • Merged!
  • Need to fix the CMD log message to include frame
UTC0006 - https://github.com/ArduPilot/ardupilot/pull/10162
  • The onion
    • Has been flown and rebased
  • Not fully reviewed yet
  • More eyes on the code
  • Re-entering old mode requires reinitialisation
  • Maybe a better step to split it?
  • Tridge is thinking of putting this in before stable
    • And an extended beta period
  • [11:11 AM] (Channel) MdB: backporting around this one will be less of a problem, but it’s gonna be bad either way :slight_smile:
  • There are lots of features in master that we need a stable release for!
  • Not going to the next step is a good idea
UTC0014 - FoxTech log / TECS bug fixed
  • TECS bug triggered by bad input
  • Serious issue, new stable release done
  • Suggest people update
  • TECS.iph jumps from a reasonable number to -1000
    • Integrators should not do that
    • Can go to nose-up or nose-down
  • RC frames can come in at 100Hz
    • Logging is done at 25Hz
    • Maybe log min/max values?
UTC0017 - https://github.com/ArduPilot/ardupilot/pull/10321
  • Should that be back-ported?
  • Already is
  • Missed in the release notes
UTC0020 - did find and fix parameter reset issues
  • Can and did cause the issue
  • Will wait and see if any parameter resets past this
  • Bug only in master, not stable releases
UTC0021 - Tom and LED
  • No clock pin on the LED strip
  • Kinda dma’d
  • Emulates oreoled driver
  • [11:23 AM] (Channel) LuisVale: the neopixels need very precise timming
  • Auxillary pins
  • D-shot-like
  • 8-bit RGB strips
  • 5V required
  • Many RTF copters have these built in
    • Kopis
  • [11:27 AM] (Channel) LV: i had on a hexa 20 leds per arm connected to a teensy that translated mavlink and displayed patterns
  • [11:28 AM] (Channel) LV: one little problem, those leds draw too much power
  • [11:28 AM] To Weekly devcall: @LuisVale from what?
  • [11:28 AM] To Weekly devcall: Just generally?
  • [11:28 AM] (Channel) LV: the power ? from the battery…
  • [11:29 AM] (Channel) LV: can’t recall exactly but when you add 120 leds it just adds up
UTC0023 - dronekit
UTC0030 - default frames
  • Models of frames to recommend
  • One of our partner now has two frames which are within what we would like to see
  • https://shop.holybro.com/pixhawk4-s500-kit_p1131.html?
  • https://shop.holybro.com/pixhawk-4-mini-qav250-kit_p1125.html
  • The QAV250 was a nice chase vehicle
    • 5Ah battery for long flight times….
  • ESCs are blhelis not blheli32 and the passthrough doesn’t work on ArduPilot
  • Should we be recommending kits to people?
    • It’s a Copter thing…
    • It’s a nice vehicle…
  • Components can be sourced from just about anywhere
  • S500 is a nice reference frame
  • Randy’s call as to whether this is appropriate on the Wiki
  • We really should get some ArduPilot branding in there somehow
    • But we shouldn’t spend partner’s money on sending stickers to other partners…
  • These boards probably ship with PX4 on them
    • Would be nice to have the AP bootloader and AP firmware on there
    • We really shouldn’t be advertising them in the Wiki if they’re not shipping with ArduPilot
UTC0039 - issue with arming PR
  • Look at GPS health status
  • Plane only healthy if 3D fix
  • Rover is always healthy unless GPS is unhealthy
  • Xy component probably dubious if you don’t have 3D fix
  • Don’t have a GPS and lose fix on Rover…
    • Bad stuff in acro mode?
UTC0040 - reminder on GSoC - please have a look at submissions
Was https://github.com/ArduPilot/ardupilot/pull/10963 at the top of the list discussed? I don’t see any mention in the minutes.
I see it mentioned now, but why was it not merged?
It was discussed.
We decided to merge and I just did that…
Peter
