I am working on visual slam based odometry source. I have managed to use my odometry via mavlink.
I setup
EK3_SRC2_POSXY 6
EK3_SRC2_VELXY 6
and set:
The active set can be selected via an RC auxiliary switch (e.g. set RCx_OPTION
to “90” / “EKF Source Set”).
And it even somehow works.
The problem I have, then pilot switch ekf sources, information is shown in Ground station, but as log message, and this message sometimes is missed by pilot, specially then he switch sources online.
So It will be good to have capability to know witch source is used, and also it will be very use full to have access to this information via mavlink, in such case I will have capability to change some parameters based on source (for example LOIT_ACC_MAX)
So if there is any capability to know what source is currently used programmatically via some mavlink request?
