We experience “delay” when we have big throttle input on our quad.
We move up the throttle for exemple and release it, the drone still go up for about 1 sec before it stops.
One might think RC inputs translate directly in velocity commands, but in fact they go through a input shaping process, to make sure the provided commands respect the acceleration and jerk limits in the controller.
Now, this is probably an issue when there’s an unwanted delay when braking from a horizontal velocity, but I’m not sure if that affects vertical velocity as well.
Nonetheless, you might want to play with LOIT_BRK_ACCEL, LOIT_BRK_JERK, LOIT_BRK_DELAY and PSC_JERK_Z. But these will also affect braking on the horizontal plane.
Looking at your graph, the Desired Climb Rate does start to flatten out as soon as you lower your throttle input (ThI). The desired climb rate doesn’t instantly go to 0 because that require a very large deceleration and jerk. If you go in the PSCD log structure, you can see the desired and actual velocity and acceleration.
I took the liberty of measuring the slope of the PSCD.DAD (Desired Acceleration in the Down direction) during the moment ThI reduces. The slope was 4.95, and PSC_JERK_Z is set to 5. So the rate of change of your acceleration (jerk) is currently limited by that parameter. If you increase the jerk limit, you’ll start decelerating faster. However, your next limit might be reaching the LOIT_BRK_ACCEL limit too fast (which limits the max deceleration you can achieve).
any reason why you use Thrust Expo 0? T-Motor Flame ESC also no longer needed super low value.
Am I correct you are using a 15" propeller? if yes, your ATC_ACCEL_x_MAXs are not the default for 15".
My guess you have done a quiktune.
That’s the value we found on our test bench. We have volonterly understimate it a bit, it could be 0.1.
We have 22" props, so our ATC_ACCEL_x_MAXs are not out of range, a bit lower than recommed by choice.
But you are right, these value could have an impact.
The recommended MOT_THST_EXPO value for 22" propeller is 0.72. that’s a huge diff.
For common ESC/Motors/Props yes but that’s only a recommendation base on experience. We know for sure that’s not the case for us. If your ESC have already a correction build in, no need for this value.
Then your ATC_RAT_xxx_FLTD, ATC_RAT_xxx_FLTT are not recommended values for 22" propeller.
Should be half of your INS_GYRO_FILTER which is 30, yes higher than the 22 recommended but our frame doesn’t seem to be noisy between 22 and 30 so no need to go that low.
But you are right, that’s not the default recommended configuration.
I could have missed something but for now we have good result with these params.
