Hi guys,
In my quest to get my minimOSD working, I replaced all the SR0 and SR1 port values.
I am using minimOSD on port SR2 so I got there in the end. However now I want to put the defaults back in.
How do I do that? I m running 3dr radios on SR1 and I understand SR0 is for the usb so it would be good to put those back to stock.
Cheers,
Sandy
After loading the default parameter you will have all SRx parameters set to 0. This can be considered as the default parameters. However, in MP under optional hardware, OSD., you will get a set of reasonable default parameters
Cheers, Harald
Sent from my iPhone using Tapatalk
