Failed to load analyzer results
System.Xml.XmlExeception: Unexpected end of file has occurred. The following elements are not closed:
header, loganalysis. Line 8, position 1.
at system.Xml.xmlTextReaderimpl.Throw(exception e)
at system.Xml.xmlTextReaderimpl. ThrowUnclosedElements()
at system.Xml.xmlTextReaderimpl.ParseElementConent()
at system.Xml.XmlSubtreeReader.Read()
at system.Xml.XmlReader.MoveToContent()
at system.Xml.XmlReader.IsStartElement()
at MissionPlanner.Utilities.LogAnalyzer.Results(String xmfile) in C:\Users\mich1\Desktop\CubePilot\MissionPlanner\Utilities\LogAnalyzer.cs:line 132
at MissionPlanner. GCSViews.FlightData.But_loganalysis_Click(Object sender. EventArgs e) in C:Users\mich1\Desktop\CubePilot\missionPlanner\GCSViews\FlightData cs:line 1205
THIS Users\mich1\ IS NOT ME…please Help
Ken
Hi Ken
Are you referring to the auto analyzer in MissionPlanner?
Most people dont use it because some results might be outdated and some results might be too simplistic to be useful. I’ve now doubt is was a very good idea at the time.
Otherwise if MissionPlanner is giving you problems in general, you might be able to uninstall, clean, reinstall
Thanks Shawn for your insight.
It’s handy to do the Beta updates from the Help screen of MissionPlanner, unless you’ve got a special reason to avoid the Beta updates.
