Data anomalies when using RPLIDAR C1 on MATEKF405 TE
On MATEKF405 TE, I can establish communication with RPLIDAR C1 initially, but after approximately one minute of operation, the data starts to exhibit issues. However, on CUAV X7+PRO, it operates normally for over ten minutes without any problems. This discrepancy has left me quite puzzled, and I’m seeking guidance on this matter.
Below are some of the parameters I used:
  • SERIAL4_BAUD = 460800
  • SERIAL4_PROTOCOL = 11
  • PRX1_TYPE = 5
    *PRX1_ORIENT=0
    Both flight controllers have the same settings.
his is MATEKF405 TE’s issue.
This is X7+PRO’s.
Did you ever find a solution? I too am having issues with the C1 lidar
I replaced the H743 flight control without any problems. It seems that the IO of the F405 does not support high-speed data.
