Dake FPV FC Current drops slowly during flight
I am on the latest FW, during my flight the flight controller shows that my current draw is less than when I began. I have several of these and they all seem to do the same.
Do they all use the same ESC’s where presumably the current signal is coming from?
Yes sir they do, it’s the esc from them
Might it be that you see measure voltage as current, that’s why it drops? What exactly FC do you use? Cannot open attached log file in the webtools.
Dakefpv fc
Measured volts drops
Not sure if this can cause, but temeperature difference in the shunt resistor used for current monitoring could alter its resistance and cause difference in measured current
