CX-OF setup wiki incomplete?
I followed the CX-OF setup guide.
http://ardupilot.org/copter/docs/common-cheerson-cxof.html
I have it connected and settings set as recommended in the wiki. I’m not getting any flow data in the quick window under flow_comp_m_x or flow_comp_m_y. I’m wondering if it has to do with an incorrect baud rate? I didn’t see any info on the wiki regarding correct baud rate for the serial port in use. I’ve tried 57 and 115 for the baud parameter. @rmackay9 what baud rate did you use for your demo? I’m using a cube on 3.6.5 with the latest beta MP. I’ve successfully used a PX4flow on this setup before.
Thanks for any help as always.
As it stated on the Wiki CX-OF supported from 3.6.4 or higher
Oops! I meant 3.6.5. Thanks for the catch.
Baud rate is 19200 but you don’t need to set as the driver forces it. There is no output to HUD , you need to check values directly pn the log for calibration.
I suggest you read the blog about it , its full of information
If you dont get “Bad OF health” messages in Mission Planner then it is working :smiley:
Andras, you need confirm IMU anf OF axes are aligned and calibrated using the logs
@ppoirier Totally agree, not getting Bad OF Health messages only means it is transmitting valid data to the FC, then indeed it needs to be calibrated and orientation checked.
