I need a custom firmware for my Kakute F7 boards, namely to include canvas mode OSD (or whatever it’s called), to get OSD via HDZero.
Anyway, it looks like the custom firmware builder web page is taking about 70 hours to build a firmware. That just seems quite odd to me, shouldn’t it take just a minute? 5 minutes? Is the custom firmware builder automated? Or maybe someone is doing the builds manually?
Looks like the firmware builder was working fine for a few hours, but now it’s back up to 20-24 hours to create a build.
By the way, the ONLY feature I would like to add to the “official release” firmware for my Kakute F7, is canvas mode OSD. The official release firmware is 700-some k - well below 1mb. Seems like OSD (a very common wanted feature?) can be added to the Kakute F7 official firmware, so that a person doesn’t have to do a custom build.
While I’m not convinced that OSD is a super common feature (not all of us regularly use FPV or downlinked video of any kind), I can agree that if an autopilot includes OSD hardware, it should probably be supported by the native feature set.
my quad is tilting to one side…can u pl tell whats the problem. below is the log:
Log File C:\Users\PRASHANT SOOD\AppData\Local\Temp\tmp123C.tmp.log
Size (kb) 108.5234375
No of lines 2133
Duration 0:00:01
Vehicletype ArduCopter
Firmware Version VDD_5V_PERIPH_nO
Firmware Hash 4fcfa4b2
Hardware Type
Free Mem 0
Skipped Lines 164
Test: Brownout = GOOD -
Test: Compass = WARN - WARN: Large compass offset in MAG data (X:377.00, Y:43.00, Z:38.00)
mag_field interference within limits (9.07%)
Test: Dupe Log Data = GOOD -
Test: Empty = FAIL - Empty log? Throttle never above 20%
Test: Event/Failsafe = GOOD -
Test: GPS = FAIL - Min satellites: 0, Max HDop: 99.99
Test: IMU Mismatch = NA -
Test: Motor Balance = UNKNOWN - ‘OCTAQUAD/X’
Test: NaNs = FAIL - Found NaN in CTUN.TAlt
Found NaN in CTUN.DSAlt
Test: OpticalFlow = FAIL - ‘FLOW_FXSCALER’ not found
Test: Parameters = FAIL - ‘MAG_ENABLE’ not found
Test: PM = UNKNOWN - No PM log data
Test: Pitch/Roll = GOOD -
Test: Thrust = GOOD -
Test: VCC = UNKNOWN - No CURR log data
Prashant - I do not know (I am not an expert). I suggest you post your issue in one of these categories, depending on which version of Arducopter you are running:
