Custom STM32H743 flight controller based on MicoAir743: sensors work in bare-metal test, but ArduPilot shows RAW_IMU = 0
I am trying to port ArduPilot to my own custom flight controller based on the STM32H743VIT6, using MicoAir743 as the closest reference board.
My board hardware is:
  • MCU: STM32H743VIT6
  • HSE: 8 MHz
  • USB FS: PA11/PA12
  • LEDs:
    • PE4 = BLUE
    • PE5 = RED
    • PE6 = GREEN
Sensor connections:
  • SPI bus:
    • PD3 = SCK
    • PC3 = MOSI
    • PC2 = MISO
  • IMUs:
    • BMI088 accel CS = PD4
    • BMI088 gyro CS = PD5
    • BMI270 CS = PA15
  • I2C bus:
    • PB10 = SCL
    • PB11 = SDA
  • I2C sensors:
    • LPS22HH barometer
    • LSM303AGR accel/mag
I created custom hwdef.dat and hwdef-bl.dat for my board and built ArduPilot for it.
My problem is:
  • in some builds the board boots and connects to Mission Planner,
  • but RAW_IMU stays at zero,
  • AHRS shows error_rp = 1,
  • roll/pitch/yaw do not react,
  • and barometer detection also seems broken.
In Mission Planner, RAW_IMU.xacc/yacc/zacc/xgyro/ygyro/zgyro remain 0 all the time.
What makes this confusing is that I wrote a separate bare-metal sensor test firmware for the same board, and in that test:
  • BMI088 responds correctly,
  • BMI270 responds,
  • LSM303AGR responds,
  • movement changes the IMU readings,
  • compass changes are also detected.
So the hardware and sensor wiring seem to be correct.
I also noticed that a previously downloaded MicoAir743 arducopter_with_bl.hex appears to be from ArduCopter 4.6.3, while my local builds from current master are 4.8.0-dev, and the generated .hex files differ a lot. Because of that, I am not sure whether I am dealing with:
  • a hwdef mistake,
  • a sensor driver/init issue,
  • a difference between 4.6.3 and current master,
  • or some board-specific detail in MicoAir743 that I missed.
My questions are:
  1. If the sensors work in bare-metal code, what is the most likely reason for RAW_IMU = 0 in ArduPilot?
  2. Is there anything for BMI088/BMI270 on H743 boards that must be configured beyond hwdef.dat / hwdef-bl.dat?
  3. Could a barometer or compass init failure prevent the IMU from becoming usable?
  4. Would it be better to start from a minimal BMI088-only config first and add the other sensors later?
  5. Is there any known-good example for a custom H743 board very close to MicoAir743?
If needed, I can also post my hwdef.dat, hwdef-bl.dat, and exact sensor pin mapping.
Thanks in advance.
If you want, I can also make a shorter, more “forum-style” version, or a more technical one with the exact hwdef lines included.
Of course it’s needed!
  • HSE: 8 MHz
  • USB FS: PA11/PA12
  • LEDs:
    • PE4 = BLUE
    • PE5 = RED
    • PE6 = GREEN
Sensor connections:
  • SPI bus:
    • PD3 = SCK
    • PC3 = MOSI
    • PC2 = MISO
  • IMUs:
    • BMI270 CS = PA15
  • I2C bus:
    • PB10 = SCL
    • PB11 = SDA
  • I2C sensors:
    • LPS22HH barometer
hwdef-bl_dat.txt (838 Bytes)
hwdef_dat.txt (3.3 KB)
