Custom STM32F767 flight controller based on FMUv5 pin configuration – SPI1 alternate pin mapping
I am designing a custom flight controller using the STM32F767IIT6, with the ArduPilot FMUv5 hardware definition as a reference.
I am currently having an issue with the SPI1 pin mapping.
The standard SPI1 pin configuration on the STM32F767 that I tested is:
PA5  SPI1_SCK
PA6  SPI1_MISO
PA7  SPI1_MOSI
With this configuration, SPI1 works correctly.
However, the FMUv5 uses the following SPI1 pin mapping:
PG11 SPI1_SCK
PA6  SPI1_MISO
PD7  SPI1_MOSI
When I use the FMUv5 pin mapping, I do not see any SPI signal on the bus.
I would like to use the FMUv5 pin mapping because I need to keep PA7 available for CRS_DV for an RMII Ethernet connection.
For testing, I have temporarily removed all Ethernet-related configuration from my hwdef.dat.
The relevant SPI configuration is currently:
PG11 SPI1_SCK SPI1
PA6  SPI1_MISO SPI1
PD7  SPI1_MOSI SPI1
The SPI devices are configured as:
SPIDEV icm42688 SPI1 DEVID1 ICM42688_CS MODE3 2*MHZ 8*MHZ
SPIDEV icm20602 SPI1 DEVID1 ICM20602_CS MODE3 2*MHZ 8*MHZ
With the following configuration:
PA5 SPI1_SCK SPI1
PA6 SPI1_MISO SPI1
PA7 SPI1_MOSI SPI1
the SPI bus works correctly. However, with:
PG11 SPI1_SCK SPI1
PA6  SPI1_MISO SPI1
PD7  SPI1_MOSI SPI1
I do not observe SPI activity.
I have also configured:
DMA_NOSHARE SPI1*
DMA_PRIORITY SPI1*
My questions are:
  1. Is the hwdef.dat syntax above sufficient to configure the alternate SPI1 pin mapping on the STM32F767?
  2. Is there any additional configuration required for the STM32F7/ChibiOS alternate-function pin mapping?
  3. Are PG11, PA6, and PD7 valid and usable as the three SPI1 signals in this configuration?
  4. Could the issue be related to DMA, alternate-function selection, or the specific SPI1 configuration used by ChibiOS?
  5. Is there any additional configuration required when moving SPI1 away from the default PA5/PA6/PA7 pins?
I am using the following hardware definition:
hwdef.txt (2.4 KB)
For debugging, I can also provide:
  • the complete schematic and PCB pin mapping;
  • the exact ArduPilot branch/commit used to build the firmware;
  • boot messages and console output;
  • a DataFlash .BIN log;
  • logic-analyzer captures comparing the working and non-working SPI configurations.
Thank you very much for your help :slight_smile:.
Best regards,
David
