Hi all,
I have added new parameters to the Ardusub/Parameters.cpp class.
The parameters show up in QGC and can be set without an issue.
However, after a reboot the parameters are always back at default value.
Interestingly enough, i also added a parameter to AP_MOTOR/Motors6dof.cpp class, which also works fine. This parameter is also persisten through reboots.
Example of implementation in Ardusub/Parameters.cpp
- added to var_info[]
// @Param: DOCKING_YAW_P
// @DisplayName: Docking Mode Heading P
// @Description: Docking mode heading PID controller, P gain
// @Range:-10000 10000
// @User: Advanced
GSCALAR(docking_mode_yaw_p, "DOCKING_YAW_P", DOCKING_YAW_P_DEFAULT),
The example parameter is added in the enum in Ardusub/Parameters.h as
k_param_docking_mode_yaw_p = 5000,
and the variable is defined as
AP_Float docking_mode_yaw_p;
The default value is defined in ArduSub/config.h as
#ifndef DOCKING_YAW_P_DEFAULT
#define DOCKING_YAW_P_DEFAULT 25
#endif
Any thoughts on how to get this to be persisten through reboots?
Cheers
