Custom flight controller does not arm
I created a pretty my flight controller, I have to believe the problem is with the software, I have finished the configuration and all parameters are set and good to go, it will arm but in the messages I get initializing APM
Post more information
.param file
.bin dataflash log with LOG_DISARMED=1
What hardware exactly?
Have you edited the hwdef file?
I like to say, when I created the problem any version I use will have this issue initializing APM, I even use a pixhawk and program the parameters and when I finish and arm it I will get the same error, no matter if I reset module and start over and again all I get it initializing APM. I don’t know how to open Mavlink to change in the parameters to 1, can you give me some advice on working the mavlink
You did not answer any question.
What flight controller hardware
Which firmware version?
Do not post duplicates. Please confine the relevant discussion to this single topic.
EDIT: I have now deleted TWO duplicate topics. Please keep the discussion here.
