Hello
I am wanted to know how do we measure current from x13 hobbywing motor
Each motor max current is 200amp
In quad mode this will result in almost max800amp current.
Are their any sensors for this capability
Hello
I haven’t heard of a power module capable of handling 800A on its own. Even if one exists, it would likely be expensive and hard to find. Consider setting up a Hall Effect Current Sensor yourself to measure such a high current. Alternatively, if supported by the Hobbywing X13, you might explore receiving current data via CAN communication or datalink from ESC. The voltage and current received from these ESC telemetries can be utilized as a battery monitor.
Thanks for this, I jsut checked they do support can will try that out thanks
