Is there a specific reason why the CURRENT sensor logging is software-limited to run in a one-second loop other than at 10 or 50 Hz? Is this a limitation of the sensor, are there other considerations for this, or can I harmlessly move this logging from the one-second loop to the 10Hz (or even 50Hz) loop?
What makes you think its logging in a one second loop? Have a look at any dataflash log - you will see its logging MUCH faster then once a second.
Thanks, Grant.
