CubeOrange+ Secure Bootloader breaks USB in release build (-Os), works only with --debug (-Og)
Description:
I am implementing secure boot on CubeOrange+ (STM32H757) using ArduPilot.
Issue:
The secure bootloader built in normal (non-debug) mode causes complete USB enumeration failure after reboot, while the same bootloader built with --debug works correctly.
Hardware:
  • Board: CubeOrange+
  • MCU: STM32H757
  • Connection: USB (OTG FS)
  • Debug: ST-Link V2 (SWD)
Software Setup:
ArduPilot versions tested:
  • 4.5.7 (default)
  • 4.6.3 (modified to fit flash)
Build commands:
Non-debug:
Tools/scripts/build_bootloaders.py CubeOrangePlus --signing-key=KEY.dat
Debug:
Tools/scripts/build_bootloaders.py CubeOrangePlus --signing-key=KEY.dat --debug
Observed Behavior:
Non-debug bootloader (-Os):
  • Firmware upload succeeds
  • After reboot:
    • No USB enumeration
    • No /dev/ttyACM*
    • Not visible in lsusb
  • Board appears dead over USB
  • Recoverable via ST-Link
Debug bootloader (-Og):
  • Works correctly
  • USB enumerates as:
    CubeOrange±Secure-BL-v10
  • Firmware loads and runs normally
Key Finding:
Issue reproducible on:
  • Stock ArduPilot 4.5.7 (no modifications)
  • Reduced 4.6.3 build (no modifications)
Conclusion: Not caused by user modifications.
GDB_logs.txt (10.0 KB)
