CubeOrange+ build failed: cannot move location counter backwards
i use Copter-4.6.2 to build CubeOrange success.
i use Copter-4.6.2 to build CubeOrange+ failed.
error msg is below:
[1212/1218] Linking build/CubeOrangePlus/bin/arducopter
/usr/lib/gcc/arm-none-eabi/10.3.1/../../../arm-none-eabi/bin/ld:common.ld:202 cannot move location counter backwards (from 0000000008200b40 to 0000000008200000)
collect2: error: ld returned 1 exit status
Waf: Leaving directory `/home/ping/ardupilot/build/CubeOrangePlus’
Build failed
→ task in ‘bin/arducopter’ failed (exit status 1):
{task 133626833488240: cxxprogram AP_Arming.cpp.50.o,AP_ExternalControl_Copter.cpp.50.o,AP_Rally.cpp.50.o,AP_State.cpp.50.o,Attitude.cpp.50.o,Copter.cpp.50.o,GCS_Copter.cpp.50.o,GCS_Mavlink.cpp.50.o,Log.cpp.50.o,Parameters.cpp.50.o,RC_Channel.cpp.50.o,UserCode.cpp.50.o,UserParameters.cpp.50.o,afs_copter.cpp.50.o,autoyaw.cpp.50.o,avoidance.cpp.50.o,avoidance_adsb.cpp.50.o,baro_ground_effect.cpp.50.o,commands.cpp.50.o,compassmot.cpp.50.o,crash_check.cpp.50.o,ekf_check.cpp.50.o,esc_calibration.cpp.50.o,events.cpp.50.o,failsafe.cpp.50.o,fence.cpp.50.o,heli.cpp.50.o,inertia.cpp.50.o,land_detector.cpp.50.o,landing_gear.cpp.50.o,mode.cpp.50.o,mode_acro.cpp.50.o,mode_acro_heli.cpp.50.o,mode_althold.cpp.50.o,mode_auto.cpp.50.o,mode_autorotate.cpp.50.o,mode_autotune.cpp.50.o,mode_avoid_adsb.cpp.50.o,mode_brake.cpp.50.o,mode_circle.cpp.50.o,mode_drift.cpp.50.o,mode_flip.cpp.50.o,mode_flowhold.cpp.50.o,mode_follow.cpp.50.o,mode_guided.cpp.50.o,mode_guided_nogps.cpp.50.o,mode_land.cpp.50.o,mode_loiter.cpp.50.o,mode_poshold.cpp.50.o,mode_rtl.cpp.50.o,mode_smart_rtl.cpp.50.o,mode_sport.cpp.50.o,mode_stabilize.cpp.50.o,mode_stabilize_heli.cpp.50.o,mode_systemid.cpp.50.o,mode_throw.cpp.50.o,mode_turtle.cpp.50.o,mode_zigzag.cpp.50.o,motor_test.cpp.50.o,motors.cpp.50.o,navigation.cpp.50.o,precision_landing.cpp.50.o,radio.cpp.50.o,sensors.cpp.50.o,standby.cpp.50.o,surface_tracking.cpp.50.o,system.cpp.50.o,takeoff.cpp.50.o,takeoff_check.cpp.50.o,terrain.cpp.50.o,toy_mode.cpp.50.o,tuning.cpp.50.o → arducopter}
(run with -v to display more information)
That means that you are out-of-memory.
Disable some un-used features for it to compile without errors.
Could you provide a reference for which modules/features are disabled in the official build of CubeOrange+_Copter.apj? Also, could you suggest the recommended ./waf configure command?
