I’m using a CubeOrange+ with a CubeNode Eth connected to a Jetson. The Jetson is running mavlink-router and I’ve connected to it over WiFi6. I’m trying to download some logs off of my Cube but I get limited to around 90kb/s? The baudrate I’ve set on the Cube for the CubeNode Eth is 12.5M and I know I’m not being limited by my WiFi6 speed either. I’ve tried connecting to the Jetson over ethernet directly and that still limits it to 90kb/s download. I’ve tried both MP and QGC. Not sure what else to try next.
Cheers
I’m having the same problem, tried enforcing rts/cts but didn’t work either.
If you’re seeing slow log downloads through CubeNode ETH, please share your full setup, including parameter files from both the Cube and CubeNode ETH, firmware versions, and the network or mavlink-router configuration. Please also specify the transfer speed and whether it is in kilobits or kilobytes per second.
For comparison, try the serial link at 8 Mbaud instead of 12.5 Mbaud, and try TCP instead of UDP. Please report the download speed for each configuration.
Refer Setting Up the Physical Connection between the Cube, CubeNode, and laptop/PC | CubePilot for more details.
