CubeETH Serial Rate Questions
Hi all,
I have a CubeOrange+ hooked up to a cube-eth. All of that works fine. I have the Cube serial 1 plugged in to the Cube Eth - when I change the serial rate of Mission planner to #Hz - it changes the SR3 parameters on the cube orange. Why is this? Does this mean serial 3 is being tied up inside the autopilot? Is it being shared?
Any clarity would be great please.
SRx parameters are MAVLink stream parameters, they aren’t directly tied to physical serial ports, they are MAVLink ports in order of allocation.
So what controls the allocation then? If I set all my serial ports to output mavlink streams would the SR# corresponding to my cube eth udp stream change?
