Is there any guidance on how to get the two FMU’s on the Cube Red to interact with one another? Is that even a thing? Or is there any reason the primary has only the AUX PWM channels and the secondary has the MAIN 8 channels? I am setting a quadplane up and was using the primary up until I went to test motors and control surfaces, no dice trying to get everything working together. On the other hand, the battery monitor does not work at all on the secondary. This seems like a very capable flight controller and my hope is I am not using it correctly, but I can’t find any documentation to direct me otherwise.
It seems like no seller is selling this CubeRed stable version yet, I am curious how you purchase it.
Sure there is
Cube Red
@Jai.GAY @dkemxr yeah that is the one I have. Is there a way to use the the entire servo rail on the primary chip?
I saw it, but it appears to be a beta version. The link says so.
Does the beta version not have the ability to use all 14 PWM outputs on the primary FMU?
Cube Red is supported in Stable.
Post on the Cube Pilot forum with questions.
