Cube Orange+ Rover (Twin Motor Boat) - Flycolor 120A ESC Initialization & Dangerous Behavior
Hi everyone,
​I am working on a twin-motor USV (Unmanned Surface Vehicle) project. I am relatively new to ArduPilot systems, so I might be missing some basic configuration steps. I am facing a dangerous initialization issue with my ESCs.
​Hardware Setup:
​FC: Cube Orange+ (Standard Carrier Board, ADSB version).
​Firmware: ArduRover 4.6.3 (Stable).
​ESCs: 2x Flycolor 120A Brushless ESC (Boat/Car version with Reverse).
​RC: RadioLink AT9S Pro Transmitter & R9DS Receiver (SBUS connected to RCIN).
​Power: 4S LiPo.
​The Issue:
When I power up the system with default settings (Trims at 1500), the two motors behave completely differently:
​Left Motor: Keeps beeping continuously (indicating throttle signal is not detected or not at neutral).
​Right Motor: Beeps once and then immediately spins up to FULL THROTTLE (even though the transmitter stick is at neutral!).
​Critical Observation:
When I try to change the SERVO_TRIM values to something else (e.g., 1000 or 1100) to stop the full-throttle behavior, both motors stop working completely and just beep continuously. I cannot get any response.
​Current Configuration:
​FRAME_CLASS: 2 (Boat)
​FRAME_TYPE: 0 (Undefined/Default)
​SERVO1_FUNCTION: 73 (Throttle Left)
​SERVO3_FUNCTION: 74 (Throttle Right)
​SERVO1_TRIM / SERVO3_TRIM: 1500 (Currently set to Center)
​SERVO1_MIN / SERVO3_MIN: 1100
​SERVO1_MAX / SERVO3_MAX: 1900
​MOT_PWM_TYPE: 0 (Normal PWM)
​BRD_SAFETY_MASK: 16383 (Safety switch bypassed).
​ARMING_REQUIRE: 0 (Disabled to force signal output).
​What I have tried so far:
​Channel Mapping: I suspected there might be a mismatch between my transmitter’s throttle channel and the Cube’s throttle channel input. I attempted to adjust the mapping to fix this, but it did not resolve the issue. The strange behavior persists.
​Direct Receiver Test: When I connect the ESCs directly to the Receiver (Channel 3), they calibrate successfully and work perfectly as intended. However, when I connect them back to the Cube, they do not work as I want (either beeping or full throttle) and I cannot replicate that smooth operation.
​My Question:
Why would one motor refuse to arm while the other goes full throttle? And why does changing trims cause them to lose signal completely? It seems like a PWM range or Calibration mismatch between the Cube and the Flycolor ESCs.
​Any help is appreciated.
​Thanks.
I started a reply over at Cube Pilot by requesting the LOG_DISARMED log.
Happy for rover experts to reply here with suggestions.
