This is what it looks like all the time. I am trying to figure out why.
orangeplusparam.param (26.0 KB)
Don’t know but the 2nd notch is misconfigured and so are some of the SERVO parameters.
Sorry, forget about the comment on the 2nd Notch filter, it’s fine for a static notch. Whether you need it or not is another question.
You don’t need these if you have set the Bdshot mask:
SERVO_BLH_MASK,16128
SERVO_BLH_OTYPE,6
And I didn’t catch the RPM parameters you don’t need. Those are for an RPM sensor.
Or as Andy has said “it’s just plain wrong”…
Thanks dave, thos extra rpm parameters overoaded my H7, now everything is below 50%
That’s interesting to know. I was going to suggest the loop rate but I run my Cube Orange’s on 800 also and don’t see a problem.
This is with the RPM unchecked and with all the logging checked.
I went back and confirmed the notch filter, here it is
I have never set this because I tried once and it about bricked one of my holybro durandal fc.
maybe i should? benefits?
