Cube Orange+ - No GPS
I am trying to build my first quadcopter. I have a cube orange plus, I bought Radiolink TS100 Mini GPS which has Ublox M8 in it. It came with 6-pin JST-GH connector (which is correct). In the wiring diagram for gps it shows VCC - TX - RX - SCL - SDA -GND and Cube Orange’s GPS2 port is VCC - TX - RX - SCL - SDA - GND
So I Changed the TX and RX and also set the baud rate to 57600. GPS’s led is flickering it means it has positioning according to manual but mission planner still show it as a “NO GPS”
Also I can see the GPS in Compass calibration as external compass.
I dont know what to do? I really appreciate help.
Thanks for your time
So after posting this I thought lets try to reverse tx and rx and I found out manual and the wiring diagram is old. So anyone need answer GPS wiring was actually VCC RX TX SCL SDA GND
